I have got a compaq presario computer but i need to take the front off to put a new dvd writer in. after removing the side panel what do i do to remove the front panel. thanks mr davies
    Genius:
  • 2,785 Answers
Just check from inside there may be latches
Posted on Apr 24, 2008
Remove front panel
Hello there!
1) take all the screws at back and sides, panels out.
2) the fron panel carefully pull out, with a screwdriver, but carefully not to broke the plastic snap connectors. now you has access to the DVD bays, and can installs new device .
Carl
Mar 16, 2014 | HP Compaq Presario SR1620NX...
How remove DVD From desktop Compaq Presario
have to be a little more clear with the question depends on where you want them removed if the computer oh intalar system for a non-dvd if the system goes to control panel and look for oction says oh add remove program
if you want to put a DVD without need only to plug the computer and remove the cable and put the other one wants to
Oct 17, 2010 | HP Compaq Presario Media Center SR1750NX...
I need to replace dvd writer in my advent SE 2102 desktop pc but can't get it in. Think I need to remove faceplate to put it in from the front but I don't know what to do without damaging casing?
check to see if there are any external screws ie for side panels removal if so remove side panels then (remove cables that are connected to drive then remove screws holding in drive then simply slide drive out put in new drive and reverse the process). if no external screws put hand underneath front of computer there should be a gap carefully pull panel away, will be quite stiff then do as above in brackets.
hope this helps
Jun 19, 2010 | Computers & Internet
Compaq presario c700
If there is a little pin hole on the front use an unwound paper-clip. push it into the hole and the mechanism should release? Realy need more detail though.
Apr 01, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
Dvd writer/cd writer combo on a compaq presario has jst stopped working. when i put a dvd or cd into the drive nothing at all happens other than the green light appears on the front of the cd driver. no on...
1st of all insert the correct cd or dvd without scratch and then check it otherwise open you pc case and check your id or sata cable correctly connected or change your id or sata cable
Nov 18, 2009 | Video Game Consoles & Games
Is it compatable with my desktop pc?
Ok. Well basically CD, DVD and Hard Drives are all cross compatible platforms so you don't have to worry about compatibility issues. If your asking me to choose I would say that you remove the CD writer instead. But before you do this make sure you have enough extra sockets in your motherbaord to plug in your Pioneer DVR-1910LS 20x DVD±RW IDE Drive w/LightScribe if your CD Writer uses IDE interface your inluck coz you can use it in place of the Pioneer DVR-1910LS 20x DVD±RW IDE Drive w/LightScribe, but if it isn't make sure you have a spare IDE socket in your motherboard. Simply remove the side panel use a flashlight and see if there are vacant IDE sockets, it's usually long in black, white or blue color. see the picture below.
If its vacant follow the steps on the link below simply copy and paste the link on you browsers address bar.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07164&lc=en&dlc=en&cc=us&lang=en&product=390426
I hope this helps you...
Jan 22, 2009 | Compaq Presario S6300NX PC Desktop
I have a compaq presario SR2150NX and i need to replace the CD drive. What should i buy
The solution is that do not replace the cd drive !!
You could buy a new DVD writer drive which can be very useful.
You can use both "cd drive" and the new "dvd drive" at a time.
New DVD drive comes only for rs.1200/- to 1500/- .(LG,Samsumg or moserbaer).
Yes ! you can operate them normally as usual.
Only call your computer engg. to make connections or the shopman to fit the dvd and cd drive.
Jan 07, 2009 | HP Compaq Presario SR2150NX PC Desktop
No Sound when I play a DVD, but I do have sound when I play a Music CD
Open your sound controls to make sure nothing is muted or set on low volume.
If that's not the case, open your audio drivers program and check to see if nothing is muted.
Oct 22, 2008 | Computers & Internet
Front cover
Ca you please tell me what type of PC you have? Compaq, HP, Dell?
Thanks
Jack
Jun 13, 2008 | Compaq Presario 5BW284 (202493-003) PC...
Removing the faceplate
Hi, I can help you with this. Are you trying to remove the cd-rom drive bay plate or the front panel of the tower?
Sep 16, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
