I have an lg air conditioning unit model no mc18ahr art cool it tries to start then shuts down on the indoor unit it flashes ch 60
  • 1 more comment
  • deb_carringt Jul 30, 2010
    We have 4 indoor units running off 1 outdoor unit. They are all LG MC 18 AHR. They are all flashing CH 60. Can any
    There are 4 indoor units running off one outdoor unit. They are all LG MC18AHR units. They are all flashing CH60.
    No the compresser is not already running.
    There is one bleep when switching unit on.
    The units were purchased in Spain about 3 -4 years ago.
  • 15,935 Answers
Can you explain more what is happening when the unit shuts down?
Does the compressor kick on before the shutdown?
Are there any audible beeps?
Is the compressor already running when it shuts down?
When and where did you purchase the unit (including country)
Thanks!!
Posted on Jul 29, 2010
What does the code on the screen mean flashes between ch and 05 ?
CH 5 on these units indicates a communications error between the indoor and outdoor units. Generally, it will require a replacement outdoor board assembly to repair it. Lookup LG parts on the internet or ring them for your nearest Agent or parts. 800 243-0000
Oct 15, 2016 | LG Art Cool LA181CNW Split System Air...
Error code ch 05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Feb 03, 2011 | LG Art Cool LA181CNW Split System Air...
LG air conditioner 24awn error code message Ch 6 inside fan runs outside unit not working
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
Dec 13, 2010 | LG Art Cool LA121HNP Split System Air...
CH 5
This is a Comms error, you may have had a power spike/voltage drop/power cut. Or a wire has been broken but this is unlikely.
I would suggest turning the power off at the indoor unit by the isolator, and also the power at the outdoor unit. leave off for 10 minutes, turn on isolator on the outdoor unit and then the indoor unit. Then start the unit up.
If the problem persists you may have a fault with the unit and a A/C contractor would be required.
This is a common call for LG equipment, i get it all the time.
all the best
Jul 05, 2010 | LG Art Cool LA121CNP wall/window Air...
Lg ductless air conditioner is coming up with code ch 5
Communication between indoor PC and outdoor PC missed. Check that all connecting cables are good.
May 02, 2009 | LG Art Cool LA121CNP wall/window Air...
LG error CH 64
What is the model of the unit?
Apr 07, 2009 | LG Art Cool LA121CNP wall/window Air...
My lg air conditionater have on display the error ch 60. Do you know what is it ? tks Stefano, Italy
EPROMM ERROR - INDOOR P.C. Check indoor pc board for dry joints in solder. Probably have to replace the board.
Mar 25, 2009 | LG Art Cool LA121CNP wall/window Air...
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
LG MC07AHR and MA09AH1 do not heat!
What you have is two fans, one for the outdoors and one for the indoors.You indoor fan is not running and it is not a good idea to run your unit. There are several reasons for this fan not to be running, but the most common is that it is bad. AC mechanic or good electrician can check this out.
Nov 05, 2008 | LG Art Cool LA121CNP wall/window Air...
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
