Question about Dryers
How to repair electric fans that runs so slow even when it's turned on to it's max speed?what seems to be the problem?
  • Warren Beneville Apr 22, 2013
    It would be extremely helpful to know what type of fan is having the problem and what its intended function, i.e. ceiling fan, typical room oscillating fan, appliance fan, etc.
I have the same problem...i think the wires are ok and it still have some grease in it...but it still running slow even if i set it to its max speed...and another thing is it really gets hot sometimes and i smell some hot electric wire smell coming from its back cover
Posted on Oct 29, 2011
  • uaungkhin347
    uaungkhin347 Jan 28, 2013
    When I face with such problem in electric fan, it is better using diesel oil instead of grease. The motor of the fan cannot resist some grease due to its high viscosity. In addition, dust and grease make motor run more slowly. Have a little diesel oil into the axel of the fan, and let the fan rotate slightly. Diesel oil clean the axel. Please try it.
  • 3 Answers
Is it a new ceiling fan? try oiling the motor. I f it didn't work, you can check the voltage and electrical wire.
Posted on Jul 30, 2010
  • 42 Answers
First try the usual oiling method
if not solved check The speed regulator for any smell of Burn
finally ensure your capacitor is in good condition otherwise that may result in voltage drop across fan terminals
Posted on Jan 30, 2013
    New Friend:
Try to replace your capacitor if the motor is well oiled.
Posted on Apr 09, 2013
Fans work but only after it gets warmer than it usually runs 2003 dodge caravan. The code is slow fan not working is there a separate fuse or switch?
DESCRIPTION The dual radiator fans are mounted to the back side of the radiator . The radiator fan consist of the fan blade, electric motor and a support shroud which are all serviced as an assembly.
OPERATION COOLANT TEMPERATURE
A/C PRESSURE TRANSAXLE OIL TEMPERATURE Fan Operation Speeds: Initial Max Initial Max Initial Max Fan On: 104°C (220°F) 110°C (230°F) Fan Speed Duty-Cycles (Ramps-up) from 30% to 99% 1,724 Kpa (250 psi) 2,068 Kpa (300 psi) Fan Speed Duty-Cycles (Ramps-up) from 30% to 99% 96°C (204°F) 111°C (232°F) Fan Speed Duty Cycles (Ramps-up) from 30% to 99% Fan Off: 101°C (214°F) Fan Speed Duty-Cycles (Ramps-down) from 99% to 30% 1,710 Kpa (248 psi) Fan Speed Duty-Cycles (Ramps-down) from 99% to 30% 89°C (192°F) Fan Speed Duty Cycles (Ramps-down) from 99% to 30%
Mar 08, 2018 | Dodge Cars & Trucks
Fan only runs on slow speed
The receiver in the fan housing may have failed.
Apr 20, 2017 | Hunter Dryers
2002 chevy malibu heats up when running at low speeds
CHECK THE THERMOSTAT. THERMOSTAT IS THE ONE THAT SENSE THE ENGINE TEMPERATURE AND TURNS ON COOLING FAN WHEN THE ENGINE IS HOT.
Jan 19, 2012 | 2002 Chevrolet Malibu
Engine temperature reaches to high before cooling cycle begins
could be a bad temp sensor or faulty thermostat. so by cooling cycle do you mean electric fan, or water circulation. a bad thermostat will slow circulation down causing overheat even if cooling fans are on. a bad sensor will not operate electric fan properly or at all and car will get hot at idle or slow speed and cooler at higher speed. Keep in mind that electric fans can turn on at any given time so KEEP ALL FINGERS AND LOOSE CLOTHIG AWAY at all times.
Apr 02, 2011 | Nissan Sentra Cars & Trucks
GE JVM1430 over the range microwave/exhaust fan unit. The exhaust fan (not the microwave cooling fan) all of a sudden has its speed slowed down considerably. The unit vents out the back, not top. ...
Sounds like a strip down of the fan and lubricate the bearings with sewing machine or thin cycle oil will do the trick.
Hope that helps.
Jan 20, 2011 | Microwave Ovens
I have a Casablanca New orleans fan that I just had fixed by an approved Casablanca repair place. The fan is and always has been connected to a dimmer switch. After a repair of a simple flywheel, the fan...
Hi, is this fan an older fan with the dimmer type control on the fan itself, (and you have a wall speed control in addition to) or is it the later fan with a three speed pull chain control? If the latter, the service rep may have accidentally placed the fan on Medium speed which due to additional capacitance from the speed control board in the switch housing, could cause the symptoms you describe.
Thanks, Brian
P.S. That's an $$$$ fan, glad to see you had it repaired instead of replaced.
Aug 29, 2010 | Dryers
I just installed a Hunter five minute fan which says it is called the augusta. I have also installed several other hunter fans in my house through the years, and they seem to move extremely fast especially...
Speed is not a factor in moving air. You can move air with a little fan that runs real fast or you can move the same amount of air with a big fan that moves slow.
It is the pitch of the blades that moves air. Big blades with steep pitch moving slow are comparable to little blades with shallow pitch that move fast.
It seems to me someone is trying to baffel you with bull**** when they tell you CFM = watts or something similar.
The real question is, is the fan moving the air necessary to achieve the result you desire? If yes, speed is not really a factor.
Let me know if this helps you.
a
Sep 22, 2009 | Dryers
Hampton bay altura 68
Read this on another thread - apparently the solution came from HB's tech support.
Turn the fan speed to HI and then select Reverse.  You should hear a "click" and see the fan reverse direction.  It seems that the reversing relay only works when the fan speed is set to HI.
Good Luck!!
Two Metre Man
Jul 12, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
2,634 people viewed this question
Top Dryers Experts
Marvin
Marvin
