Question about Gateway M460 Notebook
Laptop fluctuates charging/battery while on ac power
When ac adapter is plugged in, the laptop quickly flucuates from charging to battery power, and sometimes it doesn't charge at all
  • 734 Answers
HI There,
Your problem is your DC Power Jack that you're plugging into. It's very common with this series. The Power Jack over time starts to pull away from the motherboard (the soldering that holds it fails). It can short out back and forth between only power, only charging, or doing both or doing nothing.
There are several companies on eBay that do the repair for around 60 to 80 dollars including the return shipping. You pay the shipping to them. Go to eBay and in the search box type in "DC Powerjack Repair Replace" and you can select the company of your choice. Check their "Feedback" rating to make sure their not just arrived as a vendor.
I have used several different ones (I'm a laptop repair specialist) and have never had a problem yet.
Good Luck
Posted on Jul 29, 2010
Laptop is turning on and off
Remove the AC adapter (Charger)
PROPER method is to disconnect the power cord of the AC adapter, from power; THEN unplug the AC adapter from the laptop.
Same thing in reverse to plug the AC adapter back in.
AC adapter is plugged into laptop, THEN AC adapter is plugged into power.
Unplugging the AC adapter from the laptop, while being plugged into power; can cause a Voltage Spike.
You may get away with it for years, and several laptops; and have no problems.
However it only takes ONCE, to fry out the SMD fuses, Multi-Layer Ceramic Capacitors, and Power MOSFET's, on the laptop motherboard's DC to DC circuit.
Jus sayin'.
Moving on........
AC adapter removed, remove the Battery.
Press the Power On button in, and hold in for a count of 10 seconds.
Let go.
Do this procedure 2 more times.
(Draining residual power)
Reinstall the Battery. Attach the AC adapter, plug AC adapter into power. Let the Battery charge 24 hours.
Then turn the laptop on, and tell me what happened.
Regards,
joecoolvette
Mar 15, 2013 | HP Pavilion Computers & Internet
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
Dell inspiron not charging
Dear Mathew,
You should you Dell Utility and it has the function called Dell Battery Metter, it can enable or disable charging
Nov 12, 2012 | Computers & Internet
Is there a software that is associated with my sonny battery that will make it charge again
If you plug in your AC adapter to your laptop to charge the battery and get the "plugged in, not charging" message then try the following solution:
  • Disconnect AC adapter
  • Shutdown laptop
  • Remove laptop battery
  • Connect AC adapter
  • Power on laptop
  • Click the Startup Menu
  • Type Device and select Device Manager
  • Under the Batteries category, right-click Microsoft ACPI Compliant Control Method Battery and select Uninstall.
  • Shutdown laptop
  • Insert laptop battery
  • Power on laptop
    If you follow these steps and find that your laptop still does not charge then consider replacing the laptop battery itself.
    Hope to have been of assistance,
    Thanks.
  • Sep 14, 2011 | Sony VAIO PCG-K23 Notebook
    My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
    Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
    When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
    Possible cause:1. AC power adapter failure.
    2. Battery failure.
    3. Broken/loose power jack.
    4. Motherboard failure.
    Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
    http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
    2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
    3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
    4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
    Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
    Laptop battery is not charging
    Hi, this information represents a basic troubleshooting guideline. Refer to your user guide for specific charging and connection instructions. Manuals may be available online in the Support Web site of HP.
    Remove the battery from the computer.
    Confirm the battery contacts are free of any foreign material that may prevent charging.
    Reinsert the battery into the computer.
    Verify that the AC adapter cord is properly connected and plugged directly into a known working AC power outlet.
    NOTE: If the battery charges correctly when the AC adapter is plugged directly into an AC power outlet, but not when plugged into a power strip or surge protector, the problem is with the power strip or surge protector and not the computer battery or AC adapter.
    Verify the correct AC adapter is being used.
    Ensure the AC adapter box power light is on. This will be an illuminated green light.
    If the AC adapter power light is not on, the AC adapter and power cord will need to be replaced.
    Verify the charging indicator is illuminated on the computer.
    If the issue still exists, install a different compatible HP battery, if available.
    NOTE: If a replacement battery charges and operates correctly, the problem is with the first battery.
    If neither the original nor a replacement battery charges, service may be required for the computer.
    Dec 21, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
    Hi all please i need a hardware specialist who is conversant to the HP compaq 6735s AMD sempron 1gig ram notebook to help me on this one i made a mistake trying to use the ac adapter for another hp...
    internal component failure close to adapter socket Maybe user serviceable problem with recent surface mount components not really repairable by consumer
    Sep 06, 2010 | HP Compaq 6735s Notebook
    Dell latitude l400 mother board power problem
    SOLUTION  # 2:
    The  adapter can be plugged into the DELL the wrong way and it won't charge then. I've done this myself so check to see if the adapter plug that goes into the laptop has a grey battery icon on it. The icon goes on top when you plug it in. For different laptops the symbol may be different than what I mentioned.
    Aug 18, 2009 | Dell Latitude L400 CMOS Battery (7.2V,...
    Acer laptop shut of during power outage .
    From the Acer website:
    Product
    Notebook
    Issue
    Power Issues or Will not Boot
    Solution
    If the notebook does not power on:
    Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
    If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
    1. Unplug the ac adapter. Keep ac adapter unplugged.
    2. Remove the battery and keep the battery unplugged.
    3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
    4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
    5. Normally power on the notebook.
    6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
    7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
      If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
    Also, depending on whether your power went down "clean" (quick and stayed off), or went down and quickly came back on and off many times. Or when it came back on "clean" (came back on quick and stayed on), or it came on then off many times, your power supply may have been damaged from the power surges Are you having any problems with any other appliances?
    Feb 07, 2009 | Acer Aspire L100 PC Desktop
    Dell Inspirion 1526 Laptop Battery is not charging
    Sound like the battery. Take the battery out and there should be a power meter on it, press it, if there are three lights that flash, the battery is shot. Not all batteries will flash if they are worn out, but they are supposed to. Try a new battery, I believe this will coorect the issue.
    Jun 21, 2008 | Dell Inspiron E1505 Notebook
    Gateway M460 Notebook Logo
    205 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
