Question about HP L1506 15" LCD Monitor
HOW TO SOLVE OSD LOCKOUT - HP L1506 15" LCD Monitor
  • 11,361 Answers
  • 296 Answers
SOURCE: what does osd lockout mean and how can i fix it?
on the front of your monitor find the menu button....hold it in for 10 seconds. This should fix it.
Posted on Mar 20, 2010
SOURCE: How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Posted on Jan 20, 2010
  • 62 Answers
SOURCE: OSD LOCKOUT
1. Replaced the Micro switchs.
2. press the menu switch 15 to 20 secunds.
Posted on Nov 03, 2008
SOURCE: osd lockout
hold the MENU button for ten seconds to unlock or lock the OSD
Posted on Aug 19, 2008
  • 156 Answers
SOURCE: HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Posted on Nov 30, 2009
Monitor display says OSD Lockout /no signal input how to fix this?
This document pertains to LCD monitors .
One of the following messages appears on the screen (over the items being displayed).
OSD Lockout
OSD Lock-out
... or similar message.
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work.
To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Aug 31, 2013 | Dell Computers & Internet
Brightness/contrast locked
All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on-screen display (OSD) lockout that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lockout setting, there are several ways you can remove the lockout.
Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout. Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears. Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings. Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
Mar 02, 2013 | Dell Inspiron 580 Desktop Computer...
OSD Locks Automatically
hope this helps
Jun 07, 2012 | HP Computers & Internet
What does osd lockout mean and how do i get the box off my computer
Lockouts occur when the software driving the OSD encounters a problem or conflict--akin to your PC's operating system freezing.
Follow this link for more info: http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
Basically you have Four options to solve an OSD lockout.
Fix One: Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
Fix Two:
Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
Fix Three:
Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Fix Four:
The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
Good luck and thanks for using FixYa.
Feb 22, 2011 | HP w1907 LCD Monitor
Osd lockout
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | HP w1907 LCD Monitor
Jan 20, 2010 | HP L1940T 19" LCD Monitor
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
Dec 03, 2009 | HP W1707 LCD Monitor
Osd lockout
If you encounter an OSD Lockout error with your monitor simply try the fixes on this page:
Mar 27, 2009 | HP w1907 LCD Monitor
One of the buttons on the monitor doesn"t work
To solve an OSD lockout problem just follow one of the four fixes on this page:
Jan 30, 2009 | HP w1907 LCD Monitor
Osd lockout--can not control monitor
if u hold the menu button for 10 seconds it will be unlocked.
Sep 19, 2008 | Computers & Internet
HP L1506 15" LCD Monitor Logo
734 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
