Question about RCA F27645 27" TV
The cable jack on the back of tv, you know the one that you secure to the cable wire. It is not able to attach properly because the tiny hole that the little piece from the cable cord has be opened to wide, therefore I am not able to get a crisp picture. Can I replace the cable outlet?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 132 Answers
The input on the tuner needs to be replaced. It will have to be unsoldered from the outside of the tuner and there is a lead inside of the tuner that has to be unsoldered to get the old one off. You will then have to solder the new one back into those places. The input is only a buck or two. An old trick that some people do, is get a small piece of aluminum foil and stick it into the hole, and then reconnect the cable. Just make sure the foil is all the way in, and not touching the metal on the outside of the input. That will help a lot of times.
Posted on Jul 29, 2010
Why is the sound on my TV so low? I have it all the way to the end 100% and the sound can hardly be heard.
19LD350 is a small TV with tiny speakers, also if you are using a cable box it may not be properly set. Also try cleaning headphone jack [WD40] only a short spray in hole for headphone
Oct 16, 2014 | LG 19LD350 19Inch 720p 60Hz LCD HDTV 19 in...
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
I need to know how to seperate my transmission from my block
REMOVAL & INSTALLATION C6
  1. Disconnect the negative battery cable.
  2. From in the engine compartment, remove the two upper converter housing-to-engine bolts.
  3. Disconnect the neutral switch wire at the in-line connector.
  4. Remove the bolt securing the fluid filler tube to the engine cylinder head.
  5. Raise and support the truck on jackstands.
  6. Place the drain pan under the transmission fluid pan. Starting at the rear of the pan and working toward the front, loosen the attaching bolts and allow the fluid to drain. Finally remove all of the pan attaching bolts except two at the front, to allow the fluid to further drain. With fluid drained, install two bolts on the rear side of the pan to temporarily hold it in place.
  7. Remove the converter drain plug access cover from the lower end of the converter housing.
  8. Remove the converter-to-flywheel attaching nuts. Place a wrench on the crankshaft pulley attaching bolt to turn the converter to gain access to the nuts.
  9. With the wrench on the crankshaft pulley attaching bolt, turn the converter to gain access to the converter drain plug. Place a drain pan under the converter to catch the fluid and remove the plug. After the fluid has been drained, reinstall the plug.
  10. On 2WD drive models, disconnect the driveshaft from the rear axle and slide shaft rearward from the transmission. Install a seal installation tool in the extension housing to prevent fluid leakage.
  11. Disconnect the speedometer cable from the extension housing.
  12. Disconnect the downshift and manual linkage rods from the levers at the transmission.
  13. Disconnect the oil cooler lines from the transmission.
  14. Remove the vacuum hose from the vacuum diaphragm unit. Remove the vacuum line retaining clip.
  15. Disconnect the cable from the terminal on the starter motor. Remove the three attaching bolts and remove the starter motor.
  16. On 4WD drive models remove the transfer case.
  17. Remove the two engine rear support and insulator assembly-to-attaching bolts.
  18. Remove the two engine rear support and insulator assembly-to-extension housing attaching bolts.
  19. Remove the six bolts securing the No. 2 crossmember to the frame side rails.
  20. Raise the transmission with a transmission jack and remove both crossmembers.
  21. Secure the transmission to the jack with the safety chain.
  22. Remove the remaining converter housing-to-engine attaching bolts.
  23. Move the transmission away from the engine. Lower the jack and remove the converter and transmission assembly from under the vehicle. To install:
  24. Tighten the converter drain plug.
  25. Position the converter on the transmission making sure the converter drive flats are fully engaged in the pump gear.
  26. With the converter properly installed, place the transmission on the jack. Secure the transmission on the jack with the chain.
  27. Rotate the converter until the studs and drain plug are in alignment with their holes in the flywheel.
  28. Move the converter and transmission assembly forward into position, using care not to damage the flywheel and the converter pilot. The converter must rest squarely against the flywheel. This indicates that the converter pilot is not binding in the engine crankshaft.
  29. Install the converter housing-to-engine attaching bolts and tighten them to 65 ft. lbs. (88 Nm) for the diesel; 50 ft. lbs. (68 Nm) for gasoline engines.
