Formated hd on used laptop i recently got and dont have restore disk for onboard hardware or operating system.what do i do
    Brigadier General:
  • 6,966 Answers
Initially, you have to determine what OS and/or version of Windows the laptop used before. This could be determined by looking underneath the laptop. Often, there would be a sticker indicating the Windows version as well the the key numbers. Thereafter, you can borrow an OEM Windows CD installer (same version as shown in the sticker). Upon installation and when required, enter the keys that were indicated in the same sticker. Thereafter, it's a matter of hooking the laptop to the internet via the Ethernet port and going to the laptop's manufacturer's website and download appropriate drivers. In the event that even the drivers for the Ethernet port were not installed automatically by Windows, you need therefore to use a 2nd PC and download the network adapter drivers, copy them to a flashdrive and transfer to your PC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 24, 2008
"For Atheros PCIE Ethernet Controller v2.0.2.3(05/18/10) Check Cable Connection!"
The operating system is looking for a boot device
Make sure there are no discs in the drives cd/dvd and usb
make sure the bios is set to boot from your hard drive or
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem.
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode.
You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
hope this helps
Nov 25, 2012 | Computers & Internet
Will not go pass windows updates stage 3 keeps restarting
Probably a stuck update.
Restart in safe mode (F8) and click on My computer / Hard drive (right mouse click) Under properties, select tools/ check volume for errors, it will schedule a check, reboot and let it check the drive
If this fails, try using system restore to go back to a time before it was updated OR
If you can get into safe mode, review what has been installed recently and uninstall it.
Try updating again
Your antivirus may be preventing the update, yoou could TEMPORARILY disable this and see if that helps
Dec 31, 2010 | Acer Aspire 5920-6727 Notebook
Windows failed to start
It may take you quite a while to figure out how to solve this problem from trial and error. It will take less time if you:
RESTORE
1. Take the hard drive (HD) out of the PC
2. Attach it to an external drive case
3. Attach this to another PC and remove all of your DATA and store it external to the HD
4. Restore the system from scratch using Toshiba's restore tools
5. Put data back on.
CAH
Mar 15, 2010 | Computers & Internet
Acer aspire one will not start in safe mode or to last known good config. Nothing works.... F2, F8 F12.... all no good. Just keeps returning to the screen saying windows did not start successfully. ''a...
You are going to have to repair the Windows installation. If the boot up screen has an option to repair (some systems like Dell and HP provide an hidden partition with the software to allow you to restore the system), use that to repair the installation. If it does not, you will need the Windows disk or system restore disks to fix the installation.
If using a Windows disk, skip the first repair option and do an install. DO NOT FORMAT THE HARD DISK! During the install it will say it found a previous installation and ask if you want to repair, choose the repair option at this time. Using this method, all your applications should remain installed and working. You will need to run Windows Update till it is fully updated.
If using System Restore disks, follow the on screen prompts
Mar 12, 2010 | Acer Aspire One Netbook 8.9" Notebook
How do I start over with my computer toshiba p35 s611 do I have a restore on this model or do I need to format HD and reload XP? I dont have any restore disks.
if you go to "computer" and there is a partition or hard drive showing as "recovery" then you should be able to take your lappy back to its original state.
if not then you will need to format, depending on how old your system is anyway, a format might do some good.
Jan 02, 2010 | Toshiba Satellite P35-S611 Notebook
Just to format a HD and make it usable
i had the same problem with one of mine and when hooked up to windows xp i couldnt get it to format but i installed vista then plugged up my external hd and went into disk management and it formatted no problem then just assign a drive letter
Aug 07, 2009 | Computers & Internet
Acer eRecovery for Veriton 7900
If you have formatted the hard-Drive you,ve deleted all information from the computer.
your only other option, is to install an operating system ( Windows/Linux ) and check the device manager, to see which drivers need to be downloaded/updated. With Laptops it,s usually VGA ( graphics ) Sound And sometimes LAN/Network drivers.
a recovery cd will have all of this information, and reinstall your original operating system, including authentic product key. so sometimes worth the money.
Mike @ compurepair.
Jun 11, 2009 | Acer Aspire 5610-4648 Notebook
WD 500 GB resized by Norton Ghost Restore to 120 GB and can not get it to original size.
You should partition your new drive first to say 160Gb (you lose a bit after formatting) for 1st partition and the remaining capacity for the 2nd partition. Because your Ghost image is 120Gb it can only restore to a partition of 120Gb, that is why it shows 120Gb on a 500Gb on a single partition.
You may be able to fix this problem without starting again by using Disk Manager (from Control Panel - Admoinistrative Tools) to create a 2nd partition on the hard drive and format this partition.
Apr 28, 2009 | Dell XPS M1210 Notebook
Can not even use restore disks
from microsoft below ....
Bug check 0x50 usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM, be it main memory, L2 RAM cache, or video RAM).
Another common cause is the installation of a faulty system service.
Antivirus software can also trigger this error, as can a corrupted NTFS volume.
Resolving the Problem Resolving a faulty hardware problem: If hardware has been added to the system recently, remove it to see if the error recurs. If existing hardware has failed, remove or replace the faulty component. You should run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owner's manual for your computer.
Resolving a faulty system service problem: Disable the service and confirm that this resolves the error. If so, contact the manufacturer of the system service about a possible update. If the error occurs during system startup, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. At the resulting Windows Advanced Options menu, choose the Last Known Good Configuration option. This option is most effective when only one driver or service is added at a time.
Resolving an antivirus software problem: Disable the program and confirm that this resolves the error. If it does, contact the manufacturer of the program about a possible update.
Resolving a corrupted NTFS volume problem: Run Chkdsk /f /r to detect and repair disk errors. You must restart the system before the disk scan begins on a system partition. If the hard disk is SCSI, check for problems between the SCSI controller and the disk.
Finally, check the System Log in Event Viewer for additional error messages that might help pinpoint the device or driver that is causing the error. Disabling memory caching of the BIOS might also resolve it.
Sep 23, 2008 | Gateway 7405GX Notebook
Laptop froze
Bad News, serious problem!
Either Operating System is corrupt or Hard Drive defective. First Try REinstalling the Factory Recovery Disk Bios. Open CD rom Trey Place Factory System REstore disk. Turn on Computer and you should see "bood from CD, press any key" . Do so and follow instructions. Remeber to DELETE SECTORS when asked and when prompted select NSFS format. Follow instructions , use common sense and it should work.
If the HD is Defective, it will stop loading and indicate it cannot find HD in an error message.
One other thing. IF when you insert the disk and it boots up and does not go into the restore mode look on bottom of screen for BOOT ORDER and select CD ROM as the first boot. If you dont see that then you have to go into the BIOS and reset BOOT ORDER TO CD ROM FIRST. To get into Bias try tapping down f-2 key as its booting. If that dont work repeat with f-10, f 12 and then Delete button if all else fails. Find BOOT ORDER in BIAs and follow instructions on making CD ROM the first boot device. Then Save and Exit. Reinsert Restore disk and wait until you get the boot from cd rom prompt (process upove).
Unfortunately all data will be lost but computer will work fine.
If the drive is defective it has to be replaced. Write me again if that is the case if you want to do that yourself.
Good Luck
Cheers !
Jul 25, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
