I will advice you try this steps to fix the problem,
Make
sure PS3 is connected via correct cable
Power Off the PS3 via the
power switch in back and power back on
with switch.
Hold Power Button on the Front until you hear 3 beeps. Your ps3 should
automatically reset.
I will suggest you also try this, 1.
Turn off Playstation®3.
2. Hold the power button down; the system
will turn on and turn off once again.
3. Once the System has been
shutdown, re-press you finger until you hear 2 consecutive beeps
4.
When you hear the 2 beeps take finger off power button.
5. You will
be prompted to plug in your controller via USB and then hit the PS
button
6. The Recovery menu will pop up.
The current Recovery
Menu supports:
Restart System: Restarts the PLAYSTATION®3 System.
Restore Default Settings: Reset all system settings back to default.
Restore File System: Checks for corrupt/missing system files. Rebuild
Database: Rebuilds the OS for the PLAYSTATION®3. Restore
PS3 System: Fresh restore; Deletes everything and starts from Scratch.
System Update: Update the PLAYSTATION®3 System. This should fix the problem.
Take care.
Yes that worked !
Thanks a lot!