  30. Remove the transmission jack safety chain from around the transmission.
  31. Position the No. 2 crossmember to the frame side rails. Install and tighten the attaching bolts.
  32. Install transfer case on 4WD drive models.
  33. Position the engine rear support and insulator assembly above the crossmember. Install the rear support and insulator assembly-to-extension housing mounting bolts and tighten the bolts to 45 ft. lbs. (61 Nm).
  34. Lower the transmission and remove the jack.
  35. Secure the engine rear support and insulator assembly to the crossmember with the attaching bolts and tighten them to 80 ft. lbs. (108 Nm).
  36. The balance of installation is the reverse of removal.
AOD
  2. Raise the vehicle on hoist or stands.
  3. Place the drain pan under the transmission fluid pan. Starting at the rear of the pan and working toward the front, loosen the attaching bolts and allow the fluid to drain. Finally remove all of the pan attaching bolts except two at the front, to allow the fluid to further drain. With fluid drained, install two bolts on the rear side of the pan to temporarily hold it in place.
  4. Remove the converter drain plug access cover from the lower end of the converter.
  5. Remove the converter-to-flywheel attaching nuts. Place a wrench on the crankshaft pulley attaching bolt to turn the converter to gain access to the nuts.
  6. Place a drain pan under the converter to catch the fluid. With the wrench on the crankshaft pulley attaching bolt, turn the converter to gain access to the converter drain plug and remove the plug. After the fluid has been drained, reinstall the plug.
  7. On 2WD drive models, matchmark and disconnect the driveshaft from the rear axle and slide shaft rearward from the transmission. Install a seal installation tool in the extension housing to prevent fluid leakage.
  8. Disconnect the cable from the terminal on the starter motor. Remove the three attaching bolts and remove the starter motor. Disconnect the neutral start switch wires at the plug connector.
  9. Remove the rear mount-to-crossmember attaching bolts and the two crossmember-to-frame attaching bolts.
  10. Remove the two engine rear support-to-extension housing attaching bolts.
  11. Disconnect the TV linkage rod from the transmission TV lever. Disconnect the manual rod from the transmission manual lever at the transmission.
  12. Remove the two bolts securing the bell crank bracket to the converter housing.
  13. On 4WD drive models, remove the transfer case.
  14. Raise the transmission with a transmission jack to provide clearance to remove the crossmember. Remove the rear mount from the crossmember and remove the crossmember from the side supports.
  15. Lower the transmission to gain access to the oil cooler lines.
  16. Disconnect each oil line from the fittings on the transmission.
  17. Disconnect the speedometer cable from the extension housing.
  18. Remove the bolt that secures the transmission fluid filler tube to the cylinder block. Lift the filler tube and the dipstick from the transmission.
  19. Secure the transmission to the jack with the chain.
  20. Remove the converter housing-to-cylinder block attaching bolts.
  21. Carefully move the transmission and converter assembly away from the engine and, at the same time, lower the jack to clear the underside of the vehicle.
  22. Remove the converter and mount the transmission in a holding fixture.
  23. Tighten the converter drain plug. To install:
  24. Position the converter on the transmission, making sure the converter drive flats are fully engaged in the pump gear by rotating the converter.
  25. With the converter properly installed, place the transmission on the jack. Secure the transmission to the jack with a chain.
  26. Rotate the converter until the studs and drain plug are in alignment with the holes in the flywheel.
  27. Move the converter and transmission assembly forward into position, using care not to damage the flywheel and the converter pilot. The converter must rest squarely against the flywheel. This indicates that the converter pilot is not binding in the engine crankshaft.
  28. Install and tighten the converter housing-to-engine attaching bolts to 40-50 ft. lbs. (54-68 Nm).
  29. The balance of installation is the reverse of removal.
Nov 03, 2010 | 1991 Ford F150
When we put in our security system we were conected to a regular phone line, however we've just recently have our tv, computer and phone line tied in on cable. What do I need to do to have my security...
On your cable box it where your regular phone is plugged in, you need to take a regular phone cable and cut it, take that Green and Red wire to the series jack green and red... and take the yellow and black back to a phone jack. now plug your phone in that jack and it should work just fine.
