Question about E-Machines eMachines Desktop PC
My emachines keeps shuting down - E-Machines eMachines Desktop PC
  • 30 Answers
1 clean the cpu fan
2 change power supply
3 change memory
4 reinstall windows
do this one at the time "do not vacuum the fan" blow with compress air.
still same well need a new motherboard in that case better get new pc.
Posted on Jul 29, 2010
NP350E7C-A01US samsung laptop windows 8 keep shuting down after 5 mint or some time 10 mint .
are you sure the cooling fan is working . sounds like a overheating problem t me
Feb 28, 2015 | Samsung Computers & Internet
Laptop continuously shuting down
Probably it's the cooling system, or maybe it's the motherboard...
You turn it on, and then it apears the screen with the laptop brand or something?
Apr 09, 2013 | Acer eMachines 520-2890 Notebook
My receiver keeps shuting down when i turn it on
Denon receiver has a common problem, keep shuting down after power button press, then red light blind. mostly, if none of amplifier output transistors blown, it must be IC7815 or IC7915 mulfunction, find it, replace it. then job down
Mar 16, 2011 | Denon AVR-1601 Receiver
Emachine w5233 keeps shuting down what can i do to fix this problem
Does this happen when you are in your operating system??? and there is prompt that a program or command is promting it shut down, if it is, then it is a viral issue and latest anti visrus needs to be scanned for. If not, then I belive it is a overheating promblem most likely with your CPU. Cpu now come with a technology to override to the computer to shut down when it becomes overheat to prevent it from damaging itself further. Check your cpu fan, you can do this by taking your panel apartby unscrewing two screws from the back of your left side door panel, you then will see the motherboard and inside it you will see a huge fan, try to clean it by blowing off the dust and debris, if possible take the fan out, and apply new termal compund and reesemble to fan back onto the cpu. Make sure it is tight and securely fasten on. You should be good to go, if it still shuts off byitself, then porbraly a bad motherboard, or cpu, which will need to be replaced.
Jan 21, 2011 | E-Machines eMachines Desktop PC
Machine keeps shuting down with message OE. Have
You should have an error code legend in your owner's manual. Check to see what "OE" relates to on the washer. If not in your manual, you should be able to determine what the code relates to via LG's website. You may need to contact an appliance service company.
Feb 20, 2010 | LG Washing Machines
I have a Hp laptop bt it is now not shuting down ie all its light on keep on glowing even on shutting down and also it makes a noise while shuting down or turning it on
remove charger first and remove battery second to try which one causing problem.
if any power source cause the problem that is mean the mainboard or power board inside failed.
good luck.
Nov 21, 2009 | Computers & Internet
KEEPS SHUTING DOWN AFTERYOU START IT
check the igniter, maybe it is not hot enough anymore. it needs to glow white not orange. if it is orange change it.
Oct 24, 2009 | General Electric DWSR463GGWW Gas Dryer
Laptop keeps shuting down at random.
This could be caused by MANY different things. If it is a random thing, where do you have your laptop when it happens? If it isn't on a flat smooth surface, it's probably a heat related issue. Laptops need a lot of air circulaton, through the bottom.
Jul 01, 2009 | HP Compaq Presario V2000 Notebook
I upgraded the BIOS and now my Presario V4000 keeps shuting Down
Try a system restore. If that doesn't work download and revert back to the old bios.
Jun 20, 2008 | HP Compaq Presario V5000Z Notebook
E-Machines eMachines Desktop PC Logo
96 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
