Question about Toshiba Satellite A100-S8111TD Notebook
Error message hkdrv driver absent - Toshiba Satellite A100-S8111TD Notebook
    Scholar:
  • 126 Answers
Download the driver here-
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK
install and restart.
//javaftper
Posted on Jul 30, 2010
Display screen shows "Will return soon" Would like
You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
KX-TA624 Phone System
Press intercom button, dial 750#, lift handset then return handset to cradle to end.
KX-TA1232 Phone System
Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
KX-TDA100 or KX-TDA200 Phone Systems
Press intercom button, dial *7500, lift handset then return handset to cradle to end.
Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
How do i set an absent message on Panasonic KX-T7730? i have de manual, but this doesn't help me. which is the number program associated with this function ? Thank you
Messages come from the system the phone is plugged into. In TA series, it's dialed as 75x with x being the following descripton from the user manual:
If you are unable to answer calls, you can select a brief message that will be shown on the displays of Panasonic display proprietary telephone (PT) users when they call you. The message you select can explain the reason for your absence, and is also shown on the display of your PT every time you go off-hook. Message no. Message 1 Will Return Soon 2 Gone Home 3 At Ext %%% (Extension number) 4 Back at %%:%% (Hour:Minute) AM (or PM) 5 Out Until %%/%% (Month/Day) 6 In a Meeting To set
If you have a different system, then the instructions will be different, but they usually start with 75 or *75.
The 7730 phone is backward compatible to every KX-T series system Panasonic made, so it's also possible that you DON'T have the ability to set absent messages.
Carl
Nov 26, 2009 | Panasonic KX-T7730 Corded Phone
Removing GONE HOME from main screen
The feature is ABSENT MESSAGE. It's set by dialing *7502# on the intercom. I don't remember if you HAVE to dial the # or there's a 1 equivalent to it.
Absent messages are 1-9 (there are 9 of them) and 0 clears it. So, you can dial *7500 and it goes away.
Carl
Sep 23, 2009 | Panasonic KX-T7630 Corded Phone
How do a leave a message saying I will be on vacation?
How to programme absent messages on Samsung OfficeServ or DCS telephone systems;
Aug 26, 2009 | Samsung Prostar DCS-24B-STD Corded Phone
Initialization Error
hi friend,
there are few steps to stop the message in the start up. i tell you the step by step.
  1. Goto Run type msconfig
  2. Goto startup tab and see all the files that are in the startup files and unselect the Hkdrv files in the startup
  3. it will ask you to reboot the system.
  4. After reboot the system and in the begin of the system it ask you to the accept the changes in the start up and choose the dont show this message again in the start up and click ok.
  5. After this it ask you the same thing .please inform to fixya.com
bye thanks,
Jun 14, 2008 | Computers & Internet
Canon copier np 6545
E540 is a sorter/collator problem
You can unplug the sorter and move it away from your copier then swith off then on again and the copier will work and you can still sort via the document feeder.
here is the error code disription...
E540
Cause..
• Bin shift motor (fails to rotate)
Discription....
• The operation does not end within a
specific period after the motor drive
signal has been generated.
• Clock signals from the clock sensor
of the motor are absent for a
specific period.
• The input signal from the lead cam
position sensor does not change for
a specific period.
Jun 08, 2008 | Canon NP 6545 Copier
My computer opens Lite On 5236 (drive E:) yet sees nothing?
when you check the properties of the device does it recognise the drive
Nov 16, 2007 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
Error Message-- Error in shading position (-4431)
The issue at hand here is a sensor error. Cut the power to the machine for at least five seconds. Then reboot the scanner and the sensors should reboot. This solved the problem for us. Good luck to you.
Nov 21, 2006 | Canon DR-2580C Path-Through Scanner
Toshiba Satellite A100-S8111TD Notebook Logo
151 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