Aug 31, 2010 | GE Security Simon 3 Wireless Home Security...
How do i remove the transmission?
There are 4 different transmissions that go in this car.
The following is the Automatic Overdrive Transmission:
Automatic Overdrive (AOD) Transmission 1983–89 VEHICLES
  2. Raise and safely support the vehicle.
  3. Place a suitable drain pan under the transmission fluid pan. Starting at the rear of the pan and working toward the front, loosen the attaching bolts and allow the fluid to drain. Finally remove all of the pan attaching bolts except two at the front, to allow the fluid to further drain. With fluid drained, install two bolts on the rear side of the pan to temporarily hold it in place.
  4. Remove the converter drain plug access cover from the lower end of the converter housing.
  5. Remove the converter-to-flexplate attaching nuts. place a wrench on the crankshaft pulley attaching bolt to turn the converter to gain access to the nuts.
  6. Place a drain pan under the converter to catch the fluid. With the wrench on the crankshaft pulley attaching bolts, turn the converter to gain access to the converter drain plug and remove the plug. After the fluid has been drained, reinstall the plug.
  7. Scribe a mark indexing the driveshaft to axle flange, disconnect the driveshaft from the rear axle and slide shaft rearward from the transmission. Install a seal installation tool in the extension housing to prevent fluid leakage.
  12. Remove the two bolts securing the bellcrank bracket to the converter housing. Fig. 11: Unfasten the two bellcrank bracket-to-converter housing bolts 88187g28.gif
  13. Raise the transmission with a transmission jack to provide clearance to remove the crossmember. Remove the rear mount from the crossmember and remove the crossmember from the side supports.
  14. Lower the transmission to gain access to the oil cooler lines.
  15. Disconnect each oil line from the fittings on the transmission using Cooler Line Disconnect Tool T86P-77265-AH or equivalent.
  16. Disconnect the speedometer cable from the extension housing.
  17. Remove the bolt that secures the transmission fluid filler tube to the cylinder block. Lift the filler tube and the dipstick from the transmission.
  18. Secure the transmission to the jack with the chain.
  19. Remove the converter housing-to-cylinder block attaching bolts.
  20. Carefully move the transmission and converter assembly away from the engine and, at the same time, lower the jack to clear the underside of the vehicle.
  21. Remove the converter and mount the transmission in Bench Mounted Holding Fixture T57L-500-B, or equivalent holding fixture. To install:
  22. Tighten the converter drain plug to 8–28 ft. lbs. (11–38 Nm).
  23. Position the converter on the transmission, making sure the converter drive flats are fully engaged in the pump gear by rotating the converter.
  24. With the converter properly installed, place the transmission on the jack. Secure the transmission to the jack with a chain.
  25. Rotate the converter until the studs and drain plug are in alignment with the holes in the flexplate. WARNING
    Lubricate the pilot bushing with a suitable chassis grease.
  26. Align the yellow balancing marks on converter and flexplate.
  27. Move the converter and transmission assembly forward into position, using care not to damage the flexplate and the converter pilot. The converter must rest squarely against the flexplate. This indicates that the converter pilot is not binding in the engine crankshaft.
  28. Install and tighten the converter housing-to-engine attaching bolts to 40–50 ft. lbs. (55–68 Nm), making sure that the vacuum tube retaining clips are properly positioned.
  29. Remove the safety chain from around the transmission.
  30. Install a new O-ring on the lower end of the transmission filler tube. Insert the tube in the transmission case and secure the tube to the engine with the attaching bolts.
  31. Connect the speedometer cable to the extension housing.
  32. Connect the oil cooler lines to the right side of the transmission case. Tighten the lines to 24–31 Nm).
  33. Position the crossmember on the side supports. Position the rear mount on the crossmember and install the attaching bolt and nut.
  34. Secure the engine rear support to the extension housing and tighten the bolts to 35–40 ft. lbs. (47–54 Nm).
  35. Lower the transmission and remove the jack.
  36. Secure the crossmember to the side supports with the attaching bolts and tighten them to 70–100 ft. lbs. (95–136 Nm).
  37. Position the bellcrank to the converter housing and install the two attaching bolts.
  38. Connect the TV linkage rod to the transmission TV lever. Connect the manual linkage rod to the manual lever at the transmission.
