Question about Husqvarna 7021 21Inch 160cc Honda GCV Gas Powered Lawn Mower ()
Lawn mower husqvarna problem
I left gasoline in the tank for 12 monts in my Husqvarna 7021 21Inch 160cc Honda GCV Gas Powered Lawn Mower now i cat make it start
I have an XT721F self-propelled, auto choke Husqvarna mower. The first time I used it this season it ran for a short time and then just quit on me. I have since emptied out all of the gas and have replaced it with high octane 91, and have also added Seafoam to clean out any other issues. I mowed two weeks ago with no problems and went to mow again today and only made it through 2/3 of my back yard and the mower stalled out on me again. What's going on?
Posted on Jun 28, 2011
  • 755 Answers
Your carb is most likely plugged from the fuel attracting moisture and turning to gel. The problem is all the newer fuels with added alcohol were never meant for lawn equipment.
You can try taking the bowl off the carb and cleaning the bowl interior the float and the main jet. Which should be up inside the bottom of the bowl. *(I think you need a hollow ground flat blade screwdriver to extract the jet) Take a soft wire brush to the jet to clean it and look at all the holes in it. Are they plugged? Cant see daylight through them? Get a small piece of fine wire strand and clean the holes out! Put her back together and run some fresh fuel through it.
Good luck and be careful!
Posted on Jul 29, 2010
Have fire coming out exhaust& backfire. How do I remove the flywheel? how do you time it?
More or less, check your rings... sounds to me as if your rings are going...
Fire will also come from exhaust if too much starter fluid is sprayed..
Use carburetor cleaner instead
Nov 03, 2015 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
How do I replace top crank seal honda GCV 160 engine
its not going to matter if the seal is leaking damage alreay done to it run it till it stops or lockes up
Aug 18, 2014 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Husqvarna problems
Follow the cable to make sure it isn't stuck. If the cable moves freely, check that the flywheel brake and any attached springs are connected properly. These are usually under the pull start cover.
Jul 19, 2014 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Manual for MZ6128
Call jack small engine 877 737 2787 have make, model,serial number ready
Jul 05, 2014 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
I got water in the tank, I had to siphon it back out. The mower will not start now.
Hi dylan
Drain your carburator of fuel, I am sure you have water there also..if that does not work I have some info for yoiu below.
Apr 25, 2013 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Where do i get parts??????
Go to your nearest Husky Dealer or SMALL ENGINE REPAIR. You can also get parts on EBAY.
Apr 12, 2013 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Just bought this mower honda hush arena 21 " push mower and it throws clippings all over the deck, why? Looks like its coming from the side outlet
See if the side outlet needs a plug underneath to keep the grass inside the deck to be mulched. A lot of mowers have these plugs but this one might have not been installed.
Jan 19, 2013 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Husqvarna
Gas filter might not run properly and it must be replace. If it gets bad enough the lawn mower might not turn on and in worse case gasoline could start coming out the air pusher.
Aug 05, 2012 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
How to replace the primer bulb?
What do you mean by a primer bulb? Do you need instructions?
Thanks,
Jul 06, 2011 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Husqvarna 7021 21Inch 160cc Honda GCV Gas Powered Lawn Mower () Logo
1,009 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
