Question about KitchenAid Refrigerators
Compresser stopped working - KitchenAid Refrigerators
    President:
  • 1,099 Answers
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. WARNING: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. this will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
Good luck and Hope this work........
Posted on Jul 29, 2010
My ac is not working compresser kicks on then straight back off
if the a/c kicks in then turns off the pressure is not right and the system will need repressuring. you will need to take the vehicle to an a/c specialist to regas.
Jul 11, 2017 | AC Cars & Trucks
Try blowing console out with air compressed..with blow tip.or can of compressed air..but air compresser works best..make sure console fan is working..and clean..try getting the newest Xbox update as well ..
Aug 01, 2014 | Microsoft Xbox 360 Console
Why my acer 5633 stop working and mouse and all comand stop working and I had to stop with power buttom?
It may have been a software error (freeze-up) or hardware error.
Try starting the computer in Safe Mode and run a full virus/malware scan. If it freezes during that, force a shutdown again by holding down the power button for several seconds. Then sparay compressed air through the air vents on the side, rear, and bottom of the laptop. Do NOT shake the can of compressed air before spraying. You can buy a can of compressed air at any computer store or office supply store.
You can also run a test on the computer's memory to see if there's a faulty memory module. Check your Help & Support file for how to run Windows own "Memtest86".
Jun 13, 2014 | Acer Aspire 5633WLMi Notebook
When starting the engine, the engine turns until comression then stops. If I manually turn the engine back it does the same for several attempts and eventually starts.
Your compression release is not working as it should. On some saws, the compression release is a manual lever / button that is pressed before starting attempts. Sometimes it is tied into the choke. Other saws have an automatic compression release, based on a centrifugal cam.
If you are able to rotate the engine through the compression cycle, then the release "lobe" is likley worn. If you are not able to rotate the engine through the compression cycle, then the release mechanism is jamming.
Sep 09, 2010 | Garden
My advent cd drive stopped working what could it stop working
Either your CD/DVD drive is dirty & needs to be cleaned, or the drive has gone bad & needs to be replaced.
First, try to take the drive off the laptop. Open the drive & blow compressed air into it (from a can of compressed air) to clean it. You could also clean the lens (the small round glassy object inside the drive) using lens cleaning tissues & lens cleaning fluid.
If this did not fix the problem, you will need to replace the CD/DVD drive with a working one, or use an external CD/DVD drive.
Aug 29, 2010 | Computers & Internet
76,000 km and vehicle stops working with no
If the compression is down then you may need a valve job or a rebuilt engine. Put a tablespoon of oil in each cylinder and check the compression again. If it comes up then you need a valve job. If it doesnt change then your piston rings and seals are bad and will need a rebuild. If the valve seats are destroyed then chances are you need a valve job.
Mar 30, 2010 | 2004 Ford Focus
My 2005 XR650L stopped working and the shop says
So it needs piston & rings - right ?
I would call around.. Seems like the price is kinda steep..
Hope this helps !!
Jul 14, 2009 | 2005 Honda XR 650 R
A/c not cooling
it sounds the problem with the compresser.or may be ur compresser is getting heated quickly and stops working which stops cooling.
Dec 17, 2008 | Whirlpool ACE244XS Air Conditioner
Won't turn off with stop button have to take out battery
used compressed air and lightly blew dust from around and under controlls. works fine now. code 3
Dec 11, 2008 | RCA Lyra RD1021 MP3 Player
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
