Question about Bernina Activa 140
Machine is making a clunking noise and producing a bunch of looped up thread on the underside of the fabric every time I try to sew. How do i fix this?Thanks for the advice - Kate
  • Bernina Master
  • 7,365 Answers
1.check to see if the needle is in backwards
2.check to see if the needle is bent--lay it on a table & see
3.check the bobbin to see if it's warped
4.make sure it's threaded correctly-sometimes the thread on the thread take up lever can come off--it does on my mechanical sewing machine & I've been sewing & working on sewing machine for 23 years
Posted on Jul 29, 2010
Testimonial: "Thanks for the advice. Will try all your suggestions."
The stitches on the underside are looping I’ve retreaded both the needle and bobbin and neither makes a difference
You are getting a thread mess under the fabric? Frequently, this occurs because the top thread is not fully seated in the tension disk.
Install a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread the machine from the beginning.
If necessary, adjust the top tension so the top and bobbin threads meet in the middle of the fabric.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
TIP Avoid Thread Bird Nesting with these Four Tips Stitching Sewcial
Troubleshooting Thread Nesting Sew Toot
Jan 04, 2018 | Sewing Machines
Viking Topez 50
Jan 03, 2018 | Sewing Machines
Pfaff Creative 2 loops on underside of fabric
Although there could be several reasons, this is generally called bird nesting or thread nesting. It is usually a result of loose upper tension, mis-threading, or possibly a needle/thread/fabric incompatibility.
#1--when you thread, make sure you ALWAYS raise the presser foot so the thread seats in the tension disk. And, be sure to change the needle often...
What causes Bird Nests Superior Threads
https://lindeegembroidery.com/common-causes-of-birdnests
Nov 12, 2016 | PfaFF Sewing Machines
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
Thread on my consew 225 keeps balling the thread on the bottbottom
Sounds like bird nesting. The upper thread accumulates under the fabric creating a series of loops and knots.
First: Install a brand new needle and make sure it is installed facing the correct direction. (A new needle is the least expensive fix for most sewing machine issues.)
Second: Remove the thread. RAISE the presser foot and rethread from the beginning. Make sure it is threaded correctly (consult the owner's manual).
Third: Pull up the bobbin thread through the fabric and gently hold the thread tails in your left hand while slowly taking the first couple of stitches.
How and Why to Bring up the Bobbin Thread
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
Why Do Get Bunched Up Thread Under My Fabric
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Feb 06, 2016 | Consew Sewing Machines
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
sewing machine birdnesting
8 Tips to Fix Birdnesting in Embroidery
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
How do I adjust tension on a Necchi Lydia 510 sewing machine?
loops under fabric means top tension needs to be tightened
try cleaning the top tension dial with some unwaxed dental floss and see if that helps. if it doesn't then the tension dial may need to be replaced
also check to make sure the spool of thread is not getting caught on the spool holder
also try a new needle--one that is correct for the fabric being sewed
Feb 10, 2015 | Necchi Sewing Machines
When I sew, the stitching is loose with large loops on the underside of the fabric making the bobbin thread slide out easily. How do I fix that?
Lift the pressue foot off the fabric. Hold the thread spool with one hand and lightly pull the thread hanging out the back of the needle. This should seat the tread into your top tension discs properly. Now try sewing again. If it still throws loops, you either do not have your machine threaded correctly or your tension on top is set to zero.
Sep 01, 2014 | Bernina Sewing Machines
I teach sewing. A student had a problem with bunched threads on the underside of the fabric. I have tried figuring it out and every so often the thread stops looping. While sewing on the cg550 singer...
Make sure you have the correct bobbin, 66 class. Check the bobbin case. These machines use the apollo bobbin case that tend to get broken and then the thread hangs up.
Apr 27, 2011 | Singer CG550 Mechanical Sewing Machine
Sewing Machines Logo
705 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
