Question about Haier Freezers
HF116AE Haier part
HI
I would like to buy a part fro my HF 116AE,Haier. I think its part number VC745001.
Can you plese help me?
Charles
Where is controller knob on freezer
Brenda, haier freezer control quite often front lower right corner, some may be behind freezer by compressor, check the links to see if you can find your model and manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://image.haier.com/manual/southeastasia/haier/freezer/chestfreezer/201203/P020120309357074931017.pdf
Haier Freezer manuals
Haier Freezer controls Google Search
Jun 12, 2016 | Haier Freezers
Haier hnse05vs circuit
1-877-337-3639 This is Haier Customer Service number in US
Nov 19, 2012 | Haier Hnse05vs -01 Freestanding...
Pleaaasse help my refridgerator has a side freezer and my freezer gos in n out sometimes it works but when i buy frozen food it seems to stop working it has ice build up and makes loud noises how can i fix...
Hello
Defrost the refrigetator, by open its door for at least 4 hours, and try. If it does not help you, the compressor is faulty, and it will be best fro you to buy a new one, rather than repair this, as it will cost more. OK.
Jan 30, 2012 | Freezers
Have a Haier 5.3 cu.ft. about 1.5 yrs. old. It freezes ok and cycles off ok, but it doesn't cycle back on unless I tap it near the control. If it doesn't call for more cooling it won't cycle on...
The thermostat is bad....
You will need to replace that t-stat..
That is not that hard to fix and you can easilybuy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
May 17, 2011 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Lost manual and need to defrost
This is likely a manual defrost freezer, which means you have to remove the food, unplug the unit, and let the ice melt on its own. Do not, and i repeat, DO NOT poke the ice away from the walls. I guarantee if you poke the ice away from the wall, you'll poke a hole in the wall, and force yourself to buy a new freezer.
SLOWER IS SAFER. put some boiling water, in the pot, inside the freezer, or use a hair dryer.
Sep 30, 2010 | Haier 4.5 cu. ft. / 127 liter Chest...
Temp Control
Hi!!
The higher the number, the colder the setting.
Rate this post, Good Day!!
Apr 26, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Portable ice maker not working as good as it did
Hi
Kindly refer to the Haier service manual which will help you for sure.
Thanks
Rylee
Jan 30, 2009 | Haier Freezers
Quit working -Haier Freezer
You have one of three issues here.
Either the thermostat has gone bad,
The thermal cutout has gone bad ontop of the compressor,
or the capacitor is out for the compressor.
Take an hom meter and check the thermal cutout, it should read 0 ohms or "continuity" if it doesnt the cutout is bad.
The only real way to check the cap is with a cap meter.
as for the thermostat check it with a n hom meter to make sure you have good connections internal the thermostat.
If you have any other questions just let me know!
Mar 12, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezers Logo
50 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
