Question about Nordic Track NordicTrack A2750 PRO Treadmill
The belt is slipping on my NordicTrack treadmill A2750. I've only had it for 2 months. I would like for my husband to fix it, but need some instructions. Initially, the belt slipped to the right; now it's just too loose to run safely.
  • 6,826 Answers
Http://www.nordictrack.com/webapp/wcs/stores/servlet/FAQItem_-1_10301_12401_faq-tread#a3
There's a video on how to adjust the belt tension.
I hope this helps!
Posted on Jul 29, 2010
Belt stops when stepped on
sounds like the belt is loose.there are bolts at the back on either side that tighten or loosen the belt.adjust with belt running about 3mph. tighten both bolts about 1/4 turn each while watching the belt to make sure it is centered. give it about 15 seconds after you tighten to see the adjustment that u make.the walking belt should only be able to lift up a little bit like 1 inch. you shouldn't be able to get ur hand all the way under belt (not running of course).
Apr 09, 2014 | Nordic Track NordicTrack A2750 Pro...
Belt off center on front roller
see the video and proceed according. God bless you
Jul 19, 2013 | Nordic Track NordicTrack A2750 PRO...
Belt off center
see the video and proceed. God bless you
I am having a difficult time finding a replacement walking belt for a NordicTrack A2750 pro. I have gone to the website but this particular belt does not seem to be listed (or I am just missing it). ...
Dear Sir:
Hello, I hope everything is O.k
Now i will help you quickly.
1) You must go to the website following: www.fitnessrepairparts.com
2) You will find anything that you NEED! FOR TRAINING FITNESS !.
Do it and GOOD LUCK!
Enjoy it, Sincerely.
E.CUADRA
Sep 05, 2011 | Nordic Track NordicTrack A2750 PRO...
When you have adjusted the most you can, should you replace the belt?
If you have tightened the belt and it continues to slip it is usually a sign that the deck and belt are worn. You may be looking at repairs that might be more costly than getting a new machine. You can check the deck by sliding your hand under the belt (not running) and feeling the deck surface. If you feel grooves or any rough spots then you need to replace it. The underside of the walking belt will also feel fuzzy like a peach if the fibers are breaking down.
If the machine is not very old or hasnt had much use then it could be several other things causing the slipping/stopping of the belt.
Feb 24, 2011 | Nordic Track NordicTrack A2750 PRO...
When running on our treadmill the belt slips.
Hello, It sounds like you have aslipping front roller pully. Remove the motor hood and watch the front roller while you are on it. Once the belt is moving slowly, try to stop the wlak belt by planting your fett for a second, if the walk belt stops, but the drive belt and motor continue to run, the plastic pully is slipping and the whole front roller will need to be replaced.
Hope this answers your question.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Jan 16, 2011 | Nordic Track NordicTrack A2750 PRO...
Belt will not stay tight.
Is it slipping side-to-side or front-to-back? If side to side, you can stop this by adjusting the two allen bolts on the bottom fronts sides of the treadmill. If it is front to front, and your treadmill is more than a few years old, the belt is probably stretched and needs replacing.
You can get a quote for a new belt at treadmill parts
Dec 19, 2010 | Nordic Track NordicTrack A2750 PRO...
I have a new NordicTrack A2750 PRO and the belt seems very slippery when I walk on it.
you will need to attach star washers to the rear roller bolts, they are having an issue with the lock washers they put on the rear roller bolts. Replace them with star washers. Tighten belt until it can be lifted about 2"-3" in the center.
Aug 11, 2010 | NordicTrack Exercise & Fitness
It stops after 1hour and 40 minutes of running how do I get it so I can go longer?
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
Jul 05, 2010 | Nordic Track NordicTrack A2750 PRO...
How do you adjust or tighten the belt on the Nordic Track A2750 The belt is riding to one side of the platform
If the walking belt is off-center, remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
May 14, 2010 | Nordic Track NordicTrack A2750 PRO...
Nordic Track NordicTrack A2750 PRO Treadmill Logo
221 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
