Question about HP Photosmart C3180 All-In-One InkJet Printer
Failure of Printer to Print Color
I cannot get my printer to access the color cartridge which I have replaced several times. I have checked all settings (I think!). It had been working fine since 2007 until a few months ago. I do use refilled cartridges.
Try using a new HP ink cartridge. I had the same problem with a printer I purchased off of CraigsList even though the ink level was good. I installed a new color HP ink cartridge and it printed without a problem.
Posted on Jul 30, 2010
H P Photo smart C4280 Will not print color/; Prt cartridge just replaced
After replacing the cartridges, printer performs align print are you check this page? any color print in that? If you found colors in align page, no problem with printer.> check print command in color or not.. > If no color print in align page, perform clean cartridges > check with another cartridge.> check trailing cable,carriage PCB & Formatter..
Dec 06, 2011 | HP Photosmart C4280 All-in-One InkJet...
Will not print in color
hi there,
try to access the dell all in one center. there's a link there that says maintenance. there's an option that says clean to fix horizontal streaks.
then try to print again.
if still same. try to remove the color ink. remove the power cable of the printer. using a clean cloth, wipe the contacts of the copper strip inside the color cartridge carrier where you put the color cartridge. also clean the copper strip of the color cartridge.
if still same. try to uninstall/reinstall the printer driver.
if still same. 3 points of failure
1. cartridge problem again. most probably bad cartridge batch 2. printer driver issue. 3. printer itself.
Oct 01, 2009 | Dell A920 InkJet Printer
Printer printing out wrong color. i have cleaned the cartridges several times, checked to make certain tape is off. How do I configure the printer to allow me to have access to the printer service to...
Print a test page. if that is ok, then it could be the color profile you have selected. Also, you can make your own test pattern of Yellow, magenta, and cyan. (use mspaint and make 3 colored bars, a black bar, and a white background). Print that, and see if all 3 colors and black are printing. If one color is not printing (ie, yellow for example) then there is an issue with that printer head on that cartridge. If you are recycling the carts, then that cart needs replaced.
Aug 28, 2009 | HP Photosmart C3180 All-In-One InkJet...
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Printer won't print color only black and white
    Reinsert the color cartridge. Give print command for page. Open Preferences in print window. Open the Color tab. Click on Print in Color. (It may have been set for black only.) Try printing.
    May 23, 2008 | HP PhotoSmart C4180 All-in-One Color...
    Color cartridge problem
    Check the color side of the carriage....there is a metal piece in there that breaks free from the side and will "stab" the circuitry board that the cartridge comes in contact with...you will probably see a hole in it...I have replaced several print carriages...fairly common problem with all of the HP printers that use the 96 and 97 cartridges...hope this helps
    Apr 30, 2008 | HP OfficeJet 7410 All-In-One InkJet...
    Replaced Color Cartridge, now printer will not print in color.
    You need to check if the color cartridge that you received is not dried up from the time you received it. You can try and perform a nozzle clean test from the Dell All In One Center (click on Maintenance and you have several tests to fix various issues regarding ink).
    If ink was bought from Dell contact them, as they sort out most of the issues.
    Mar 16, 2008 | Dell 922 All-In-One InkJet Printer
    HP DESKJET 1180C
    HP Deskjet 1180c and1220c Professional Series Printer and HP Deskjet 9300 and 1280 Printer - Troubleshooting a Blinking Print Cartridge Light Introduction The Print Cartridge light continues to blink with both cartridges properly installed and the Access Cover (also known as the top cover or lid) closed. Instructions The blinking Print Cartridge light may be caused by a faulty cartridge, the plastic case of the printer being dislodged or slightly out of position (which prevents the Access Cover from seating properly), the Access Cover sensor (also known as the top cover sensor or lid sensor), or by the actuator on the Access Cover. Follow the steps below to resolve the issue.
