Question about Homelite Mighty Lite Lawn Trimmer
Have lost a spring and so therefore line won't feed. Where can I get replacement parts for my Homelite Mighty Lite 26cs machine?
Ebay... Parts interchange with Ryobi...sometimes
Posted on Jul 29, 2010
Homelite mighty lite 26bv gas Blower won't run full speed or only in Full Choke
Sounds like a lean condition. Rebuild carb, replace fuel lines and fuel filter and you should be ready to blow the leaves.
Nov 10, 2012 | Homelite Mighty Lite Blowervac
Homelite weedeater mod. 26cs
Try going to ebay and finding a carb for the model, some are as cheap as $12.
Mar 12, 2017 | Homelite Mighty Lite Lawn Trimmer
I need an address to purchase a fuel tank for my mighty lite 26cs . Model - UT21506 SN- ATK0712739
Go to psep.biz or jackssmallengines.com you will find all that you are looking for ! Godd Luck...
Aug 16, 2011 | Homelite Mighty Lite Lawn Trimmer
My homelite 26cs has not advanced the line from day one. Each of the five times I have mowed and then wanted to weed eat/trim since buying it I have take the spool out, threaded it through the holes and...
Be sure the Line is wound the proper direction as having wound the wrong direction would make it wind the string back in as you try to make it feed out. Other than that I would say it may be a faulty spool but i would go to Homelite website HERE and contact them to let them know it does not feed properly if you just bought it I believe it is under a 2 year manufacturers warranty.
Thumbs up if helpful, Feedback is Appreciated!!!!
Jun 21, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a Homelite Mighty Lite 26cs gas weed **** and the starter cord will not retract into the weed ****. How can I get it to retract so it can be pulled to start the weed ****?
This is somewhat common in the the "zip start" machines. The recoil pulley is 2 plastic housings with a round coil spring between them. It is designed to need less effort to pull and start the machine. When pulled on with great effort/frustration, the middle spring bends and damages the upper housing. The only semi-permanent solution is to replace the pulley assembly. The part is relatively cheap thru Homelite.com. If you can do it yourself, go for it. A repair shop will most likely charge you $20 to $40 in labor to do this.
Aug 05, 2010 | Homelite Consumer Products MightyLite...
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
Hello I need the homeleit 26cs mighty lite manual, the starting coard wont retract
This would be caused by the starter pulley separating and jamming on the flywheel, In most cases it would cost more to fix these machines than it would be to replace them. Unless of course its under warranty then just take it back for a repacement.
Aug 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Mightylite 26cs Gas Trimmer
sounds to me like dirt in gas tank dirty or plugged filter screen on fuel line inside gas tank or plugged pinched or obstucted fuel line . also check for the following pin hole in primer bulb bad spark plug dirty or rusty coil or flywheel magnet.or simply dirty or missadjusted carb if i can be of further assistance let me know i would start with the fuel hoses and make sure they are in good shape first ...do the easiest and cheapest things first good luck hope this gets you up and running good mrdmburns@cableone,net
May 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
489 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
