Question about Husqvarna Designer I
I bought a seam binding foot for my Designer 1 and have no instructions. I have tried to use it but can't seem to get it to work. Could somebody instruct me please
  • 201 Answers
Not sure just what foot you have. Was it a genuine HV foot or a generic brand? Could you describe in more detail what the foot looks like and what it is supposed to do. There are lots of videos on YouTube showing how various feet work and you might find what you need there.
Posted on Aug 11, 2010
What foot and setting do I need to sew strips of bias binding together.
If you are sewing bias strips end to end, any foot would work. A 1/4" seam allowance is probably fine. You'll probably just need to cut the ends @ 45 degree angles and match them up before stitching. Sewing them at 90 degree angles creates a big bulk of fabric whereas 45 degree angles spread the bulk out when applied to your cushion fabric.
Learn How to Join the Ends When Quilt Binding Tips from McCall Quilting
Mar 16, 2017 | Sewing Machines
What size needle required for sewing Velvet curtains??
What kind of velvet? Poly-based fabrics often require ball-point needles to avoid pulls. For apparel weight velvet (something I'd make a skirt with), I'd probably use at least an 90, possibly heavier. For really heavy, upholstery-weight, I'd use my walking-foot machine and a 100-110 (often used for jeans). But I'm sure I'd want to bind all of the seams on my serger, I often bind after sewing the regular seams, but for very heavy fabrics I'd bind first (just run up all of the edges of each piece before sewing seams).
Hope this helps.
Apr 06, 2015 | Janome Memory Craft 4900QC Mechanical...
Designer 1 foot pedal won't work
Have you tried using another Designer 1 foot control? It is more likely that the problem is a loose connection at the machine. Do not cut anything apart on the foot control unless you are certain that is where the problem lies.Take the machine in to an authorized dealer and have them test it for you. Find out EXACTLY what is not working. No need to buy a foot control and find out that the connectors on the machine are not properly attached.
Dec 29, 2011 | Husqvarna Sewing Machines
The machine will not back up. Or cut the thread when a seam is fi
If the presser foot is down when you initiate these features of the machine, I needs to go in for service.
Feb 25, 2010 | Husqvarna Sewing Machines
I have a designer 1 that won't release the bobbin.
Winding too tight;
Whenever your bobbin won’t come off any Viking, Designer 1 included, it’s because it wound too tight. This is how you know. It went on easy! To get it off, don’t pry, slowly unwind all thread, it will change shapes and let go of the bobbin winder. My favorite way to wind a bobbin on a Viking is to thread the machine through the needle and go under the foot then up to the bobbin winder (it has to be under the foot or it winds too tight. If it still winds too tight, lay your thread down instead of standing it up, the weight of the thread can increase tension on the winding process also check that you use a spool cap as large as or slightly larger than your spool. If it still winds tight. I’ll explain what bad thread can do.
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test (tip: always check your thread this way when you thread your machine)
Mar 12, 2009 | Husqvarna Designer I
Designer 1 touch screen freezes
Static Electricity and Designer 1:
The designer 1 is susceptible to static electricity. They sell static removers for electronics. Try that 1st. Don’t spray your machine, just the rag and wipe the machine. Endust for electronics makes a pump spray and you can even use it on the screen (DONT spray the screen). Then try to recalibrate the screen in the set menu. If you can’t get into the set menu keep trying until you can otherwise, there is a way to get into the service mode to set it.
Feb 25, 2009 | Husqvarna Designer I
Designer 1 reverse won't select, no light at all
The designer 1 has a weakness of the reverse pad (rubber button set) on left side of the machine wearing out and not working. You can try pushing from different angle, or pushing hard, but it most likely needs to be replaced. If you did buttonholes with the buttonhole sesor foot (foot with a wheel and a cord that plugs in), it would automatically size the buttonhole and you wouldn't need to reverse and you can use "FIX" to tie a knot instead of reverse
Dec 30, 2008 | Husqvarna Viking 1
Presser foot wont raise and lower
Does the presser foot move at all when the machine is first turned on?
Do the needle and feed teeth calibrate when the machine is first turned on?
You probably need to locate your nearest authorized repair center.
May 05, 2008 | Husqvarna Designer I
Q foot for Designer 1 machine
Check Janice Henning's site sewmuch4retirement.com...look under Tips, Designer 1 Tips, Item 1 (which is at the bottom of the list).  Jan has easy instructions and a nice photo.
Feb 29, 2008 | Husqvarna Designer I
Sewing Machines Logo
46 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