    1. With the printer turned on, open the Access Cover. The carriage will move out of the capping station and stop at one of the cartridge status icons located inside the printer under the Access Cover. The yellow arrow on top of the carriage will point to one of the cartridge status icons to indicate a good, empty, or faulty cartridge. See Figure 1 below.
      1. If the carriage stops in the cartridge’s OK position, indicated by the happy face in Figure 1, continue with Step 2.
      2. If a problem is indicated with one of the cartridges, remove the cartridge and verify that the cartridge part number is correct. The black cartridge part number is 51645A and the color cartridge part number is C6578A or C6578D.
      3. If the cartridge part number is correct, clean the electrical contacts on the cartridge with a soft, lint-free cloth. Do not touch or wipe the nozzle plate.
      4. If a faulty cartridge is still indicated after verifying the cartridge part number and cleaning the contacts on the cartridge, replace the cartridge.
      5. After replacing the cartridge, turn off and then turn on the printer to clear the cartridge error from the printer's memory. If the cartridge error cannot be cleared, the printer will require repair. If the carriage stops in the cartridge’s OK position, indicated by the happy-face in Figure 1, continue with Step 2. NOTE: The printer checks the status of both print cartridges before printing. Both the black and color cartridge must be functional and installed in the printer in order to print.
      Figure 1: Cartridge status icons c00001225.jpg Icon/Drawing Problem identified by the symbol Solution c00001226.jpg The color cartridge is missing, improperly installed, defective, or the wrong print cartridge is installed. 1. If there is no color cartridge in the cartridge cradle, insert a color cartridge.
      2. If there is a color cartridge in the cradle, remove the color cartridge and firmly reinsert it.
      3. Check to make sure the color cartridge is appropriate for the printer.
      4. If the problem persists, replace the color cartridge. c00001227.jpg The black cartridge is missing, improperly installed, the wrong print cartridge, or is defective. 1. If there is no black cartridge in the cartridge cradle, insert a black cartridge.
      2. If there is a black cartridge in the cradle, remove the black cartridge and firmly reinsert it.
      3. Check to make sure the black cartridge is appropriate for the printer.
      4. If the problem persists, replace the black cartridge. c00001228.jpg The color print cartridge is running low on ink. Replace the color print cartridge with a new color print cartridge. c00001229.jpg The black print cartridge is running low on ink. Replace the black print cartridge with a new black print cartridge. c00001230.jpg None. The print cartridges are working correctly. None. The print cartridges are working correctly.
    2. Close the Access Cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, remove the Access Cover by following the steps below:
      1. Open the Access Cover and hold it open.
      2. Dislodge the Access Cover from the hinges with a sharp blow to the hinge area of the Access Cover and then remove the Access Cover.
    3. Install the Access Cover by following the steps below:
      1. Align the hinges on the Access Cover with the hinge pins on the printer.
      2. Push down firmly on the Access Cover until the hinges snap into position.
    4. Close the top cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, the printer case may be dislodged or slightly out of position. To restore the printer case to the proper position, squeeze the printer by applying pressure to the front and back pressure points shown in Figure 2. Figure 2: Pressure points c00006497.jpg Firmly squeeze the pressure points on the printer case as shown in Figure 3. If the Print Cartridge light continues to blink, continue with step 5. Figure 3: Squeezing the pressure points c00006498.jpg
    5. If the Print Cartridge light is still blinking, push down firmly on the center of the Access Cover (the extra pressure may engage the sensor). If the Print Cartridge light quits blinking, remove the pressure from the Access Cover to see if the Print Cartridge light starts blinking again. Re-apply the pressure to the center of the Access Cover to see if the Print Cartridge light stops blinking again.
      1. If the Print Cartridge light quits blinking with pressure applied, the Access Cover is faulty and should be replaced.
      2. If the Print Cartridge light continues to blink even with pressure applied, the Access Cover sensor may be faulty and the printer will require repair.
    Oct 18, 2007 | Office Equipment & Supplies
    HP Photosmart C3180 All-In-One InkJet Printer Logo
    138 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
