Question about LG WFT1071TP Top Load Washer
During the water supply in the tub, the water gets drained through the drainhose. New Machine one day old. What causes that drainage. Top Loader LG machine. Model: WFT11G00TED Water keep on draining before cycle can start at all
    President:
  • 1,430 Answers
The problem is the drain hose is to low or to tight in the standpipe. The standpipe is your home plumbing. If it does not have an air gap around it, it will create a siphon effect. Here is a link with more info http://appliancehelponline.com/washerdrainsfills.html
Posted on Jul 29, 2010
MACHINE MAKES DOES NOT WASH,WATER OUT FROM DRAINAGE PIPE
is it a top or front loader?is your drain hose same level as top of machine?if not ,raise hose to level and start cycle.machine will not wash if it does not fill.please reply if u need more help
Apr 05, 2010 | LG Washing Machines
Fisher Paykel Ecosmart washing machine spills water.
sometimes too much detergent, or extra cleaners like oxy clean) will cause lots of foam which will cause the water level sensor to misread, or foam over the top of the drum. if this is not the problem, you will have to tilt the machine on its side and look for loose or damaged hoses. the play in the tub will not cause leaking
Jul 10, 2009 | Washing Machines
I have a twenty year old Maytag washing machine that is leaking water out of the bottom of the machine. I have checked the hoses and it is not coming from there. Any ideas
hello. i can help you. unfortunately, your problem has numerous possible causes.
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jul 02, 2009 | Washing Machines
Water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Apr 02, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG front loader - shower water filling up machine
your drain should have a backflow device in it. This can be very dangerous, you need a professional plumber ASAP.
Feb 17, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
No Drainage on my LG WD-8050F washing machine
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Dec 08, 2008 | LG WM-2277HW Front Load Washer
Rotten Egg Smell
Make sure the rubber door gasket is clean. Pull it back and clean under and around it. The gasket will collect dirt and begin to mildew causing various odors. Run the machine empty, boil a medium pot of water to almost boiling, then put it in the machine during the wash cycle. This will help clean the lines, during the rinse cycle place a 1/2 cup of vinegar in the unit. Make sure you are using HE detergent. 1-2 tablespoons will due. If your using liquid fabric softner, dilute it by half. These machine use less water than a typical top loader and can't dissolve regular detergent effectively. There by causing your lines to get clogged with gunk.
Nov 02, 2008 | LG WM1814CW Front Load Washer
Washing machine is leaking at bottom of tub
This could be alot of things. Can you give a Make, and Model Number? Is this a Top Loader or a Front loader.
If its a top loader, Unplug the unit first and then remove the front panel, is the front panel removable? Some are not removable.
Once you have the front off it could be as simple as a hose has a hole in it, or worse the tub seal is leaking and you need a complete rebuild or replace the machine.
Also check the hoses coming to the machine and see if they are leaking or if the drain hose has a problem? or is the water coming from somewhere else, sink next to machine? or drain is plugged or very slow and water is coming out of the drain during spin. Please advise if you need further help
T.
Jul 07, 2008 | Washing Machines
Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Apr 16, 2008 | KitchenAid KAWS700L Top Load Washer
LG front loader not draining properly
My LG front loader is stopping during the drain cycle (making a humming sound as if it is trying to drain, but can't....What can I do?
Nov 02, 2007 | Kenmore 44102 Front Load Washer
LG WFT1071TP Top Load Washer Logo
127 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
