Question about 3Com WL ROUTER 3COM|3CRWER100-75 54M RTL Wireless
3com Wireless router, 3CRWER100-75: cannot log into. The reset to factory default procedure does not work. I don't know the password that was set by the user. Its stuck on 192.168.0.1 and asking for password. Holding in the reset button does not reset to 192.168.1.1 and password does not change to admin. Any solutions?
informatica
  • 1114 Answers
SOURCE: DI-624 can't login as admin
Try connecting directly to the router with a cable as if there is a problem with the wireless connection then you won't be able to connect. If you are already connected directly then reset the unit to it's factory defaults: Locate the Reset button on the back of the DI-624 (through a small hole next to the power cable). Use a paper clip to press the Reset button Hold for about 10 seconds and then release. After the DI-624 reboots (this may take a few minutes) it will be reset to the factory Default settings. Now try to login again directly via a cable.
Posted on Aug 08, 2007
steve_e_uk
  • 1675 Answers
SOURCE: LOOKING for 3Com OfficeConnect Wireless Router
hi normally after a reset the user name is normally, (admin), and the password is normally (password)....hope this helps
Posted on Apr 13, 2010
SOURCE: I have a 3com 3CRWER100-75
Same problem... anyone?
Posted on Sep 27, 2010
PCTechOnline
  • 532 Answers
SOURCE: I am the owner of Trendnet TEW634GRU. I have a
make sure you have reset the router first.
It sounds like the password was changed (as it should be)
The reset will put it back to factory specs and you will start fresh with all the settings.
Posted on Dec 24, 2010
Keynan
  • 977 Answers
SOURCE: Hi all and thanks in advance. I have a
Hi!
From reading all your replies, it seems that one thing you've done wrong:
unchecked SSID broadcast
If the SSID is not broadcasted, it will not appear in the networks list on your computer. Turn it back on (check the chechbox) - and you should be able to see it!
The link you've posted seems to deal with another issue, but it made me think that maybe the "3com 2" is a totally different network - maybe of a neighbor...
With that said, I couldn't understand if the encryption/duplication issue is solved... Are there still 2 similar SSIDs, after you've changed yours?
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Posted on Feb 07, 2011
How do I recover a forgotten password for an overdrivepro63E wireless internet stick
Wireless networking is a common feature in homes and offices.
Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network.
If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu.
Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable.
Open your Web browser. Enter the default address of your router.
The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Enter your username and password.
Many routers use "admin" for the username and password by default.
Locate the wireless security settings.
Disable the wireless security.
Reset to Factory Defaults
Locate the reset button on your router.
Typically the reset button is a small indented hole on the back of the device.
Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings.
Locate the wireless security settings and add security as necessary.
Nov 05, 2013 | Computers & Internet
How do I reset my password?
Step 1:
Wireless networking is a common feature in homes and offices. Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network. If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu. Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable. Open your Web browser. Enter the default address of your router. The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1." Enter your username and password. Many routers use "admin" for the username and password by default. Locate the wireless security settings. Disable the wireless security. Reset to Factory Defaults Locate the reset button on your router. Typically the reset button is a small indented hole on the back of the device. Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings. Open your Web browser. Enter the default address of your router. The default address is listed in your user manual or on the product website. Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1." Enter your username and password. Many routers use "admin" for the username and password by default. Locate the wireless security settings and add security as necessary.
Feb 27, 2013 | Computers & Internet
How to reset netgear wgr614 to factory default
You can reset your Netgear router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings. For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Get instant Netgear router
support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router problem.
Jul 26, 2012 | NetGear WGR614 Wireless Router
3com AP 7250 - how do i reset it to factory defaults if i don't have the admin password ?
It will have a reset button on it, hold it down for ten seconds and it should reset the router to factory.
Mar 12, 2012 | 3Com Wireless LAN Access Point 7250...
I need to change the network name and password
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings. From the center screen, select your encryption type from under the Security Options heading If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router: Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Hope this helps don
Feb 21, 2011 | NetGear Computers & Internet
Tryint to reset my wireless router to default settings. Can you help me?
The router's admin page is http://192.168.1.1 or http://192.168.0.1 and the default password should be either "admin" or "password" without quotes. There should be a choice under "Setup" called "Factory Reset". That will erase the settings and reset it like new.
Alternatively, you can follow the procedure as given below on all the brands I've tried (Belkin, D-Link, Linksys)
1. hold the reset button for 30 seconds (don't release)
2. unplug the power (still holding reset) for 10 seconds
3. plug power back in (still holding reset)
4. hold reset for another 30 seconds - the lights will usually begin flashing in some odd pattern
5. release the reset button
6. wait 1 full minute or until the lights stop flashing
7. unplug the power for 10 seconds, just to do a reboot
8. verify the settings (e.g. SSID) are back to the defaults
Get online router/wireless router support at http://www.vtechsquad.com/linksys-router-support/ to fix Linksys router/wireless router issues.
Dec 21, 2009 | Linksys WRT160N Wireless Router
Default factory pass fails while cannot be reset
There should be a reset button on the back of the router. Once you locate it press it in and hold it down for a few minutes to reset the router to factory default. Then try logging into it.
Nov 22, 2009 | D-Link DVG-G1402S Wireless Router...
Hot to reset the seting to default
Get instant online Netgear router
Get help for recover your lost wireless router password >>
May 12, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Forgot security password
Save slight model differences between the different OfficeConnect routers, the procedure to do a factory reset is like this (from memory, for exact details you have to find a manual)
- power off the unit and remove all cables
- connect a normal (straight) network cable between the WAN port and either of the four LAN ports
- power on and wait until the status led is beginning to blink slowly, like 30 seconds
- then power off, reconnect everything and power on again
After this procedure you will have to input all settings from the very beginning, the default password is admin if I recollect correctly.
Jun 06, 2008 | 3Com OfficeConnect Wireless Router
Factory Default Reset Procedure
Hold the reset button in for 10-15 seconds... Now its defaulted back to factory and the user name and pass will both be admin
May 07, 2008 | Linksys Wireless-G Broadband Router
3Com WL ROUTER 3COM|3CRWER100-75 54M RTL Wireless Logo
1,015 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
john smith
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
