Question about Refrigerators
I have a recurring problem with the freezer freezing up and plugging the drain hole. i have defrosted and cleaned several times only to have it come back again. do you suppose the heater element is not functioning. not sure how to test this. i suppose this comes on during the automatic defrost cycle but not sure.
  • jogil411 Jul 29, 2010
    model# ET21GKXHW01. NOT SURE IF THERE IS ANY WAY TO TEST THE ACTUAL HEATING ELEMENT. HATE TO BUY ONE IF IT'S NOT DEFECTIVE.
    President:
  • 2,702 Answers
First check that the door seal is a good tight fit if hot wet air is getting into the freezer this is were all the frost is coming from also check the thermostat tem is not to hight,,
Posted on Jul 29, 2010
  • Michael Thorpe
    Michael Thorpe Jul 29, 2010
    hi its miket756
    to test the heater coil all you need is a lamp and a battery unhook the to wires that feed the heater and hook up the lamp and battery if the lamp lights the heater is ok,,,if you have an avo meeter hook that up if you get a reading again the heater is working ok,, only if you dont get a reading or the lamp dont light will that prove the heater is broken,,,i hope this is of better help to you, mike
Ice in the bottom of the freezer
Check the door gasket for a leak. Air entering past the gasket will form ice.
Sep 23, 2014 | LG LRBN22514ST Bottom Freezer Refrigerator
Why is water leaking out evey day???
Is the water leaking from the refrigerator compartment or the freezer compartment? Can we assume the "leaking" water is more than some accumulated humidity/moisture (check your door gaskets)? Have you checked all water lines/fittings for the water dispenser/ ice cube maker (if you have one)?
If it is is the freezer section, the problem may be a clogged drain line (is there ice blocking the trough drain hole?) at the bottom of the freezer (evaporator) coils? You may need to defrost the freezer, check for any faulty parts (e.g., defrost time/ADC, defrost thermo, defrost heater), and clean the drain trough/tube. See Refrigerator Defrost Parts for illustrations.
May 22, 2014 | Roper Refrigerators
Clogged drain plug
Happens to me too. The drain freezes, freezer floor freezes and then ice starts building up to the point where it forms in the fan area and then the blades hit the fan and it gets very noisy. In my case, the container that is supposed to carry the defrosted water to the drain has a electric wire running underneath and twisting around the drain hole. I believe this wire is supposed to heat up and melt the ice to stop the drain hole from freezing. I believe the heating mechanism has failed in my case and suspect the same for you. Until fixed, this will continue to freeze up every so often. Search for your LG freezer drain heating element or parts.
Mar 13, 2014 | LG Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Freezer is not draining when it defrosts because of ice plugging drain hole. Is there a solution to this problem?
I had a Maytag repairman tell me to take a piece of wire coat hanger, wrap it around the defrosting element into the drain hole. This keeps the drain hole from freezing up. It has worked fine for 6 months now!
Mar 31, 2010 | Maytag MSD2756GES Side by Side...
My Roper refrigerator collects water in both vegetable bins. Help!
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Jan 21, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
ET18NKXJW BY WHIRLPOOL, WATER IN CRISPER DRAWERS, SHELVES AND FREEZES FOOD IN BACK OF REFRIG. DRAIN HOLE FOR FREEZER ICED UP FROM TIME TO TIME.
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Dec 15, 2009 | Refrigerators
Condensation drain hose freezes - water drains into frig.
The problem is probably the drain itself. It is probably partially clogged. Another thing could be ice build up. I will usually get a peice of metal coat hanger a few inches long and I will hook it over the defrost heater and let in hang into the hole about an inch or so. That way when the unit defrosts that hanger will heat up and keep it from freezing.
Sep 07, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
MY GE PROFILE REFRIGERATOR IS WARM, FREEZER IS FINE.
i think its not the frz drain hole blocking up but a fault with the defrost tray heater. the tray heater should keep the defrosted frost as water to drain away. it sounds as though the tray heater is not working therefore letting the water freeze as it is escaping thorough the drain hole. i would check this out by defrosting the unit and inserting a flexi rod into the otherside of the drain hole (above the compressor usually) and after clearing it if it freezes up again check out the defrost/heater system.
Apr 08, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Hotpoint side-by-side freezer drain freezes
yes totally defrost unit and verify drain is not plugged, make sure drain is trapped. it may drain into a pan on top of compressor, where heat dissipated by compressor evaporates condensate. certain crosly model freezers made by w.c. wood co. have a problem with that.
Mar 30, 2008 | Refrigerators
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
