Question about Motorola Mobility RAZR V3 Razor Car Charger
Auto answer does not answer
I have a motorola v3 cell phone and I have activated the auto answer feature, but the phone does not pick up when an incoming call is present. Am I doing something wrong?
  • piggybankauc Jul 29, 2010
    Motorola v3: How can I get the auto answer function to work where it answers calls without any manipulation?
    President:
  • 567 Answers
Hi it seem like you did something wrong indeed,you should restore the phone to factory setting then start again
Posted on Jul 29, 2010
  • 6 more comments
    Do you know how to find the code for the master reset?
    Okay, I did the master reset. Code =000000. But it's still not picking up. I believe I have to use bluetooth or car connection. I will try that later. Any other suggestions?
  • piggybankauc Jul 30, 2010
    I tried the auto answer feature with the bluetooth and with the car charger/connection and neither allowed it to work - still not answering the call. I'm still open to suggestions.
  • Hilton Bristol Jul 30, 2010
    okay i will send you some suggestions
    A Motorola bluetooth headset is an affordable and user-friendly headset. To use a bluetooth headset with a cell phone, the user must first pair the headset and the cell phone with each other. This is a simple process whereby the headset and the phone are "introduced" to each other so that they can work together. After pairing, they will be able to detect each other and work together to enable hands-free use of the cell phone
  • Charge the headset. Turn the headset off and insert the connecting plug into the end of the bluetooth headset. Leave the charger plugged into the headset until the light on the charger turns green. Disconnect the bluetooth headset and the charger.
  • Step 2.Activate the cell phone's bluetooth ability. Find the bluetooth function within the menu settings and turn it to the "on" position.
  • Step 3.Turn the bluetooth headset on. Most Motorola bluetooth headsets indicate they are ready for pairing with a steady blue light. Press the on button until the headset displays a steady blue light.
  • Direct the cell phone to look for bluetooth devices with which to pair. Within the bluetooth menu, find "Look for Devices."
  • Step 5Select the bluetooth headset when the cell phone detects it. Click the "OK" button when the cell phone confirms the pairing. Enter "0000" for the passkey when prompted. Click "OK."
  • Step 6Confirm the pairing. The headset indicator light should now be flashing blue and purple.
    Test the pairing by making a call. Dial a number on the cell phone and make sure you hear the ringing and voice in your bluetooth headset.
    I appreciate your help. I already had the bluetooth paired and functioning properly. The problem is still the auto answer of the headset. It does not answer when a new call is coming in. It just continues to ring and not pick up/answer the call. I want it to answer the call without pressing or touching anything.
  • Hilton Bristol Aug 02, 2010
    You should try to update the phone software if its possible, if thats not possible it may mean your phone is not design for automatically answering calls.
    • 360 Answers
    Hi, the auto answer feature on a motorola v3 does not mean it will automatically pick up a call when it comes in, rather it means it picks up the call as soon as you open the flip.
    Take care
      With the auto answer feature turned off, the phone can be anwsered when the phone is opened during a call so I don't think this is totally correct.
    • Quadri Olatunbosun
      Quadri Olatunbosun Jul 29, 2010
      Hi, the auto answer actually works for/with your headset device...
    I've got a Motorola RAZR 3 or 4 years old. I just bought a new car with Bluetooth (Ford Sync). How do I get the car to recognize the phone?
    In order to make other devices see your motorola mobile phone, you should enable "discovery mode", which is activated in Bluetooth menu of your phone.
    Please be aware that this feature is turning on only for 3 minutes, then new devices won't be able to find your cell phone. If 3 minutes is not enough, you can activate this feature again (and again).
    This procedure is only required for initial pairing, there is no need to perform this operation every time.
    Hope this helps!
    Sep 07, 2011 | Motorola Mobility RAZR V3
    Unlocking code + Motorola Razor V3 Phone
    here
    http://www.mobileunlocksolutions.com/motorola-v3/rs1wp9/
    you can get your Motorola RAZR V3 mobile model unlocked at very low cost ,full secure & Safe..
    Apr 06, 2010 | Motorola Mobility RAZR V3
    Cant find speaker phone feature on my Motorola Razr V3 cell phone
    Yes, This phone does have a speaker phone setting.
    When in a call it should be the top right button on your keypad.
    Dec 17, 2008 | Motorola Mobility RAZR V3
    Auto answer
    Master reset the phone. or visit www.picocity.com
    Jan 07, 2008 | Motorola Mobility RAZR V3
    Auto bluetooth problems with Motorola RAZR V3 cell
    don't think so.
    maybe while pairing up the new phone you have turned down the volume on the earpiece?
    Nov 28, 2007 | Motorola Mobility RAZR V3
    Razor v3 - call waiting question
    check your phone settings and if u do not want call waiting,disable it manually
    Nov 27, 2007 | Motorola Mobility RAZR V3
    Motorola v3
    Not being cheeky buddy but I have the same pairing are you tapping in "0000". Also go into settings and headphone or carsettings and set to auto answer. Hope this helps M8
    Sep 26, 2007 | Motorola Mobility H350 Wireless Headset
    No service phone
    Let's start with the basics here. Do you have a service provider? Is it activated? Is the phone activated? If NO, then you need to subscribe to one and have them activate the phone. You simply may not have activated the phone before using it. If the answer is YES, then you may be in a "dead zone" or "bind spot". Move to different locations (several blocks sometimes). There are whole neighborhoods without service especially in the mountains. Are you in such a community? If these answers did not solve your problem then you need to take the phone back to the store you got it from.
    Aug 19, 2007 | Motorola Mobility RAZR V3
    Motorola Mobility RAZR V3 Razor Car Charger Logo
    77 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