  39. Secure the converter-to-flexplate attaching nuts and tighten them to 20–30 ft. lbs. (27–41 Nm).
  40. Install the converter housing access cover and secure it with the attaching bolts.
  41. Secure the starter motor in place with the attaching bolts. Connect the cable to the terminal on the starter. Connect the neutral start switch wires at the plug connector.
  42. Align the scribe marks and connect the driveshaft to the rear axle.
  43. Adjust the shift linkage as required.
  44. Adjust the throttle linkage.
  45. Carefully lower the vehicle, then connect the negative battery cable.
  46. Fill the transmission to the correct level with Mercon® or equivalent fluid. Start the engine and shift the transmission to all ranges, then recheck the fluid level.
Jul 22, 2010 | 1989 Ford Thunderbird
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
I need to repair internal wires
Typically you have to unstring the guitar to get access to the insides.
Use a small miirror to view the insides. You may need to drag the jack out of the sound hole to resolder wires if they are broken. There should be three wires on the jack. One carries the audio, one the ground, and the third connects the battery when the instrument cable is plugged in.
After re-soldering the connections if needed, procure a piece of 1/4 inch wood dowel from your hardware store. Push the dowel through the hole where the jack goes and near the sound hole. Push the jack onto the dowel and then pull it back through the jack hole and pass the nut over the dowel and onto the jack threads and tighten. The extract the dowel rod from the jack.
It is near impossible to reach clear into the guitar body to put the jack back in without the dowel rod unless you have very tiny arms.
Feb 09, 2010 | CF Martin Music
How do you get the external linkage arm off an aod transmission. The tranny I am replacing tthe arm sticks up. The one I am putting back in the control arm sticks down below the pan. Do I have to take...
Just guessing that you have a 5.0 but if not, please let me know....this is for an AOD Tranny removal for an 88 Mustang 5.0L:
  1. Raise and safely support the vehicle.
  2. Place the drain pan under the transmission fluid pan. Starting at the rear of the pan and working toward the front, loosen the attaching bolts and allow the fluid to drain. Finally, remove all of the pan attaching bolts except two at the front, to allow the fluid to further drain. With the fluid drained, install two bolts on the rear side of the pan to temporarily hold it in place.
  3. Remove the converter drain plug access cover from the lower end of the converter housing.
  4. Remove the converter–to–flywheel attaching nuts. place a wrench on the crankshaft pulley attaching bolt to turn the converter to gain access to the nuts.
  5. Place a drain pan under the converter to catch the fluid. With the wrench on the crankshaft pulley attaching bolts, turn the converter to gain access to the converter drain plug and remove the plug. After the fluid has been drained, reinstall the plug.
  6. Disconnect the driveshaft from the rear axle and slide shaft rearward from the transmission. Install a seal installation tool in the extension housing to prevent fluid leakage.
  7. Disconnect the cable from the terminal on the starter motor. Remove the three attaching bolts and remove the starter motor. Disconnect the neutral start switch wires at the plug connector.
  8. Remove the rear mount–to–crossmember attaching bolts and the two crossmember–to–frame attaching bolts.
  9. Remove the two engine rear support–to–extension housing attaching bolts.
  10. Disconnect the TV linkage rod from the transmission TV lever. Disconnect the manual rod from the transmission manual lever at the transmission.
  11. Remove the two bolts securing the bellcrank bracket to the converter housing.
  12. Raise the transmission with a transmission jack to provide clearance to remove the crossmember. Remove the rear mount from the crossmember and remove the crossmember from the side supports.
  13. Lower the transmission to gain access to the oil cooler lines.
  14. Disconnect each oil line from the fittings on the transmission.
  15. Disconnect the speedometer cable from the extension housing.
  16. Remove the bolt that secures the transmission fluid filler tube to the cylinder block. Lift the filler tube and the dipstick from the transmission.
  17. Secure the transmission to the jack with the chain.
  18. Remove the converter housing–to–cylinder block attaching bolts.
  19. Carefully move the transmission and converter assembly away from the engine and, at the same time, lower the jack to clear the underside of the vehicle.
