I have tried all solutions and still the black box covering my screen will not go away. 1)Can you give me another suggestion and 2)Can you send me the manual for my remote which you have both model #s. Thanks.
  • memeagher Aug 16, 2010
    This is the initial problem, so if you check all the colutions given to me that did not work, you will have all the info you need for model #s, etc.
    President:
  • 2,559 Answers
I don't have a list of what all you have tried but I can tell you that you can turn the black box off with the remote by pressing the CC button(closed caption) or turning it off in the settings menu, you can also use the PIP(picture in picture) button or settins to turn that off as well if it is PIP and not CC
Posted on Aug 17, 2010
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details of the problem and the brand/complete model number
Thanks for using FixYa.
Posted on Aug 16, 2010
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is...
First of all check your VGA cable is working or not.
If VGA cable is ok than do the following steps.
  1. Turn off all peripheral devices connected to the computer.
  2. Disconnect the computer's power cord from the AC power source (wall outlet or power adapter).
  3. Remove the computer cover.
  4. Locate the battery on the board (see figure below).
  5. With a medium flat-bladed screwdriver, gently pry the battery free from its connector. Note the orientation of the "+" and "-" on the battery.
  6. Wait for 1 to 5min then re-place the battery back again.
  7. Re-place the computer cover.
  8. Plug the computer and all devices back in.
Second step you can do is
1) Remove the RAM from the RAM bank clean it properly and insert it back again.
If still you are facing the same problem ... you can Remove the CPU fan and put some cooling paste on top of CPU and re-place the FAN back.
Jul 06, 2011 | LG Flatron L1710S 17" LCD Monitor
Often freezes-solved by sliding phone up and down several times restarts itself 3 buttons on keypad no longer work
Hi,the problem you are experiencing is as a result of a faulty flex connector cable,it's bad hence it can send signals properly from the board to the screen which results to freezing of the phone.The solution is to replace the flex cable.
Here is a detailed solution to assist you in disassembling your phone and replacing the flex conn. cable;
1.Remove your back cover, battery, sim and memory card. Remove the four screws you see behind the phone.
2.Run your plastic tool e.g credit card,around the join of the battery compartment to release it.
3.You will see a connector ,it needs to be disconnected. Just flick the black latch up and pull the ribbon out.
4.Now remove the two screws on the upper edge of the phone. Both screws will be covered with red stickers.
5.Now move the slide down and remove the three screws you can see.
6.Lift the circuit board to the side slightly to reveal a ribbon attached to the underside. The connector attaches like a plug and socket. Just lever it away from the circuit board to unplug.
7.Pull the slider down to access four more screws. Remove these. Now run your fingernail or your plastic tool around the join of the front cover. This will release the clips which hold it in place. The cover will still be attached near the top of the phone so don't try and force it off .
8.The camera cover should now be loose. Remove the two screws you can see. You can now remove the front cover.
9.With the front cover removed ,the navigation pad and the part that holds this in place will come away with the cover
10.Pull the screen away from the rest of the phone. The c connectors needs to be released. For each, flick the black latch up where the ribbon enters and pull the ribbon out.
11. You now need to separate the LCD and touch screen. To do so you need to slide something flat and thin (the edge of a guitar plectrum would be best) between the LCD and touch screen. Try to follow the dotted line and try not to push your plastic tool too far under the touch screen or you'll get a sticky residue on the underside of it. Applying some heat with a hair dryer may help loosen the touch screen.
12.You should now have the LCD screen and touch screen separated. Reverse the whole procedure for reassembly.
Thanks and take care
Jun 21, 2010 | Samsung Tocco Ultra Cell Phone
Black box on screen
That sounds like a text box. Press the cc button and keep pressing it. You will see different closed captions options on your screen each time you press the button. Finally when it says cc off stop pressing the button and you should no longer get the black box. If you have a cable box connected you may also have to disable the captioning on it.
Feb 12, 2010 | Sharp LC-19SB14U 19 in. LCD TV
A black box stay on the screen covering,
turn on closed captioning. this is the only way we have been able to save the tv. after a few days we were able to turn it off again and the black box was gone.
Dec 05, 2009 | JVC Televison & Video
Black box on JVC screen
a black box is covering my tv screen except for around the edges. I can use the dvd player, but i cannot watch cable. it is as though there is a security feature to block tv, but i cannot get it to go away!
Jul 11, 2009 | JVC AV-32D305 32" TV
Black box in middle of screen
Note that the large black box goes away when pushing buttons on the tv (ex: the black box will disappear to show the volume setting when changing the volume on the tv but it will cover the picture and the menu display of the dtv box).
This is caused by the closed caption setting of the television set NOT the captioning of the converter box. To fix this you must open your television's menu, find the ccd/closed caption option, and turn it off. This is a frustrating problem as when most people are told to shut off the captioning they try to do so at the box.
Normal dtv box captioning will appear as a small text box at the bottom of the screen as you would expect - not as a giant black rectangle that covers most of the screen. If you do want to shut this off too you will find that you can't do it through the usual menu options (the menu will only allow changes to font, color etc.) - there should be a ccd button on the remote that when pushed will scroll through ccd-1, ccd-2,... off.
Dec 01, 2008 | Toshiba MV13L2 13 in. TV/VCR Combo
Black Box on the screen
It sounds like a text box that isn't receiving any text. If it covers almost the entire screen, then you might have accidentally got the settings into DEMO mode. It could also be a box for closed captioning, but that usually covers just the lower part of the screen. Either way, the solution is to go into the setup menu and restore facotry presets.
Nov 27, 2008 | Toshiba 27A33 27" TV
Rectangular Black Box Covers Lower Half of the Screen
I found this because I"m having the EXACT same problem with my DVD. Very frustrating that nothing works....
Feb 10, 2008 | Sony DAV-C450 System
Some sort of box across the screen
Try to look at your captions on your tv...you probbally have them set on text 1 or 2 which cause the box to pop up also why it goes away when you push a button. Turn all caption functions of your tv off...cc and text this should take care of the problem.
Feb 05, 2008 | Panasonic DVD-S27 DVD Player
TOSHIBA tv
I had the same problem. A big black box in the middle of the screen that would temperarily go away if with the EDS button.
Go to the main menu and turn off closed captioning. It worked for me! :D
Sep 09, 2007 | Toshiba 27A34 27" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
