Question about Waring CB15 Work Top Blender
The cb15 blender works for 1/2 hour stop running sit for 20 minutes starts working again and then repeats the same process. Now it stop working all together. I had the blender less than 1yr brand new out of the box.
  • 2,272 Answers
Motor ,Motor coil and Internal carbon .This parts are getting short.The motor is actually weak or the motor coil is got weak.So after running for few minutes the parts gets hot due to weak and it stops.Then again works after gets bit cold.But this will not last long.Slowly ---- slowly the working time for the unit will become lesser and lesser.At one period it will just start for few seconds and then again stop.If you turn it off then again ON then it will do the same.At last motor and its coil will get non operational.Its advisable to get this parts checked and replace the exact faulty part.The motor coil,the motor and the internal carbon.A local electronics repair shop dealing in repairing with this brand model unit will be helpful.If the unit is under any kind of warranty then get it repaired by the service center of the unit.other wise local electronics repair technician.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 29, 2010
Vitamin 3600 canister leak
I think it's the little washer in the blade assmbly since mine was worn to a sliver when it started doing what yours did. I replaced it with a similar washer and it worked for a week and then started spitting out metallic dust until it stopped working again. Could be the bearing seized. I would say yes a new blade assembly but I hadn't found one- since I have a 3600 which is very old-when my husband bought a used replacement container with a working blade assembly on ebay. $37 bucks, problem solved.
Mar 28, 2012 | Vitamix Blenders
When I make a frappacino I get lots of foam instead a slushie drink
You're blending at a high speed and air is getting introduced. Try a slow blend speed. This should solve your issue.
Jul 24, 2011 | Vitamix 5000 Work Top Blender
My cb15 blender is making noise and I think bearing are worn out
most of the time they are a bronze bushing and needs to be cleaned and use silicone grease as an lube. check the motor bearing as well
Mar 19, 2010 | Waring CB15 Work Top Blender
The blender stops working after a few minutes while I am in the process of making peanut butter. Why is it overheating so rapidly
it could be the consistancy of what your processing heavyer food will overheat it quicker then less dense foods.
Dec 21, 2009 | Vitamix Super 5000 Work Top Blender
WHEN i PUSH ANY BUTTON TO TURN IT ON, IT WORKS FOR A FEW SECONDS THEN IT STOPS, i HAVE TO UNPLUG IT AND SHAKE IT, IT WORKS FOR ANOTHER FEW SECONDS THEN IT STOPS AGAIN. wHAT CAN i DO TO FIX IT?
Sounds like the brushes are not making good contact or you have a defective switch. Run the blender witout the container or blades . Free run it for 5 minutes id you can and see if that helps.
Oct 20, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
Unit began smoking and smelled hot
If this was a recent purchase for which you have a receipt, return it to the store immediately while you still can. If it is beyond the store's return policy, but purchased less than one year ago (most times you will still need a receipt), call Black and Decker to get in-warranty service/replacement.
In fact, call Black and Decker anyways - if the BL5000 was manufactured between Dec.2003 and Jan.2005 (highly possible if it was marked on clearance), the blade assemblies were recalled. here is the recall notice:
http://www.blackanddeckerappliances.net/safetyrecall2.html
If it is out of warranty, let the blender cool for an hour. Then remove the blender jar, plug in the base, and see if it will spin with nothing attached to it. See if it smokes if left on for 1 full minute - don't let it run longer than one minute.
If it doesn't smoke, let it cool for an additional 20 minutes. Then remove and then reassemble the blade assembly, gasket, etc., collar, jar, etc. Try blending. If it smokes while blending, order a new blade assembly and gasket (usually they come packaged together - around $20 or so). Once the new blade assembly/gasket arrives, try blending again. If it doesn't smoke, you're probably good to go. If it does smoke, you have a more serious issue.
All of this is going to take time and money if it is out-of-warranty. If you have deemed that the blender is worth more than $50 for a new one, let me know.
Mar 26, 2009 | Black & Decker BL5000 ProBlend Work Top...
Hello, we stored the blender in a box w. the jar on the base and now the jar is stuck on the base...anything that might help?
1) Vinegar - apply vinegar to a rag and apply to any exposed areas - use a q-tip to dribble vinegar into hard-to-reach places. Let a cup of vinegar sit in jar itself. After 20 minutes, try to remove.
2) Hot Water in blender jar.
3) Freezer - don't let it sit too long - 10 mins tops - last resort.
If all else fails, break parts, and reorder them here:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3635&linkon=subsection&linkid=120&secid=53
-Tha Mp3 Doctor
Jan 13, 2009 | Back to Basics Blender Solution 5500...
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
Blender stops working
I also have the same problem...it is brand new...worked 3-4 times and stopped. Spent $65 for a nice blender. I will also NEVER buy black and decker again.
Dallas, TX
Oct 12, 2007 | Black & Decker BL1900R Blender
Waring CB15 Work Top Blender Logo
81 people viewed this question
Top Waring Blenders Experts
AZBen
AZBen
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
