Question about Coby MP725Digital Media Player
How do I erase all files and start over - Coby MP725Digital Media Player
  • 6,826 Answers
Remove files from MP3 player http://www.cobyusa.com/?p=faq Connect the USB cable to your MP3 player, then hook the other end to a free USB port on your computer. Double-click on the MP3 player’s icon to view the music files stored to memory. Scroll through the list of files until you find the ones that you wish to delete. Click on single items you wish to delete. Right-click on the highlighted files to pull down an action list and from there select -Delete. The computer will ask if you really want to throw the file away. Select OK. Exit from the window, then disconnect the USB cable from the MP3 player. The player will automatically turn off. The memory will update the first time you turn the player on after deleting songs.
Posted on Jul 29, 2010
How do I delete a recording off my Sony Sony - ICDBX140 - 4GB
  1. Slide the HOLD?POWER ON/OFF switch in the direction of "POWER ON/OFF" to turn on the IC recorder, or towards the center to release the IC recorder from the HOLD status. The stop mode window appears.
  2. Select the file you want to erase when the IC recorder is in the stop or playback mode.
  3. Erase a selected file. When the IC recorder is in the stop mode, press and hold ERASE.
    When the IC recorder is in the playback mode, press ERASE.
  4. Press ERASE. "ACCESS" appears in the display window and the selected file will be erased.
    When a file is erased, the remaining files will advance so that there will be no space between files.
Hint
  • To cancel erasing, press souni_stop.png(stop) in step 3.
  • To erase a part of a file, divide the file into two files first, and then proceed with steps 3 through 4.
Mar 10, 2015 | Sony Video Cameras
Olympus DS-30 recorder: memory is full but there are no files to delete
1.Press the FOLDER button to choose a folder.
Every time the FOLDER button is pressed, it cycles through folders and the List display will appear (+P20).
Press the + or button to choose the file you want to erase.
Press the ERASE button. The “Cancel” indicator flashes.
Press the + button to choose “Erase”.
5
Press the OK button. The display changes to “File Erase!” and erasing will start. “Erase Done” is displayed when the file is erased. File numbers will be reassigned automatically
Apr 04, 2008 | Olympus DS-30 Digital Voice Recorder
Hi i own a RCA digital voice recorder model# rp5030A i can not figure out how to delete recordings
Erasing selected file
You can delete a file by the following steps:
1. Select folder (A, B, C , D or )
2. Select file.
3. Press ERASE once and DELETE will blink on the screen.
4. Press and hold ERASE for 3 seconds to confirm deleting. (or press STOP to cancel erasing file)
Erasing all files in a folder
You can delete all files in a specific folder by the following steps:
1. Turn on the unit.
2. Select a folder (A, B, C , D or ).
3. In Stop mode, press FORWARD continuously until "ALL" appears on the display.
4. Press ERASE and "DELETE" will blink on the display.
5. Press and hold ERASE for about 3 seconds, all files in the selected folder will be erased completely (or press STOP to cancel erasing all files).
Tip: File numbers that come after erased one will be moved forward by one automatically.
See page 12 for more info: http://www.rcaaudiovideo.com/docs/common/RP5030/RP5030_OM.pdf
Dec 29, 2012 | RCA RP5030 Digital Voice Recorder
Hello i have a problem with my nokia 3110c whitch is : when i flash my phone with phoenix i got this result : Flashing started Creating product data items list Product data items list created Backup...
Now what is the condition of the phone ? If the phone has still problem, uninstall the previous file you have installed and re-install this one3110c file.Select the product code 0544311 or 0556977.This two files can use universal.Use fully charge battery or insert charger when message prompt.I hope there will be no error.Thanks good luck.
Aug 16, 2011 | Nokia N70 Cellular Phone
How do I delete the recordings on the vr5220 digital voice recorder? Step by step
To erase files or bookmarks, while playback is stopped:
1. Press x once.
2. Press '<< / >>' to select one of the erasing options:
  • Delete the current file (DEL 01)
  • Delete all files in the current folder (DEL AL)
  • Format the memory of the player (FORMAT) (Caution! All data inside the memory will be erased)
  • Delete all bookmarks in the current file (DEL BK)
3. With one of the above options selected, press and hold x for about 3 seconds to confirm your selection and start the deletion.
