When I switched on my new Toshiba Satellite Pro it says 'the computer restarted unexpectedly or encountered an unexpected error. Windows installataion cannot proceed. To install windows click OK to restart computer then restart installation' Must have done this about 10 times and I keep getting the same. Any ideas please? Thank you
    Novelist:
  • 150 Answers
This sounds like a corrupted XP installation or possibly a damaged hard-drive, either through a hardware failure
or through file system corruption.
(the last scenario is the most likely)
Windows uses write back caching to improve performance.
This means that data is not immediately written to disk, but
the writes are delayed until there is enough data to make
it worth while.
Also, the NTFS system uses transaction based data transfers,
which set a dirty flag, write the data, update the file indexing
structers (MFT) and then clear the dirty bit on a hard drive.
If a PC unexpectedly looses power, or if it is hard reset during
a disk access operation, the hard drive may be dirty or
corrupted. For this reason, reseting or powering down a PC
without going through a proper OS shut down is a very bad
idea.
The correct procedure is START ==> SHUTDOWN ==> options,
and let windows do its thing.
Having said that, the NTFS file system is very robust, with
transaction logging and indexing redundancy, such that
it usually recovers from such events, by automatically
scanning and repairing the hard drive's index structure
when the system is re-booted.
For some reason, this has not happened on your machine,
and for some reason, windows is trying to re-install itself.
This may be due to and automatic recovery partition and
utility built into your computer. Most modern laptops have
a small, hidden HD partition, on which they store a rescue
copy of the operating system, along with some diagnostic
and recovery utilities.
This recovery mode is often activated by a special button
(such as the IBM BLUE BUTTON) or a bypressing a special
key combination during start-up.
1) Try completely powering down and restarting your machine.
Wait a couple of minutes after power down, then physically
remove the battery.
2) Wait a couple more minutes, put back the battery and
restart the machine.
3) If this does not help, you have one of the following:
a) Damaged operating system / aborted re-installation
b) Damaged file system through improper shut down
c) Hard drive failure
d) Bad settings in the BIOS or within the BOOT.ini file
causing the system to boot from an incorrect hard drive
or partition. (but this is unlikely)
At this point you need to call tech support for model specific
instructions on operating system recovery.
Martin
Posted on Apr 24, 2008
    Genius:
  • 2,785 Answers
Reinstall your operating system
I had to factory reset my tablet and after it factory reset it shut off and when it turned on again it said 'the computer restarted unexpectedly or encountered an unexpected error.
Help laptop wont start after resetting factory settings - Acer ...
www.tomsguide.com/.../77186-35-help-laptop-wont-start-resetting-facto...
Mar 25, 2012 - 5 posts - ‎2 authors
i restored my laptop back to factory settings as it kept crashing, now when i ... TVs · Cameras · Smartphones · Tablets · Software · 3D Printing; More ... or encountered an unexpected error, windows installation cannot ... then restart the installation... i do this and its just repeating itself, i have no recovery discs.
"The Computer Restarted unexpectedly or encountered an ...
heresjaken.com/the-computer-restarted-unexpectedly-or-encountered-an...
Feb 1, 2013 - Now your computer will restart and continue on the Windows setup process ... THOUGHT MY 1000 DOLLARS COMPUTER HAD CHRASHED AND .....setup experienced an unexpected error" To install windows, restart the installation. .....JUST fyi - I had a similair problem on a Surface Pro 3 tablet and this ...
encountered unexpected error when going to factory reset ...
h30434.www3.hp.com > Laptop & Notebook > OS/Recovery
Jan 13, 2016 | Computers & Internet
I did a factory reset on my toshiba satellite model number PSLC8U-03701Q laptop and after the reset a box is coming up stating..install windows The computer restarted unexpectedly or encountered an...
When you reset ...you need to reinstall windows...you will probably have a boot partician on your hard drive or if you have the disc reinstall
Sep 08, 2014 | Computers & Internet
My new acer aspire 7560-sb416, Windows 7 laptop won't boot. Error: "the computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install...
Try pressing F8 whilst booting to get into safe mode, if this will not work your only option may be to restore to factory settings either from the hard drive partition or from a Windows 7 DVD.
Aug 25, 2013 | Computers & Internet
Trying to Re-install windows 7. Got the following error: "The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install Windows, click...
So was this the issue then? You can run the Windows Vista Upgrade Advisor to see if there are any compatibility issues that you may be having with hardware or software that would prevent an upgrade to Windows Vista.
I hope this helps.
Mar 28, 2011 | Microsoft Windows 7 Ultimate for PC
I did recovery manager. When it restart den it says ((The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install Windows, click ''OK'' to...
The previous windows installation is either damaged, or did not complete, it is asking you to put your windows disc in so that in can proceed with the installation.