  20. Remove the converter and mount the transmission in a holding fixture. To install:
  21. Tighten the converter drain plug to 20–28 ft. lbs. (27–38 Nm).
  22. Position the converter on the transmission, making sure the converter drive flats are fully engaged in the pump gear by rotating the converter.
  23. With the converter properly installed, place the transmission on the jack. Secure the transmission to the jack with a chain.
  24. Rotate the converter until the studs and drain plug are in alignment with the holes in the flywheel. NOTE: Be sure to lubricate the pilot bushing.
  25. Align the yellow balancing marks on converter and flywheel on models with the 8–302 engine.
  26. Move the converter and transmission assembly forward into position, using care not to damage the flywheel and the converter pilot. The converter must rest squarely against the flywheel. This indicates that the converter pilot is not binding in the engine crankshaft.
  27. Install and tighten the converter housing–to–engine attaching bolts to 40–50 ft. lbs. (54–67 Nm). Make sure that the vacuum tube retaining clips are properly positioned.
  28. Remove the safety chain from around the transmission.
  29. Install a new O–ring on the lower end of the transmission filler tube. Insert the tube in the transmission case and secure the tube to the engine with the attaching bolts.
  30. Connect the speedometer cable to the extension housing.
  31. Connect the oil cooler lines to the right side of the transmission case.
  32. Position the crossmember on the side supports. Position the rear mount on the crossmember and install the attaching bolt and nut.
  33. Secure the engine rear support to the extension housing and tighten the bolts to 35–40 ft. lbs. (47–54 Nm).
  35. Secure the crossmember to the side supports with the attaching bolts and tighten them to 35–40 ft. lbs. (47–54 Nm).
  36. Position the bellcrank to the converter housing and install the two attaching bolts.
  37. Connect the TV linkage rod to the transmission TV lever. Connect the manual linkage rod to the manual lever at the transmission.
  38. Secure the converter–to–flywheel attaching nuts and tighten them to 20–30 ft. lbs. (27–40 Nm).
  39. Install the converter housing access cover and secure it with the attaching bolts.
  40. Secure the starter motor in place with the attaching bolts. Connect the cable to the terminal on the starter. Connect the neutral start switch wires at the plug connector.
  41. Connect the driveshaft to the rear axle.
  42. Adjust the shift linkage as required.
  43. Adjust throttle linkage.
  44. Lower the vehicle.
  45. Fill the transmission to the correct level with Dexron® II or Mercon® fluid. Start the engine and shift the transmission to all ranges, then recheck the fluid level.
May 14, 2009 | 1988 Ford Mustang
Confused about Connections
Bob, you can do this, grab 3 rca cables, 1 yellow 1 red 1 white.
the holes on the back of the dvd are colored coded, you guessed it yellow ,red, white, plug the cables into the matching colored holes, your done with the dvd player, now take the other end of these 3 cables and guess what the plugs on the back of the tv are the same color code as well, take a flashlight and find the 3 colored holes marked " input 1" stick the yelloe cable in the yellow hole , red in red hole, white in white hole, turn on dvd player & tv, grab your remote for the tv and find the input button and push it until the screen show "vid1" or "video 1", input 1 what ever yours says and you`ll be watching your dvds. Good Luck & Happy Holidays, BMW Rider
Dec 01, 2007 | Hitachi 57F500 57" Rear Projection...
