Question about Legacy Audio LM56 5.6 in. Car Monitor
Installation i was wondering how to install this item into my truck, with a play station 2. there is two wires (black and red) which i assume go to the battery, and than only one yellow AV jack....how do i hook up a ps2 to this??
  • 47 Answers
OK THE RED IS POWER
THE BLACK IS GROUND
THE YELLOW IS YOURE AV INPUT
THE ONLY PROBLEM YOU HAVE NO AUDIO INPUTS
ON THIS UNIT
THE YELLOW GOES TO THE YELLOW ON THE PS2 WIRES
Posted on May 13, 2008
Ceiling fan and light kit installation 4 wires 3/1 (red, black, white) from electrical box to 3 wire (black, white. green) from fan. How do the wires connect?
I'm assuming from your question the 4th wire in your electrical box is a bare copper wire which is the ground. The green wire gets wire-nutted to that. The white wires get wire-nutted together. I'm guessing you have two switches installed in the wall for the fan because there is a black and red wire coming from your electrical box (one for the light and one for the fan) connect the two black wires together. The red wire is then connected to the blue wire in the fan which is the light.
Dec 22, 2016 | Dryers
Just performed a new install on this. Everything powers up and works fine, including the power antenna. Followed set up instructions including selecting speaker output but no sound at all? Radio station...
It sounds like you may have the negative and positive polarity wrong usually to the speakers. I suggest to use black for negative and red for positive so that each speaker is correct. Speaker wire is good but for self installs its a common mistake.
Oct 23, 2013 | Kenwood KDC-HD455U
How do I install a trimatron light switch that has a black wire a green wire and a red wire and the house box has two black wires and a red wire
If the main box has 2 blacks and a red i would assume that the first black is either the live or the final wire that goes to the light. the other black and red sound like traveller wires that are either or wires for a 3 way switch system. 3 way switches are used on both ends of a hallway or for the top and bottom of a stairwell. You have to purchase a special 3 way dimmer to put in that area... or better yet buy 2 so that you can undim the light from the other end if needed.
Oct 06, 2013 | Electrical Supplies
2 gang light switch wiring diagram
I'm sorry, maybe I'm not understanding correctly and completely. First, I'm assuming you're installing a two gang box to replace an existing single. If not and you have two red and one black terminated to your existing switch, all you should have to to is; kill the breaker, remove the existing switch, get a couple spare pieces of black wire, just to keep things consistent, splice the three black wires together, terminating one on each switch, top or bottom doesn't matter, and carry one red to each switch. That's about as simple as I can explain it. From everything you've said, your black sounds like your hot wire, and your reds go to either light fixture. This installation should work for you hope this helps!
Aug 19, 2017 | Electrical Supplies
I have a 97 toyota tocoma ext.cab. and am putting in my new cd player although my wires are not the same colors could you tell me what wires i need to match
Hello... I will try and help you with your problem. I am assuming that you have cut the factory harness off in the truck? If you have and you can reconnect it, I would recommend doing this and then you can purchase a wire harness adapter and then just match the colors. The benefit in using an adapter harness is the ease of the installation, and the more you change the radio in the truck, the shorter the wires will get. If you do not have the factory harness, or cannot reconnect the old one, here is the hardwire code:
Wire purpose: Truck color: Alpine harness:
Constant 12V+ Blue/Yellow Yellow Switched 12V+ Gray Red Ground Brown Black Illumination Green N/C Dimmer n/a N/C Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Pink White Left Front (-) Purple White/Black Right Front (+) Light Green Gray Right Front (-) Blue Gray/Black Rear Speakers 6 1/2" Rear Corners Left Rear (+) Black Green Left Rear (-) Yellow Green/Black Right Rear (+) Red Purple Right Rear (-) White Purple/Black
Hope this helps!
20 year car audio/video installer
Bay manager
Apr 06, 2011 | Alpine 16 Pin Original Head Unit Harness
Sony car radio model no mex-bt2500 fitted to my renault laguna keeps looseing its memory when you switch of car and comes on when car is switched on without touching on off switch on radio is ther a...
Hi , I assume your installaton to be an aftermarket installation - ie not factory installed. if so then it sounds like the installer has connected the red and yellow wires together and connected them to a switched feed off your ignition.
this is an easy fix - the radio needs a permanent 12 volt supply to the yellow wire - leave the red wire where it is
Apr 17, 2010 | Sony Car Audio & Video
Installing cooper 30A 250V female receptacle.
Correct, assuming red and black are connected to the breakers in the breaker panel, and white is connected to the neutral/ground buss bar in the breaker panel.
Dec 17, 2009 | Cooper Wiring Devices ACE6001V-K "ACE"...
CDC-R304
red = 12 volts switched (ignition)
yellow = 12 volts constant
black = ground
blue = power antenna
blue/ white = amp turn on
purples = right rear
grays = right front
greens = left rear
whites = right front
black striped speaker wires are negative side
Nov 08, 2007 | Aiwa CDC-X204 CD Player
Wiring installation
You do need a 208/240 volt supply from your service panel. The green is ground, white is nuetral, and the red and black should measure 120 volts each to ground or 240/208 between each other. It is normal for most breaker panels to supply 208/240 between adjacent insulators. If you are only getting 1/2 of that then the circuit breaker may not be straddling the insulator bar but be 1/2 notch out and both breaker pins contacting the same 110 supply.
Apr 14, 2007 | Jenn-Air JED8430 Electric Cooktop
Legacy Audio LM56 5.6 in. Car Monitor Logo
157 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Mark Skinner
Richard Lukszys
Richard Lukszys
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