The recovery manager must have damaged your windows installation
Sep 05, 2010 | HP Pavilion dv6000z Notebook
Satellite a300 wont install windows (brand new)
turn off the computer and disconnect the battery . wait like half an hour. put it back in you have to wait a few minutes for the battery to finish charging then turn it on . this should help. the menu will pop up after you type your password in .
Mar 15, 2009 | Toshiba Satellite A300-0CF035 Notebook
Computer restarted unexpectly or encountered an unexpected error
Seems like the preinstalled image is corrupt or there is a hardware problem. Contact Acer for the correct procedure since this is a new system. I could offer alternate methods if you have the Windows install disc, but it is best to contact the manufacturer as soon as possible so it is on record.
Dec 07, 2008 | Acer Aspire 5315 Notebook
I have a BRAND NEW HP Pavilion Notebook which I just switched on for the FIRST time. It has come up with an error message, ie: "The computer restarted unexpectedly or encountered an unexpected error....
Your windows installation CD might have become corrupt. Use a fresh CD and enter into BIOS settings to set Default Settings before installation.
Try & reply.
Sep 11, 2008 | HP Computers & Internet
Open Questions:
InstantHelp{[1'877'778'89'69]}Avira Antivirus Tech Support Number? For further detail call:1877_778_89_69.Avira Antivirus support number,Avira Antivirus Customer support number,Avira antivirus techsupport number,Avira antivirus technical support phone number,Avira helpline phone,Avira antivirus phone number,Avira antivirus customer suppot number. Avira Antivirus phone number. Avira Antivirus support number,Avira Antivirus Customer support number,Avira antivirus techsupport number,Avira antivirus technical support phone number,Avira helpline phone,Avira antivirus phone number,Avira antivirus customer suppot number. Avira Antivirus phone number. Avira Antivirus support number,Avira Antivirus Customer support number,Avira antivirus techsupport number,Avira antivirus technical support phone number,Avira helpline phone,Avira antivirus phone number,Avira antivirus customer suppot number. Avira Antivirus phone number. Avira Antivirus support number,Avira Antivirus Customer support number,Avira antivirus techsupport number,Avira antivirus technical support phone number,Avira helpline phone,Avira antivirus phone number,Avira antivirus customer suppot number. Avira Antivirus phone number. Avira Antivirus support number,Avira Antivirus Customer support number,Avira antivirus techsupport number,Avira antivirus technical support phone number,Avira helpline phone,Avira antivirus phone number,Avira antivirus customer suppot number. Avira Antivirus phone number. Avira Antivirus support number,Avira Antivirus Customer support number,Avira antivirus techsupport number,Avira antivirus technical support phone number,Avira helpline phone,Avira antivirus phone number,Avira antivirus customer suppot number. Avira Antivirus phone number.
Feb 27, 2017 | Computers & Internet
InstantHelp{[1'877'778'89'69]}Nortan Antivirus Tech Support Number? For Any query call us :-1-877-778-89-69 Nortan Antivirus support phone number,Nortan antivirus customer phone number,Nortan antivirus tech support phone number,Nortan antivirus technical number,Nortan antivirus tech help number. Norton Antivirus Support Phone Number, Norton Antivirus Customer Service Phone Number, Norton Antivirus Tech Support Phone Number, Nortan Antivirus support Helpline Number, Nortan Customer support Telephone Number.Nortan Helpdesk number,Nortan Tech support Telephone number.Norton Antivirus Support Phone Number, Norton Antivirus Customer Service Phone Number, Norton Antivirus Tech Support Phone Number, Nortan Antivirus support Helpline Number, Nortan Customer support Telephone Number.Nortan Helpdesk number,Nortan Tech support Telephone number.Norton Antivirus Support Phone Number, Norton Antivirus Customer Service Phone Number, Norton Antivirus Tech Support Phone Number, Nortan Antivirus support Helpline Number, Nortan Customer support Telephone Number.Nortan Helpdesk number,Nortan Tech support Telephone number.Norton Antivirus Support Phone Number, Norton Antivirus Customer Service Phone Number, Norton Antivirus Tech Support Phone Number, Nortan Antivirus support Helpline Number, Nortan Customer support Telephone Number.Nortan Helpdesk number,Nortan Tech support Telephone number.Norton Antivirus Support Phone Number, Norton Antivirus Customer Service Phone Number, Norton Antivirus Tech Support Phone Number, Nortan Antivirus support Helpline Number, Nortan Customer support Telephone Number.Nortan Helpdesk number,Nortan Tech support Telephone number.Norton Antivirus Support Phone Number, Norton Antivirus Customer Service Phone Number, Norton Antivirus Tech Support Phone Number, Nortan Antivirus support Helpline Number, Nortan Customer support Telephone Number.Nortan Helpdesk number,Nortan Tech support Telephone number.
Feb 27, 2017 | Norton Computers & Internet
Computers & Internet Logo
129 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
