Compaq Presario B1900 Model HSTNN-A25C. Laptop wont charge. When I plug in the charger, the light on the front just flashes in no pacific order. Have replaced the charger and tried different batteries but with no luck. The laptop also wont power up with out the battery installed, which I though should. Any ideas? Thanx
  • Anonymous Jun 16, 2008
    I have a COMPAQ laptop, Model NO. HSTNN-A25C, His problem no sound. Please i want the audio driver.
    Thank you.
  • Anonymous Apr 02, 2009
    sound problam
I have the exact same problem on my Presario B1900 as well! I have also replaced batteries and power supplies but no lucl.
Can any help me out?
Thanx
Posted on Jun 14, 2008
  • 61 Answers
I would look closely at the battery connectors on the PC itself.
Posted on Apr 24, 2008
I want to activate wifi on my laptop Model: HP COMPAQ HSTNN-A25C. Please advise the process.
The wifi switch will be in one of the following places. It may have a wifi symbol which will look like radio waves. I hope this helps.
  1. Check the front edge of the laptop for a switch that goes from left to right. The light will normally go from Orange to Blue
  2. check the side edges for the wifi switch
  3. Look at the top of the Keyboard above the number keys to the right. you may find a button there.
  4. Or you can manually turn on your wifi.Click the "Start" button, and click "Control Panel." Click "Network and Internet." Click "Change adapter settings." Right-click on "Wireless Network Connection," and select "Enable" from the menu.
  5. Once you see the wifi symbol at the bottom right of the Laptop screen (near the date/time) click on it and choose your wireless network.
Jul 29, 2016 | HP Computers & Internet
Compaq Presario V5000 does not come on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
http://www.chargerbuy.com/replacement-compaq-presario-v5000-ac-adapter-65w-18-5v-3-5a.html
Nov 20, 2012 | Compaq Computers & Internet
I have bought a new charger for my laptop, compaq presario cq56, and it is still not charging
Other expert is right--if not charger may be a loose socket where it plugs in or even a bad battery is possible.
Jun 12, 2012 | Compaq Presario CQ56-115DX Laptop
My compaq presario 2200 wont boot up...when i press the on/off switch without the a/c charger (battery alone), the amber led flashes twice....if i plug the charger in with the battery, the led blinks once...
If the computer is not turning on, there is a big chance of hardware failure and normally there is no easy fix for this rather than a motherboard replacement.
May 03, 2011 | HP Compaq Presario 2200 Notebook
I have a compaq presario cq61 and have been having problems with the charger for quite a while but money is an issue so cannot get a new one just yet, the laptop has 2 lights to aknowledge that the...
YOUR PACK IS NO GOOD
IT MUST RUN WITH NO BATTERY
PACK CONNECTED
SINCE IT DONT THEN THE CHARGE IS WEAK TOO.
YOU KNOW PACKS CAN BE
GOOD
BAD
OR WEAK, OR EVEN ON FIRE, (loL)
Mar 01, 2017 | HP Compaq Presario CQ61420us Notebook
My laptop HP PRESARIO V1000 won't start without charger plug in. When push on, the charge led blinking for eight times then nothing happen. it start normally when I turn on with charger plug in, after...
It sounds like the Battery is Dead or not charging. You might try a local pc shop and see if they have any laptop batteries for you laptop. Or have them test to see if the battery is charging.
Dec 11, 2010 | Compaq Presario M2000 V1000 V2000 V3000...
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
My laptop wont charge so i brought a new charger but it still wont work.
It could be the battery... they tend to wear out over time. If you run the laptop with the charger plugged in, it works fine, right? It just won't hold the charge?
Aug 31, 2010 | HP Compaq Presario CQ61420us Notebook
Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
May 23, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq presario v2000 wont charge
It has happened to me as well since i have the exact same model laptop. The problem is a loose cable or the wire inside is damaged. I just bought a new charger since buying one is cheaper than taking the risks that the repair might cause a short after using it for some time.
Jul 26, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
1,572 people viewed this question
David Payne
David Payne
