Question about Magicard Rio 2e - Ethernet - Single-Side Printer
The printer ribbon keeps breaking and when it does
The printer ribbon keeps breaking, and when it does work the colours are faded, i have brought a new ribbon and the fault is still the same
The printer needs to be cleaned and the cleaning roller (the cylinder thingy that comes wrapped) may need to replaced. You will know if it needs to be replaced if it looks dirty.
Posted on Nov 01, 2010
I have wep printronix p7500 line printer. I haven't uses the printer since last 24-30 month. when i print a text file using edit.exe. it print quality is very fade. I brought a new ribbon for this printer....
I'm guessing the carrier solvent for the ink has evaporated. (Ribbon is old and dried out - even the new one) In the past, i have sprayed WD40 on unspooled ribbons and rewound them to bring ribbons back to life but that can be messy with spotty results. Suggest you buy direct fro Printronix.....
Oct 01, 2017 | Printronix Office Equipment & Supplies
My zebra card printer p330 i donbt recognized the colour ribbo YCMK, only detect the mono ribbon
The P330i is not supposed to work with the YMCK color ribbon, you should use the YMCKO 800015-440 color ribbon.
-- The Pros at www.DiscountIDStore.com
Sep 25, 2010 | Zebra P330i Thermal Card Printer
Print keeps fading, even though using new ink
check your printer settings, make sure color only is not checked off, or if you mainly print black and white documents, you should have that option checked, you may have to go into advance printer options to do this.
Apr 07, 2010 | HP Deskjet 3845 InkJet Printer
I have a zebra z6mplus the ribbon keeps breaking
You may have your contrast set too high. If it breaks as it feeds under the printhead (while printing) your contrast may be set too high.
You also could have a ribbon spindle issue. Are both ribbon spindles turning?
Jul 08, 2009 | Zebra Z6M Plus Thermal Label Printer
Printer keeps breaking the ribbon
first, try to calibrate the ribbon, if it does not work, you probably have worn out rollers, and possibly a broken o-ring. if you want more info, call us at 310-671-8018, thanks adi
Mar 25, 2009 | Fargo DTC400 ID Card Printer Package
COLOUR PRINTING
A thermal printer will only print in black because it burns the image into the paper like a hot iron. It produces a black image because of the surface of the paper is coated. Usually the image fades or goes away after six months.
If you hade a label printer that uses color transfer ribbons, that would work if they have other colors available besides black. I don't know if that is an option with this particular model.
Mar 10, 2009 | Dymo LabelWriter 400 Thermal Printer
Card printer is not printing in colour
You have probably bought fake color ribbons , or you have taqken of the blue cup with the rfid inside.. Wich tells the printer what kind of ribbon installed
Nov 19, 2008 | Datacard SP35 Printer
Data card sp35 plus ribbon break
There could be either of the following issues:
1. Check the print head temperature to make sure that it is hot enough to transfer the ribbon to the card.
2. The surface of the PVC card may not be image compatible. Try another brand of card or opt to 60/40 composite cards for testing.
For technical assistance by blog for id card printers, see our blog at www.safecardid.com/blog/
Jun 20, 2008 | Datacard SP35 Printer
Vertical fading lines
Sounds like dust on the CMY ribbon. Did you try a new color CMY ribbon?
Possibly the printer has dust floating around on the inside, but if balck prints good, that may not be.
- techwaredit
Apr 01, 2008 | Rimage Everest II Printer
Wierd colours on LCD screen.
Check LCD ribbon cable. 99% LCD ribbon cable is defective. Replace LCD ribbon cable.
Nov 09, 2006 | Panasonic PV-GS31 Mini DV Digital...
Open Questions:
See all Magicard Rio 2e - Ethernet - Single-Side Printer Questions
Magicard Rio 2e - Ethernet - Single-Side Printer Logo
252 people viewed this question
Top Magicard Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
