Question about Jenn-Air JCD2389G Side by Side Refrigerator
My fridge leaks underneath
My new refridgerator has been leaking on the floor since I got it. The repairman put a new door on it and it still leaks. He cannot find the problem.
    President:
  • 1,099 Answers
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website). If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Hope this helpout......
Posted on Jul 29, 2010
253.63712300 sears Hoffman estate fridge has small pools off water that sometimes freeze on back of fridge shelf. Sometimes small trickle of water leaks onto floor. the refridgerator and freezer are s
probably dust, hair, lint plugging the drains.
you have pets?
have it serviced by a professional, or you can disassemble all the drain lines and conduit and pans and clean yourself. good luck
call a PROFESSIONAL
Dec 29, 2014 | Estate Refrigerators
Have a magic chef refridgerator and the water is leaking on the items below. Fan is working fine in the freezer compartment. There is icicles on the divider board. Checked the hole where the water...
at the back of the fridge there is a water drain hole. this will be blocked. you will have to unblock by pushing a thin wire etc down it, then pour a little warm water down to confirm it has been unblocked. if otherwise
There are two issues that may cause leaks near the door of your fridge. The fridge door may not close in full or the rubber gasket which encompasses the door frame may be clogged or torn, thus causing condensation and leaks. To repair this problem, you need to discover the faulty component. If the gasket is dirty, clean it by rinsing with a sponge. Check if an item in the refrigerator is preventing the door from closing properly. If the gasket is somehow impaired, replace it. When buying a new gasket, it is best to buy one that matches your fridge model or type of door. The more general the gasket, the harder it is to install it.
If the leak caused by the gasket, you may have to check the door and ensure that it closes tightly. If it does not close well, you may use the door screws and bolts to fix the problem. Another remedy is to put the refrigerator at a slight angle. Some fridges have adjustable legs, but if your model does not have such, you may want to buy some wooden shims or sheets of plywood and put them beneath the fridge.
Fridge Leaks due to the Drain Pan
The drain pan functions to catch water from condensation so that it does not leak over the floor of your kitchen. If the drain pan is somehow damaged, it may be the reason why you have a puddle of water around the fridge. The pan is located underneath the fridge. Pull it off, drain the condensed water from it, and check if there are any punctures into it. If there are some, you should buy a new pan or somehow repair the current one. One possible way to check your drain pan is to fill it with tap water once you have cleaned it.
Hope this helpout.......
Jul 28, 2010 | Refrigerators
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaks on to the floor from our whirlpool fridge
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
Oct 23, 2009 | Whirlpool Refrigerators
Water comes from under drawers on fridge side, leaks onto floor
If leak continued then you must have a faulty cut off valve. Check and tighten valve. Also, check the hose that runs underneath the fridge for cuts or holes.
Jul 12, 2009 | GE Profile PFS22 33" Artica French Door...
Fridgidaire Gallery Series Side by Side Refridgerator
"jennycub" sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine. very common problem( easy to detect. water on the floor of freezer compartment) as far as the other posting by" humblerumble", ive seen where the drain tube under the refig has pushed a hole into the drain pan under the refrig, in which case it will only leak after a defrost cycle, with the kickplate removed grab a flashlight and look under the unit for the drain pan as you pur water into the back of the freezer sect to trace water flow
Oct 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water leak
What's happening is when the fridge goes into defrost water goes thru the drain and is seeping into the crack by the damper which will run into the fridge section.  Why?  The drain doesn't come down far enough for all the water to go down the drain tube.  Frigidaire has a new drain that is longer and will prevent this problem.
Oct 22, 2007 | Refrigerators
Jenn-Air JCD2389G Side by Side Refrigerator Logo
137 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
