Question about Cuisinart DCC-1200 Coffee Maker
Coffee overflows onto the counter from time to time. Have a clean gold filter. It seems that the coffee doesn't flow threw the lid as fast as it used to. How do I clean inside the coffee pot lid? There seems to be build up in there.
  • 396 Answers
I believe your problem is the filter basket holder is not seated correctly or the carafe is not completely inserted in the unit to push the brew pause lever up. The brew pause feature which stops the coffee from going into the carafe when you want a cup of coffee before the brew cycle is done. When you remove the carafe a spring lever stops the coffee from dripping into the carafe. When the carafe is inserted it must push the spring lever up to allow the coffee to flow into the carafe. If it is not the coffee will overflow and make a mess. The filter basket holder should be firmly seated in the unit so it will not have any play in it. Cuisinart recommends using a vinegar and water mixture but BrewRite Cleaner (Sodium Carbonate) available in the coffee section at Wallmart, Kamart and Target is fantastic. You can clean your carafe with BrewRite Cleaner and hot water by letting it soak a few minutes and rinsing. I will also clean your filter basket holder by soaking it as well and all your coffee residue will be gone with no scrubbing.
Posted on Jul 29, 2010
  • larrylabazio
    larrylabazio Apr 16, 2013
    thank you, i cleaned everything than pushed the filter basket holder all the way down and everything worked fine
We had this problem as well. It turns out that we had coffee grounds stuck in the lid. The pouring mechanism in the lid is actually a little complicated. I was able to clean out the path the coffee takes from inside the carafe up through the lid with Q-tips and a lot of water.
Posted on Dec 20, 2010
  • 2 more comments
  • MTKA7 Jan 14, 2011
    It worked! Thank you for your advice, I thought it was leaking out of the back of the unit, when all along it was grounds stuck in the lid of the carafe. What a simple fix!
  • shoro Jan 14, 2011
    Glad I could help somebody else with the same problem!
  • pamperedann Feb 27, 2011
    we've had our coffeemaker about 3 years. lately it's been pouring coffee all over the counter. i've cleaned EVERYTHING, checked lids, basket seating, cleaned with vinegar. seems it runs about the first 30 seconds out, then the rest starts going into the carafe like it should. any clue on this one?
  • Helen Magnuson Jul 06, 2012
    Same problem here. Ended up using Q-tips, proxy brushes and a toothpick to clean out the coffee grounds/paste that had formed inside the lid. Thanks for the tip!
My DCC 1150 Cuisinart coffee maker brews the coffee ok but when the brewed coffee comes out to the top of the pot most of it goes over the edge and onto the counter.
Posting this answer again b/c it sounds to me like your coffee is flowing over the lid of the pot, not the edge of the basket/water chamber. Coffee oils build up inside the lid. You have to clean it with a pipe cleaner or a bottle cleaner (like the ones that come with Dr. Brown's Natural Flow bottles - they look like a mascara brush but the bristles are clear). It will be clear how much build up you are getting out as long as your pipe cleaner/bottle brush is a color lighter than coffee. We have to do this about every 8-10 weeks. This is one of the weaknesses of this coffee pot - the lid, even if you rinse it regularly after you brew coffee, gets coffee oil build up inside of all the little holes that allow the coffee to flow in and pour and stay hot. I wish Cuisinart had made this lid so that you can open it to get to all the parts - but alas they didn't.
Mar 24, 2015 | Cuisinart Coffee Makers & Espresso...
Overflow in basket
Steven, I think it`s not the filter or the coffee just that more water is flowing into the basket then it can process. I would try lesser quantity of water first to see if it overflows. Try first with filter only and then with coffee. And before you do all that, your machine should be under warranty and may be returnable to the store. Do that and save the trouble of fixing it.
Mar 22, 2014 | Black & Decker CM1050B
DCC-1200 leaks coffee onto carafe and warmer plate
My coffee pot was leaking over the carafe and onto the warmer. I found that this issue was caused by the carafe lid. The lid was not allowing coffee to flow into the pot fast enough. I removed the inner mechanism from the carafe lid (it pops off really easily) and just sit the lid on top of the pot while brewing, and no more leaks! After brewing, I put the mechanism back onto the lid and twist lid onto the pot.
Nov 16, 2012 | Cuisinart DCC-1200 Coffee Maker
My basket always overflows, the water doesn,t empty fast enough
Here is the SOLUTION(S):
1. Buy a sprayhead that restricts the flow2. Let the water flow through for a few minutes, then lift the lid while it flows through.3. Don't use Decaf4. Plug up a couple holes on your current spray head
Mar 24, 2012 | Bunn BT10B Coffee Maker
While the coffee is brewing without using the grinder feature, coffee overflows onto the counter. About 1/2 of the coffee goes into the pot while the rest spills over. I have cleaned residue from the lid...
overflow problem possible causes: 1) water is over the "10" marker, 2) no filter in basket 3) too much (or too fine) of coffee in the basket -- does not drain. Also make sure the "spring" on the bottom of the basket is not stuck (the one that lets you remove coffee carafe without dripping coffee.
Jan 17, 2011 | Cuisinart Thermal DGB-600 Grinder
The cuisinart repeated;y clogs and sprays water
The two most common reasons for overflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Sep 07, 2009 | Cuisinart DCC-1200 Coffee Maker
Lately whether I put in pre-ground beans or whole beans, 1/2 the pot while dripping, leaks all over the counter, Help!
If water is leaking from the very bottom of the machine, your unit is broke and you need to call Cuisinart. If it is just overflowing the caraffe/basket:
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Aug 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I clean it everynight but it still leaks coffee grins and coffee all over the place...this is the second coffee maker of its kind that i have had and they both have done the same thing. This only happens...
Jul 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Over flow grounds without a cause
I have had two of these machines (warranty return) and they both did the exact same thing. Here is what I have discovered the problem to be.
The lid for the carafe gets stick and internally jams. As another poster suggested clean it thoroughly (this sometimes works). I have another solution. Call 1-800-726-0190 and explain that you lid jams and leaks all over your counter. They will send you an new lid for free no questions asked. They obviously are very aware of this situation and don't even ask for proof of purchase or purchase date.
Jan 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DCC-1200 Coffee Maker Logo
2,294 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
