Question about Dymo LabelWriter XL Plus Thermal Printer
Dymo labelwriter xl, or xl plus and Windows 7
I need to make a Dymo labelwriter xl, or xl plus (serial port hookup) work with windows 7. I need drivers.
SOURCE: Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Posted on Apr 28, 2008
SOURCE: New labelwriter 400 turbo will not print under windows 2000
I had the same problem and accidently discover it was something very simple...at least in my case. I noticed the power cord connection was very good.. I notice the light on the transformer (cord) was sometimes green then it would go out. When I unplugged and then put some force into reconnecting the printer worked. Hope that helps.
Posted on Oct 06, 2008
SOURCE: OUR DYMO LABELWRITER TWIN TURBO JUST STOPPED PRINTING--
OK! The first time you tried to print ON THE LEFT SIDE, without anymore labels there, there was a "pending" error message in the print queue. This typically cuts off all furtther printing, as all subsequent requests are "behind" it in order or priority.
To fix this, open the Dymo Labelwriter "Printer" dialog box (double-click it on the tray or go to "start / control panel / printer and faxes" - then double-click on "DYMO LabelWriter Twin Turbo". Once open, you'll see a list of "failed" print requests. Somewhere in there you'll find the one with the "laserwriter output" out of paper message. Select that and cancel or delete it.
If this was the problem, all your attempts will now print (make sure you have enough postage paper in, and you'll have extras you can use, I'm sure!
Hope this helps.
Posted on Jul 09, 2009
  • 4 Answers
SOURCE: dymo 400 labelwriter does not print unless shut down and rebooted
It could be how you have loaded the labels. If you have loaded the labels and there is a small gap between the spindle and the roll, it will print one label and give a error-printer message and stop working until you unplug it for 30 seconds and plug it back in. I would reload the labels from scratch and ensure there is no gap.
Posted on Aug 06, 2009
My Dyno Labelmaker 400 Turbo will not work with DYMO Labelwriter 400 Turbo. Am using Mac Mavericks 10.9.3!
that same printer will not work with Windows 7 either, I think it is time to get a new printer. Dymo is not coming out with new drivers, they want you to buy a new printer.
Jun 05, 2014 | Dymo Labelwriter 400 Turbo Printer
Windows vista and dymo labelwriter 450
Here is how to upgrade the software:
1. disconnect the printer and make sure you log in as an administrator. If you need to, back up your contacts: Address Book > Export;
2. uninstall everything that says DYMO (Start > Control Panel > Uninstall) and re-start the computer (back up whatever should be saved);
3. install the latest Windows updates;
4. install DYMO Label 8.5.0: see the download link below(I suggest right-clicking the downloaded file and running it as administrator);
5. connect the printer directly to the computer only when prompted;
7. only use DYMO-made rolls - black stripes on the back, the logo and article number should be there.
tinyurl.com/dymolabel850pc
Also, please go to Start > Devices and printers > right-click the printer > Printer properties > Ports > clear Enable bidirectional support > OK.
^CM
Jan 07, 2013 | Dymo ® LabelWriter® 450 Series PC...
Dymo labelwriter turbo model 90479 driver
You can download the Windows 7 Driver here:
http://www.dymo-label-printers.co.uk/dymo-labelwriter-drivers-windows-7.html
Note: you don't say if it is a 300/400/450 series, but if it's a 300 series and the model is NOT listed in the compatible printers on that page then there is NO SOLUTION - your printer simply will not work with Windows 7 as Microsoft dropped support for the old USB chipset in this OS...
ps. there is a server problem at the moment so if you can't download 8.4 try 8.3 it will still work just fine.
Apr 11, 2012 | Dymo LabelWriter Office Equipment &...
Hi i have dymo labelwriter twin turbo, and this runs with windows xp, but i have windovs vista. What can i do?
I think you can have a look at this site
https://global.dymo.com/enCA/RNW/RNW.html?pg=std_adp.php&p_faqid=101
This support site should contain driver and software for Dymo Labelwriter running on Windows 7 also.
May 24, 2011 | Dymo LabelWriter Thermal Printer
We just changed to Windows 7 and the Dymo Label Writer 400 will not work - is there a download or some kind of fix to hook it into Windows 7 Thank you. Lori
Visti this link:
http://sites.dymo.com/Search/Pages/SupportSearchResults.aspx?k=Labelwriter 400
You probably need an update driver for your Labelwriter. You will need to determine if you are using Windows 7 64 bit or 32 bit. You can contact Dymo to ask for further information.
May 17, 2011 | Dymo LabelWriter 400 Thermal Printer
Windows 7 compatibility, do you support this?
Here is the link for the driver Dymo LabelWriter 310 Printer for windows 7. All you have to do is just download the software and install and plug your Dymo LabelWriter 310 Printer so that it will detect and installed to your system. Have a nice day!
Feb 26, 2011 | Dymo LabelWriter 310 Printer
Need printer driver for windows 7
Hi, David. I had the same problem, and there is a solution. There isn't a driver for Windows 7, but under Windows 7 you can install a virtual machine, that runs a fully licensed copy of XP on your machine. You can download this from Microsoft. Once you have installed a virtual XP machine (and it's not hard at all to do - maybe 10 minutes), you can load the DYMO software and drivers for XP, and your LabelWriter EL60 will work just fine.
Regards,
- Jim
Dec 16, 2009 | Dymo LabelWriter EL60 Thermal Printer
Trying to set uo dymo labelwriter 400 on windows vista
Quite a lot of the early LW400's didn't ship with the Vista driver/software. You can download the correct Vista driver from here:
http://www.dymo-label-printers.co.uk/Dymo-LabelWriter-Vista-driver.html
Oct 14, 2008 | Dymo LabelWriter 400 Thermal Printer
Error: Will not print
Hello Sir,
To check the printer settings in Windows 95/98/2000
1. On the Windows task bar click the Start button, point to Settings, then click Printers.
The Printers window is displayed.
2. Right-click the EL40 or EL60 or EL Turbo icon and select Properties in the shortcut menu.
The Properties dialogue box is displayed.
3. Click the Details tab, then click the Port Settings button.
The Port Settings dialogue box is displayed.
4. Verify the following settings:
Bits per second: 19,200 (for EL40, EL60, XL, XL+) / 115,200 (for EL Turbo, XL Turbo, 330 Turbo)
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Xon/Xoff (for EL40, EL60, XL, XL+) / Hardware (for EL Turbo, XL Turbo, 330 Turbo)
5. Click OK to close the Port Settings and Properties dialogue boxes.
6. Click the Close button in the upper-right corner.
The Printers window is closed.
To check the printer settings in Windows NT
3. Click the Ports tab, then click the Configure Port button.
Select the COM port and click the Settings button.
Bits per second: 19,200 (for EL40, EL60, XL, XL+) / 115,200 (for EL Turbo, XL Turbo)
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Xon/Xoff (for EL40, EL60, XL, XL+) / Hardware (for EL Turbo, XL Turbo)
7. Click OK .
Thanks
Good Luck
Don't forget to comment
Cheers!!!!
Feb 20, 2008 | Dymo LabelWriter 320 Thermal Printer
Dymo LabelWriter XL Plus Thermal Printer Logo
567 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
