I'm trying to take back off of Whirlpool washer, not doing to well in doing this, I am trying to find where washer is leaking from. Starts leaking soon as I try to fill washer
  • 259 Answers
Ok. To start out. DO NOT take the back off.
Put any screws you removed back into the machine.
These machines are actually front service-able. I will list the order of dis-assembly for the most common whirlpool washers as follows:
-Removing two phillips head screws in the front bottom corners of the control panel, or the rear lower corners of the control panel. These screws usually go through the plastic end-caps into the top of the washer at a slight angle.
*NOTE for some Kenmore models it may be necessary to remove the endcap covers to expose the screws on the front of the console*
The most recent designs have no visible screws but instead are using spring clips under the left and right sides of the control panel that need to be depressed with a putty knife to release them.
Pull the panel forward and lift to disengage the tabs at the bottom. Flip the panel upwards and it will swing back out of the way pivoting on two plastic strips at the top back corners of the control panel.
-Next you will see one wire connector going into the top of the machine, this is actually your lid switch connector, disconnect it (all the rest of the wires will route behind the top of the machine, between the top and the rear panel).
-Now using a flat blade screwdriver pry the front of the two brass colored clips towards the rear of the washer (put tip of screwdriver into front most part of clip and press handle of screwdriver towards rear of machine). The clips should pop off the top pretty easily.
-Now you can open the lid and place a hand on the front of the opening and pull the cabinet forward. The entire front and side wrapper will come off the base platform and you can set it aside to gain access to the inside of the cabinet.
Check your pump that is located at the front bottom of the washer. This is usually white or off white in color with two hoses connecting to it. When these pumps leak, they will usually have a tell tale sign of water mark around the opening where it connects to the motor shaft. Be advise the pump is only held to the motor shaft by two spring clips, but if the pump has been leaking for some time it may have caused the motor shaft to swell inside the pump and be difficult to remove. You may have to use a pry bar are large flat bled screwdriver to dislodge it. If this has occured be sure to file the motor shaft down as installing a new pump on a rusted shaft will cause the new pump to fail very quickly. I even use my channel locks to squeeze the shaft to free up large flakes of rust all the way around the shaft paying close attention to the very end of it as that is usually the worst part.
Another common leak point is the hose that runs from the drain pump to the outlet of of the back of the washer.
Also inspect the clear rubber hose that runs form the side of the plastic outer tub up to the control panel where it connects to the pressure switch.
Good luck and if you have any more questions, get me the model number of the machine and please let me know!!
Posted on Jul 29, 2010
  • Robert DeStevens
    Robert DeStevens Jul 30, 2010
    How are you making out with this? Any questions on it?
Washer leaking water
Please be very careful, electricity and water don't mix. With that said try checking the hoses and make sure the hose clamps are secure. I have a Whirlpool washer and have had this problem among several other assorted problems. Glad I took out a service contract it more then paid for itself in the last two years.
good luck,
Marty
Jun 21, 2014 | Whirlpool Washing Machines
After wash is done floor is wet.
The water pump is the most common thing to cause a Whirlpool washer to leak. It is the very first thing I check when working on a Whirlpool washer leaking. First you need to take the case off. To do this, unplug the washer and take out the two screws that hold the control panel in place (one on each side, you may be able to see them in front, you may have to snap off two covers to see them or they may be on the back) then hinge the control panel up. Once its up, you should see a plug attached to the case with three wires - unplug it. Now remove the two clips on each side of the case under the control and lean the case over then slide it out of the way. Now start the washer and watch while the water is coming in. If the pump starts leaking replace pump.
HOPE THIS HELPS YOU WITH YOUR PROBLEM...PLEASE LEAVE ME A COMMENT...Thanks...Jim
Feb 13, 2011 | Maytag PAV2300 Top Load Washer
I have a Whirlpool Duet Sport washer, model WFW8300SW02. It is leaking water from the tub. The leak is dripping down the back of the concrete frame that surrounds the tub. I detect no tears in the...
with what you describe i would have to say its a hose. fault as you say there is greater amounts of water when the tub starts up this would widen a rip in the hose or increase looseness
Dec 21, 2010 | Washing Machines
Leaking water when washer begins to load water.
Fist place to check is the outlet hose at the back of the machine it will leak as soon as water enters the tub, see if is leaking there, if it is you just have to tighten the clamp . if not there are a few hoses inside of the machine that may need clamps tightend also. The motor is seperated from the water so that wont be leaking. It could also be the electric water inlet valve that is leaking. let me know what you find out !
Oct 29, 2009 | Whirlpool LSB6000PQ Top Load Washer
How do you take the top off a whirlpool sq 9030pq5 washer
look on the back there should be screws it hooks in the front and metels screws hold the back most likely
Jun 21, 2009 | Whirlpool LSQ8000 Top Load Washer
ULTIMATE CARE II WASHER - MODEL LSQB520JQ0 IS LEAKING
you can tip this unit back, the bottom is open and then oyull be able to see where the leak is coming from, any part wharehouse(online stores as well) will stock the pump if needed.. most common cause of leaking pump is fron center shaft youll see the water line
Mar 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer leaks
do not remove the top panel. First tip the washer back. NOT ALL THE WAY. just enoough to see under it. you will see a pump. it is attached by 2 hoses. one to the tub and one to the drain. take the 2 clips off with the hoses still attached. tip it downward. Is water leaking oout of it? let me know thanks
Feb 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Open Questions:
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
