Samsung as18aorcd/kcv unit will not run all lights are flashing
Why is my samsung printer saying prepare new image unit?
Imaging unit has a cerain page life and printer has finished those pages and is warning u to arrange for the same.
Aug 19, 2014 | SAMSUNG CLX-3185FW COL LASER MFC Projector...
I have a Samsung CLP-310 and I've mislaid the units manual. On the top of the unit down on the bottom right hand corner there are four (4) colour icons a yellow, red, blue and a grey, all which light up...
Here is the link to the manual, it says that the flashing light is PROBABLY caused by lack of toner and the first step is to replace/replenish the corresponding flashing light to the toner. It explains that when the light turns stys on all the time the toner will be empty.
With regards to the paper jamming, there is 3 pages on things to do or try.
I hope this gives you a few ideas
http://www.samsung.com/uk/function/search/espsearchResult.do?keywords=Samsung+CLP-310&input_keyword=Samsung+CLP-310
Nov 30, 2010 | Samsung CLP 300 Laser Printer
Blinking Nature Indicator Light
air conditioner will run fine and then shut off. When it does this the nature indicator light on the unit begins flashing If I attempt to turn it back on the fan revs up and then shuts off 15seconds later. I'm not sure what it's trying to convey with theblinking light but when the AC shuts off...
Jun 14, 2010 | Samsung AS18A6RB Air Conditioner
Samsung air conditioner light flashes and switches off by itself
It could be the temperature sensor. It is the short , usually black wire that runs across the front of the air handler. Unplug it, and check it with a meter set to ohms. If it reads a value it is good. If you get nothing it is shorted, and needs to be replaced. If it reads good, you may need to replace the main board on the handler.
GOOD LUCK WITH THE REPAIR
Mar 10, 2010 | Samsung Heating & Cooling
Indoor unit freezing up
THE OUTDOOR UNIT HAS A CONTACTOR WITH THE CONTACTS WELDED TOGETHER THE CONTACTOR CONNECTS TO THE COMPRESSOR AS IT TYPICALLY PULLS A SURGE OF 20 -30 AMPS OR MORE..WITH THE INDOOR UNIT IN FAN ONLY THE COMPRESSOR SHOULD NOT BE RUNNING. THE CONTROL WIRES GOING TO THE UNIT HAVE 24 VOLTS TO THE CONTACTOR TO PULL IN THE CONTACTS TO SUPPLY 220 TO COMPRESSOR.
Mar 09, 2010 | Heating & Cooling
Freezer light flashing
if you have ice built up on rear wall of freezer section then your unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow over to the fresh food side.
Jun 24, 2009 | Samsung RS2630SH Side by Side Refrigerator
My new TV keeps turning off and then on again with flashing red and green lights in front.
Check your warranty for the unit. Then call Samsung to see I they can help.
800-243-0000 Customer Support
If no help there repost with model # of the unit.
May 15, 2009 | Televison & Video
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
