I have a Compaq PDP124P power supply that arcs when power applied. This has happened to 3 different power supplies (3 different HP d530s) in 2 months. I have read there is a glue problem but have not found how to remove it or a suitable replacement for this power supply. Can you help?
  • equinefan Jul 29, 2010
    I will try your solution. Thanks.
    President:
  • 567 Answers
Hi power supply usually go bad after being use for for some time,this link show step by step along with the photo how to remove the power supply http://webdevsys.com/d530RemovePsu.htm it is very useful Compaq power supply
Posted on Jul 29, 2010
What is the vga driver for windows 7 professional on hp compaq series pdp124p desk top computer
the rear of most desktops have 2 VGA jacks
the onboard. VGA
and the better grade, PCI-express slot GPU card. VGA jack.
which one do you use?
not only that , 100s of PCI GPU cards could be in that slot.
looking or telling what you have or a photo of the rear helps.
unlike laptops, desk tops can have any thing there.
this PC is relic of long long ago. worth zero value today. 14yo.
HP owns COmpaq now, and all support ended long ago for this PC.
is this the old C500 series PC, no service tag data show by you, full tag data.
my wild guess, Pdp124p is the PSU power supply number
sorry that is not the PCs model number.
i see google showing it was used on a D530 SFF.
Small form factor case = SFF
ill now answer as though you said, D530 VGA onboard. jack1.
d530 s (c or u) s = sff, the PC came in 3 case types!!!
the jack1 below is wired to.
ntel Extreme Graphics 2 (integrated with Intel 865G chipset)
the jack 2 option VGA was sold with
NVIDIA Quadro4 100NVS AGP (64MB, dual VGA) full height
or 3 others sold by compaq day1
or if others like me added faster cards, there 100s possible
only looking and reading finds the cards model.
ill pretend its jack 1.
Intel Extreme Graphics 2 (integrated with Intel 865G chipset
Intel does not support drivers for w7 on there old chip.
HP(compaq) did but does not support this PC now.
you can ask HP on there forum for the driver.
be step1, and if fails buy a new GPU card and plug it in
and use that.
more? (intel.com) words (intel pulled the plug, dead see?)
https://www.intel.com/content/www/us/en/support/products/81528/graphics-drivers/legacy-graphics/graphics-drivers-for-intel-82865g-graphics-and-memory-controller-hub-gmch.html
id put in a new card, at point 2. that has w6 support, sure would.,
but you can ask at HP, Fixya is not HP, sorry to say.
the Real HP (and compaq) IS HERE, THERE FORUM.
https://h30434.www3.hp.com/
Jun 17, 2018 | HP Computers & Internet
I have an HP Compaq PC. A d530s running Windows XP Professional. When I turn the PC on, the power light flashes red 4 times (1 red flash per second). Pauses ~3 seconds and repeats the red flashing. Just...
A bad power supply, OR a bad motherboard. And I hate to tell you, but it's more common for the motherboard to fail first. Especially in those HP/Compaq slimline PCs.
It's because there's very little airflow, and system overheats and burns out. I've had many customers with the same issue.
The good news is you can still recover your data from the hard drive, just take the drive out, and hook it up inside another desktop with SATA connections, or get a SATA-to-USB adapter, they cost about $15
Sep 03, 2011 | HP Compaq dc7100 Ultra-slim PC Desktop
Green light in rear flashing won't part up
The green light flashing is a diagnostic LED light, telling you there is a power failure.
More specifically a bad Power Supply.
Weak voltage power rail.
The Power Supply used in a Compaq Presario SR1010Z desktop computer, is a 300 Watt unit, and is an ATX form factor.
[ATX form factor for a Power Supply, denotes the size of the Power Supply case, and the shape.
It is approximately 6 inches Long, 6 inches Wide, and 3-1/2 inches Tall.
The ATX form factor for a Power Supply is used in over 90 percent of the personal computers out there, and is as readily available as the air we breathe]
Usually, HP uses one of three generic Power Supply manufacturers.
1) Bestec
2) Delta
3) HiPro
All are low quality Power Supply manufacturers.
This is HP Support, and the main menu page for the Compaq Presario SR1010Z desktop computer,
http://h10025.www1.hp.com/ewfrf/wc/product?product=1146324&lc=en&cc=us&dlc=en&submit.y=7&submit.x=6&lang=en&cc=us
If you click on Manuals, then on Upgrading and Servicing Guide on the following page, there are instructions on how to open your computer case.
This is instructions on how to replace a Power Supply, from HP Support,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01356113&cc=us&lc=en&dlc=en&product=3548196
(It's for a Pavilion a6230n desktop computer, but after you open the computer case of your Compaq Presario SR1010Z, the instructions are the same)
What Power Supply would I recommend?
There are 100's to chose from.
This is but one example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276575&CatId=1078
Chosen because;
1) Maximum wattage is rated at 450 Watts.
A computer ONLY uses the power it needs, and NO more.
Wouldn't matter if you had a 10,000 Watt power supply, (No such thing. An exaggeration), if your computer only needs 100 Watts, it would only use 100 Watts.
(Surfing the internet typically uses 100 watts)
2) Has all the power cables you'll need, and more. Tie up the power cables you do not need. (Use plastic ties, Not wire, or bread wrapper ties)
3) 24 Amperes (24A) on the 12 volt power rail.
4) 135mm cooling fan.
The cooling fan on the Power Supply you have now is 80mm.
A larger fan turns slower. Produces as much air as a smaller fan, (Or more), but makes less noise.
Less wear on the fan's bearings also.
5) Is an ATX form factor Power Supply.
6) It's 80 percent efficient, compared to the 60 percent efficient Power Supply you have now.
(That is, if it was working)
Sep 12, 2010 | HP Compaq Presario sr1010z PC Desktop
Computer won't turn on!
what it might be is that your hardrive or power supply is not working and that you need to have it replaced
soory i couldnt be of more help!!
Jul 22, 2010 | HP Compaq d530S PC Desktop
Hp d530s problem restarts by itself (Windows XP Pro. I tried different hard drive, still same. The CPU and the power supply are very hot. The fan makes noise sometimes. What could be the problem? Thanks!
Scan the system for viruses. If no virus found check ur power options settings in control panel. Still u experience the same problem just uninstall anti-virus program from ur pc. This will fix ur problem mostly.
Jul 21, 2010 | HP Compaq Evo d530 PC Desktop
Hp compaq d530
Then it's truly dead, replace it. If you're lucky it hasn't fried the entire pc.
May 11, 2010 | HP Compaq d530S PC Desktop
PC won't power on. Compaq SR5410F
IF you have another power supply you can use, try it and see if the computer will power up.
Oct 29, 2009 | HP Compaq Motherboard
RE: HP Compaq D530S desktop PC
there is no extra room the only way is upgrade the hard drive whid a biger one man and the hard drive is eide interface if you atenp to bye one thanks
Oct 17, 2009 | HP Compaq d530S PC Desktop
HP d330 fried during pwr serge, fixed, boots but no screen signal
there are several possibilities. 1. replace the ram, make sure that its a good working ram module. 2. review all your work from system board to power supply. 3. try running it temporarily without the cmos battery. 4. check your monitor. 5. check your VGA. 6. retry and retry.
Jul 13, 2009 | HP Compaq Business Desktop dc5800
Computers & Internet Logo
264 people viewed this question
Alun Cox
David Payne
David Payne