  • File numbers that come after erased one will be moved forward by one automatically.
  • Press to cancel erasing all files. The undeleted files are saved automatically.
  • Formatting the internal memory may be required when encountering compatibility problem, etc.
  • You may also format the player when connected to a PC (by right-clicking on the player's drive name or letter and select "Format" from the menu). Make sure you select FAT or FAT32 as the file system.
Jan 02, 2011 | RCA VR5220 Digital Voice Recorder
How to delete on RCA VR5220A
Erasing Files and Bookmarks:
1. Press x once.
May 03, 2010 | RCA Audio Players & Recorders
Lost manual can't ERASE RP 5010 recorder by RCA
folder
2. Select a folder (A/B/C/D).
continuously until “ALL” appears on
the display.
4. Press ERASE and “DELETE” will
Apr 07, 2010 | RCA RP5010 Digital Voice Recorder
I need to delete a recording
2. Select file.
3. Press ERASE once and DELETE will flash on the screen.
2. Select a folder (A, B).
3. In Stop mode, press FORWARD continuously until “ALL” appears on the display.
4. Press ERASE and “DELETE” will flash on the display.
Aug 14, 2009 | RCA RP5010 Digital Voice Recorder
Madame, Sir, I subscribed for CorelWindvd9 after a month trial. I payd 29 ? for it, but I cann't open the programm. An additionnal key is asked after de seriesnumber is submitted. I deleted all of the...
Hello and welcome to FixYa . In order to re-install WinDVD 9, remove all traces of WinDVD manually only delete the folders if they exist, and if allowed.If you cannot delete a folder, try renaming the folder by adding .old to the name of the folder. You will need to show hidden files and folders on the computer on XP go to Start, All Programs, Windows Explorer,tools, Folder Options, View, Hidden files and folders, Show hidden files and folders. Using windows Vista Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, Control Panel, Appearance, Personalization, Folder Options, View, advanced settings, Show hidden files and folders, OK. The following folders will need to be erased.
Go to My Computer Use Start button, or on the Desktop. On Vista, Computer. Double click on C: drive, Documents and Settings and the folder named after your username.
When you reach the "InterVideo" folder, there will be a DVD9 folder, which is the one you are looking to erase. Note -This folder may be named Corel\DVD9 instead of InterVideo\DVD9 Erase the following folders Go to C:\Program Files\InterVideo or Corel delete the folder DVD9 Go to C:\Program Files\InterVideo\Common delete the folder Bin Go to C:\Program Files\InstallShield Installation Information delete the folder {E3993D46-AE3F-402E-9F9D-EEBDFBEC3564} Go to C:\Program Files\Common Files delete the folder InterVideo Go to C:\Program Files\InterVideo\Common\ delete the folder Bin The second place to remove WinDVD 9 settings is in the registry.
Go to Start, Run type in regedit click ok. left hand column will be a list of items double click on HKEY_CURRENT_USER double click Software and InterVideo At the very end, when you reach the InterVideo folder,erase the DVD9 folder, by right clicking on it, and hitting Delete. Erase the following HKEY_CURRENT_USER\Software\InterVideo delete DVD9 HKEY_LOCAL_MACHINE\Software\InterVideo\ and DVD9 HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall and {E3993D46-AE3F-402E-9F9D-EEBDFBEC3564} Restart the computer. Go to Start Run type in "%temp%" and hit Ok. Erase as many files as possible .In the "Edit" menu, click Select All, go to the File menu click delete.Say yes to delete Reinstall your software and it will accept your key. Hope this gets you going. Please Rate Me. And you can always Ask Me.aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Apr 27, 2009 | Corel WinDVD 9 Full Version for PC
I have a Digital Voice Recorder DS-2....how do I erase an item???
Press the FOLDER button to choose a folder. Press the FF or REW button to
choose the file you want to erase. Press the ERASE button. CANCEL” is flashing.Press the down arrow button to choose the
START”.
START” is flashing. When the up arrow button
is pressed, it will return to the flashing display of Cancel.
Press the MENU/SET button
while “START” flashing.
The display changes to “FILE ERASE!” and erasing will start.
“ERASE DONE” is displayed when the file
is erased. File numbers will be reassigned automatically.
Apr 01, 2009 | Olympus Audio Players & Recorders
Coby MP725Digital Media Player Logo
23 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
