Question about Belkin Computers & Internet
I am unable to connect to wireless without the ethernet cable, using the new router i have just purchased ?
  • 38 Answers
Talk to your internet service provider. he probably will give you help.
Posted on Jul 29, 2010
I purchased a D-Link Wireless N 150 Router, Dir 600L. I am unable to setup the same. Do I need a Modem also to setup this router or I can setup without a modem?
You can setup a wireless network without a modem. It will allow you to share printers, files ect. The modem is required for an internet connection only. The modem basically translates the Ethernet traffic in to a signal that can be carried over your respective service, DSL over a POTS line or broadband over a coax cable. The word modem stands for MOdularDEModular note the word MODEM in there.
Dec 24, 2012 | D-Link DIR-600 Router
Linksys E3000 Wireless Connectivity Problems the router is excessively hot too. Can connect with ethernet cables I have cable mode and the cable company sees my lan card I can get internet connected via...
That excessive hot temperature of your router is not a good sign, it means that something is wrong with it and the problem is hardware base and in just a few more days or weeks the router will eventually stop working even when using ethernet cable.
The best thing to do here if the router is still new and under warranty is to have it replace from store or from where you purchased it.
Mar 04, 2011 | Linksys E3000 Wireless Router
I am unable to set up my Linksys WRT150N router security. I am using a Mac Computer OS X v10.5.8. I can access the internet using the router but only through an unsecure connection. When I go to change the...
Is there any computer connected to the router ?
If not then you will need to connect the computer
to the router.
Do not change any wireless settings on the router
with the wireless computer.
you will need to connect the computer to the
router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the
router.
Now once you change the network anme and security
on the router, you will need to connect to the
wireless network on your wireless computers.
Click Here for step by step instructions
Jan 24, 2010 | Linksys Wireless-N WRT150N Router
I have linksys router,it's connect with lan cabel but without lan cable router unable to connect to my laptop
All routers need to have a ethernet cord from the ISP Device. Most people run Laptops Wireless from there routers or if its stationary run another ethernet cord from an open port behind the router to your laptop.
Sep 19, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Unable to connect Linksys wireless router to my arris cm450a
All routers will only work with ethernet. You would need to get an ethernet card installed in your computer. You can probably buy one for about 20.00 at Walmart. If you don't want to do this you can purchase a usb/ethernet adapter and still use the usb port on your computer. You can purchase one of these for around 5.00's on ebay. Just go to ebay and search for usb/ethernet adapter. Please rate if this has helped. Thanks.
Jan 31, 2009 | Arris Touchstone 450a (CM450) Modem
Zoom aDSL modem/wireless router seen but not connecting
Here are a couple of ideas to look at first, assuming you haven't tried them already:
1) Does moving the router help? Sometimes a new DECT phone or a microwave, or even a piece of equipment at a neighbour's house, can interfere with the signal.
2) Does changing the channel on your router help at all? If there are many other networks using the same channel, this might block your own signal.
3) If this does not make any difference, it might be worth checking your security settings.
Nov 14, 2008 | Zoom (5590-00-03) Wireless Router (G66115)
Trying to get router to work
that would be a settings issue for the router..the output of the modem should work on usb or ethernet..can you see the router from your desktop management application?
Oct 22, 2008 | Computers & Internet
Need Help with new Wireless Router
more info needed.
Are you on cable or dsl? Can you access the router set-up screen? Can you ping the router from the computer? Whose tech support did you call? Are you using wireless or ethernet connection to router? Can you access the net if you hookup using a ethernet cable? What OS are you using?
You migh try disconnecting the modem line for a few minutes and then reconnecting it to reset the IP address your ISP gives you. If you were using the net successfully without the router, you may want to clone your computer's MAC to the router (DSL).
May 13, 2008 | Computers & Internet
I purchased a new computer but i am unable to connect to the internet with my wireless adapter because it asks me for a security password that i never established when i initially connected my router and...
Try using it without actually entering a password. Othewise, connect a computer to the router with an ethernet cable. Go to Start> Run> type cmd a black window should open up. Type ipconfig at the cursor. This will bring up a series of numbers. Try connecting to your router By typing the ip address that is in the "default Gateway" spot, in your browser address bar. If it has a login page, use "admin" as the user without a password and change the settings in there. You should be able to disable the password there.
Apr 17, 2008 | Computers & Internet
U can use
USB Ethernet Adapters.Visit:
http://www.ramelectronics.net/network/network-cards/usb-ethernet-adapters/c40000-c43000-c43004-p1.html
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