Dc jack
The PCG-K37 (Sony VAIO Laptop) uses a DC Jack soldered to a two-wire jacketed (shielding) cable that is routed under the DVD (tray) and towards the back to the Voltage Board located under the Touch Pad (Mouse) via a white polarized plug. The wires are color-coded Red (+) and Black (-); a third black wire is NOT attached to the DC Plug, but is used as a grounding wire for the Voltage Board to the LCD Hinge MOUNT only. Remove the battery and DC plug (AC Adaptor Wire) from the laptop first, before going any further.) To access the DC Plug requires removing the Keyboard Hood (houses the stereo speakers & power button) carefully by prying up from where the F-Keys (top row) are. There are four (4) slots: above the "Delete Key," and "F10" and "F4" and "ESC Key," and you will have to press these keys to see the pry slots for a thin blade screw driver to fit. The "Hood" pops up gently and is connected by a thin strip "Wire Cable" through the aluminum keyboard shield down to the motherboard. The "Wire Strip" cable is held in place on the Power Button Board by a sliding pressure retainer (Tan in Color) - it slides away (approx 1/8 of an inch) from the circuit board to let go of the cable. (To re-attach: make sure the retainer clip (Tan in Color) is up before sliding in the wire cable strip and push the retainer back in by applying pressure on both ends to seat it.) With the Keyboard Hood out of the way; remove the keyboard (3 screws only) and set the screws aside. The keyboard swings toward you and the wire connector cable for the keyboard is attached to the motherboard the same way the Hood is connected - a larger pressure retainer clip. With the keyboard out of the way; the aluminum shield must be removed. There are ten (10) screws holding this shield down, so please note which "length" screw goes where is should because putting the longer screw in the wrong place may damage something when it bottoms out. Next is removing the laptop Palm Rest (it contains the touch pad) and there are two screws easily missed near the touch pad on top; the rest of the screws are accessable when you close the lid (LCD) and flip the laptop up-side-down. Unscrew each screw one at a time and flip the laptop over to drop out each screw individually to catch them in your hand. Look for the tiny arrows to locate the screws and don't forget to lift up the battery door to get to the two (2) tiny screws, too. There should be a total of thirteen (13) of these screws and again please note the difference in lengths and where they go. Once you have all screws accounted for; set the laptop right-side-up and lift open the lid (LCD) carefully because the latch catch is hooked. (Slide the latch hook to open.) With the Lid open, you will see a thinner wire cable (white) attached to another pressure clip - it's the touch pad cable attached to the Voltage Board; release it just like you did with the keyboard cable and you can start lifting the Palm Rest up and away from the laptop case to expose the motherboard. At this point, you can see the DC Jack in the back right side corner. To get more room to manuver around, you may remove the DVD by opening the Hard Drive Bay Door and removing the two (2) tiny, short screws near the bottom of the hard drive (no need to remove the HD). The DVD slides out. Looking again on top of the motherboard, you will see a glide rail for the DVD and a metal shield covering the DC cable; remove the screws carefully and note the lengths again for proper placement. The next trick is to only move one LCD hinge out of the way, so it is important to secure the LCD in a way so that the one remaining hinge is NOT DAMAGED during this repair process. There are three (3) screws holding the hinge to the laptop case and that third screw in in the back of the laptop between the DC Jack and the modem's phone (RJ-11) jack. There is a hold-down bracket to secure the modem jack and the DC Jack; only one screw keeps it there. After getting the hold-down bracket out of the way; the DC Jack slides up and out. Remember how the DC Jack was positioned because putting it back in up-side-down makes it hard to plug the AC Adaptor in for laptop use on AC power. Use heat-shrink tubing and your insulators and avoid using electrical tape after soldering the two wires onto the new DC Jack. Also remember that the RED WIRE is soldered to the Center Post connector. Reverse the disassembly listed above to re-assemble. If you think this was tough, now you know why Technicians charge a minimum of $99 to do this job. But at least you now know that the DC Jack is NOT attached to the motherboard and the motherboard does not require complete removal just to get to the worn-out DC Jack. And YES!; DC Jack do wear out because the Adaptor plug is pulled on sooooo many times that the DC Jack take the abuse more than the plug does; and that's because there is more stability built into the plug than the DC Jack. One additional note: the Keyboard Hood connector cable is usually the first thing people damage accidently by folding the crease too many times. Wires inside this "tape" will break just like bending and twisting solid thicker wires will break. The replacement part is found on the Sony Parts Website for about $10 plus S&H. You will know you need it replaced when you can not seem to keep the laptop "ON" or the HD & Power lights fail to glow or you still can not get power to recharge the battery. The circuits for these functions run through that flat tape wire cable to the Keyboard Hood. Good Luck! (I say that because it will take up your entire evening, take up your entire dining room table, and wear thin the nerves of your spouse who will be very concerned about that table you are using to venture on!) Oh, and one more thing... Unplug the telephone as distractions should be avoided until you finish putting everything back together (or you WILL forget things).
Nov 15, 2007 | Sony PCGK37 Notebook
RCA F27645 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
