Question about Cameras
Hi, I have a Finepix A600, it has a very short battery life using NiMh batteries. While it was under warranty it had a software upgrade to improve the battery threshold tolerance of the camera. This made some improvement, but the battery life is still short. The NiMh batteries are fine. Is there anything that can be done. Thanks
    President:
  • 1,944 Answers
Try using higher capacity NiMh batteries.
Posted on Apr 24, 2008
Red battery light even with new batteries - then shuts down
Your camera can work with 2 AA sized batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period.
Always charge sets of batteries together.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
AA manganese (Zinc-Carbon) batteries and NiCd rechargeable batteries cannot be used with this camera.
If you are sure you have good batteries, also check if all contacts are clean and shiny. No oxidation is allowed. To clean contacts never use sharp tools. They can damage the camera forever.
Eventually clean contacts with a cotton swap or a dry cloth.
Also check if no debris is in the battery compartment. Just a little pice of paper can spoil all the (camera) fun.
Just to make sure, try some other batteries, then the ones you are sure of, they are fully charged. Perhaps, next time you are less convinced.
Feb 24, 2014 | FUJIFILM FinePix AV130 Compact Digital...
What batteries do I use for fujifilm finepix a605 digital camera
Your camera takes two AA sized batteries. You can use either disposable alkaline cells (like Duracell) but the battery life will be short, or can use rechargeable NiMH cells (recommended). Absolutely do not use NiCad or Lithium rechargeables in your camera, and you also mustn't use manganese cells (sometimes called lithium manganese).
Please take a moment to rate my answer.
Sep 13, 2010 | Fuji FinePix A605 Digital Camera
My fuji finepix a600 is taking pictures slowly
Try this...go into the menu and find "reset"...follow the on-screen instructions.
Jul 13, 2010 | Fuji FinePix A600 Digital Camera
My Finepix A900 digital camera is turning itself off every time i try to take a picture.It's not the batteries, I've tried 2 sets of new ones. Any suggestions?
Actually, it may be the batterys. Even top brands like Energiser can have unbelievably short battery life if they are not NiMh! Go onto the FujiFilm website and find the batteries they recommend
Jun 12, 2008 | Fuji FinePix A900 Digital Camera
Fujifilm a600 problem since new
If still under warranty, Fuji can perform a "power re-set" on the camera. This reduces the amount of power the camera requires, and should solve the problem for the long-term. I have sent out one of my customer's A600 with the same conditions. The re-set solved his problem.
Jan 22, 2008 | Fuji FinePix A600 Digital Camera
OBSCENELY short battery life in PowerShot A40 :-(
You need to use Nimh battery specifically designed for digital
camera use with high ampacity usage.
Jan 05, 2008 | Canon PowerShot A40 Digital Camera
Software
Hi Socrates,
If you purchase and install the Motorola Phone Tools (http://direct.motorola.com/hellomoto/phonetools/), the software will update the firmware in your phone when you connect it and run the update tools. It walks you through this (and makes you do it) when you start the software for the first few times.
This may help with battery life, but also keep in mind new batteries can be found on eBay for less than a dollar. Also, a good tip with any rechargable device is to charge it completely when you first get the battery, and then drain it completely without charging it right after that. This helps to set the "life" of the battery, and will generally increase the lifespan of it significantly.
Dec 17, 2007 | Motorola Mobility RAZR V3
Card not initializing
You will have to format it. Keep it in the camera and go through the manual's instructions for doing this, sorry but this sometimes happens.
Nov 19, 2007 | Fuji FinePix A600 Digital Camera
Cameras Logo
202 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
