My printer is saying paper jam but there isnt any thing, what can i do to fix this?
  • 906 Answers
Good day, please tell me the information of your printer. what is the brand and model type.
thank you.
Posted on Jul 30, 2010
Message in the screen add paper
The best thing you can do is read the manual first, it explains all these things. Just in case: That is telling you to put more paper in or it will quit printing. Try these links:
Canon printer says its out of paper when there is paper
The printer keeps saying its out of paper and its not not sure if paper is... My printer says paper is jammed when it isnt HP Printer keeps saying to add paper but it in
May 30, 2016 | Office Equipment & Supplies
The printer is now saying paper jam and there isnt one
Open the back door pf the printer and look for a black plastic lever.That the paper sensor wich may be damaged and it is saying to the printer there is a paper jam.
Nov 01, 2010 | HP Officejet 6500 Wireless All-in-One...
My printer isnt feeding paper in straight and it keeps on jamming and saying that there isnt any paper.. is there anything i can do to esay fix it???
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Oct 25, 2010 | Office Equipment & Supplies
Says paper jam but there isnt one
off your printer and manually feed paper by turning roller as guide, observe if sensor key freely move when paper pass, some sensor key stock when forcefully remove the jam paper inside.
Apr 05, 2010 | HP LaserJet 1020 Printer
Canon PC735 copier, paper jam light keeps coming on but there isnt any paper or anything blocking the machine. Tried resetting but nothing has worked. What can I do?
My canon copier pc735 says we have a paper jam- but it does not. We just replaced the cartridge and it wont work. I had them send me a new cartridge, but its the same thing- paper jam. Help!
Oct 10, 2009 | Office Equipment & Supplies
Paper jam, but no paper..
could be a hard ware problem..check your warranty
Apr 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Problem with paper jam, but no paper..
1) there should be problem of interference of another signals.
Paper jam indicator keeps appearing and there is no jam.
SOMETIMES THE PRINTER WILL READ THAT IT HAS A JAM IF SOMETHING LIKE THE INK ISNT CLICKED IN TIGHT OR SUCH. IM SURE YOU MIGHT HAVE TRIED UN PLUGGING IT FROM ITS ACTUAL POWER SUPPLY BUT IF YOU HAVENT I WOULD TRY THAT, IT COULD RESET THE WHOLE THING. IF THAT DOESNT WORK I WOULD JUST GET THE PRINTER IN GOOD LIGHT AND OPEN ALL COMPARTMENTS, THERE COULD BE THE SMALLEST PIECE OF PAPER JAMMED SOMEWHERE YOU CANT SEE OR WOULDNT EXPECT THERE TO BE ONE
Jan 09, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer says "Remove paper jam"
check that the paper tray is set to match the paper your printing - look also in the printer driver settings for the correct size. A4, Letter etc.. If that did not fix it make sure the paper take-up roller isnt worn.
Jan 20, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
Marvin
Marvin
