Magnavox Plasma Model # 42MF231D/37 S/N AE1C0628000383 ....Has sound, No visible video or OSD; and no sign of backlight..... Visible inspection showed no signs of degraded electrolytics on any of the power supplies. I am suspecting a panel problem??????
  • ZNREL Jul 30, 2010
    I'll know after I purchase CBA's and Install them, as far as results.
    ZNREL
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. I hope you have already checked the X and Y sustain buffer boards as well while checking any swollen/bulged capacitors on these boards. I’ll suggest you to check the power supply board and replace it if it has gone bad. Also check the controller board which is the board located next to the power supply unit. As there is no picture so it can only be an issue with one of these boards or a component that has gone bad. All this is only recommended if you have electrical expertise and know how to solder/re-solder components as these units contain high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 29, 2010
  • ZNREL Jul 29, 2010
    I have allready checked all the CBA's for visibly bad caps. None found. Where there were voltages listed alongside the connectors, I checked for these voltages and what I could check seemed OK. Its been a couple of weeks now since I was inside this TV. And unfortunately I never made notes on which connectors and what voltages I checked.
  • Rylee Smith
    Rylee Smith Jul 30, 2010
    Then check the control board the one next to the power supply unit and Y-main and the buffer boards. You'll have to replace whichever has gone bad as the sound is working so it seems to be either of these boards.
Have sound but no picture
If its not under warranty, pull the back cover and check the capacitors on the power supply. If there are any that are bulging or show signs of fluid leakage, replace them. If that doesn't fix your no picture but sound issue then you have a bigger problem. You can do it yourself pretty cheap and its not that hard. Just make sure you use the proper replacement capacitors.
But if otherwise
You most likely have a backlight issue with this TV set. Could be the inverter circuits for the backlights. The inverter is the power supply source for the backlights. there could also be a screen driver problem. This would entail changing the entire board.
Hope this help...
Jun 26, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
Magnavox plasma television will not turn on, makes
Relays clicking noise you hear.....change caps..you might see visible signs of CAPs being bad....swolen,,, top ready to explode etc.
May 19, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
I have a magnavox 42mf231d / 37 it turns on
Hi tt3nry,
Unfortunately the answer isn't a simple one on that set. Just about every board in that set can have a problem that causes it to shut down. The cheaper way out this will be a trip to the shop as opposed to you buying all the boards from a distributor and doing it yourself. A small, local shop will charge you a FAIR price and do it right for you. Plus, most distributors DO NOT WARRANT parts if you are not a professional technician.
Ask friends where they have had work done or call the local chamber of commerce. They can point you in the right direction as well. Avoid the great big places. More than a few techs means more overhead and higher prices.
Good luck.
Apr 21, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
Magnavox plasma tv model 42mf230a/37 sound but ni
Replace lower scan converter PCB, which plugged into Y-Sustainer Board, located to the left of the display if you poke back cover open. There are 2 of them, but in some models might be the one, long PCB.don't wait to fix it! otherwise, you will knock out Y-
Sustainer and upper scan converter. That will cause you to spend few hundreds to fix it.
Good luck,
Alex's TV Service,
Philadelphia,
Pa, 215-806-5980.
Jan 21, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
No video but i have sound what board should i need to replace?
If your power light is coming on and you can hear sound.It should be your inverter.The inverter works like the starter in a florescent light bulb.Your backlight isn't coming on. Try ebay by typing inverter and your model number in their search.
Nov 15, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
42'' Magnavox 42MF231D/17 with picture/sound problem
Hi my name is Roety,
I can help you with your issue ,
Sounds like a bad SSB small signal board
login as a guest and check price and availability at
encompass.com
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 31, 2009 | Philips Magnavox 42MF521D/37 Television
Magnavox 42MF231D/37 screen went white then black
Alot of times i have noticed that when i have worked on these, it has been the Backlight Inverter. 32 inch televisions had same problem as the 42 inch
Oct 18, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Magnavox 42MF231D/17, screen just turned black,
power supply or inverter board failing if the power board is the problem it will have blown caps
little cans with puffy tops because the caps have vented if you don't see that then your inverter has died that model id out of production so try shop jimmy. com
Sep 22, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Magnavox 42mf231d/37 - no picture
Common problem on this tv, ceramic capacitor beside horizontal transistor.Need be Replace . 561K 2KV
Aug 06, 2009 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
