Question about ASUS Essentio (CM5571BR003) PC Desktop
I have read that some asus 5571 hard drives have
I have read that some Asus em5571 hard drives have crashed. Is changing the bios setting the answer?
    Guru:
  • 1,705 Answers
No. If its running all right, leave your bios alone.
1) Backing up all your files will save you from data loss.
2) Routine maintenance, Keeping all the vents clear of dust, cleaning out the tower occasionally. Good anti-virus protection and a de-frag now and a gain.
Posted on Jul 29, 2010
Testimonial: "thanks"
    Novelist:
  • 235 Answers
Check to see if your PC is over heating which would normally cause the fan speed to increase. Overheating will cause it to shut down unexpectedly. Cleaning all the dust from the power supply and vents will prevent overheating. Make sure the fan IS running.
After you back up your data, run disk diagnostics on the hard drive to fix any bad sectors.
Posted on Nov 06, 2014
Where can I purchase a system disc for a Asus m2n Sli motherboard having an award Boot Block V1.o Bios?
If the computer is asking for a system disc, then what it is really saying is that it cannot find the Operating System. This usually means that one a a few things:
1. The BIOS is not set to select the internal hard drive as the boot device. This can change by accident or if the BIOS gets corrupted.
2. The OS itself is corrupted and cannot boot.
3. The HDD (hard drive) has failed.
When you say you need a "system disk", what you really need is to reload the Operating System. You can get Windows from many sources. Then you only need the drivers that are specific to the main board you have. These can be downloaded for free from the ASUS website. Just go to support, downloads, select you main board model and revision, and download the drivers for your particular Operating System. Of course, if the problem is hardware related, simply getting a new OS will not completely solve the problem. A BIOS corruption would be the worst possible issue since that would require a reflash of the BIOS, and hopefully it would be in good enough condition to perform one without crashing completely. The simplest problem would be if the BIOS was simply not looking at the hard drive as a boot device. Go into the BIOS and ensure that the internal hard drive is selected as the first boot device. If not, make it such and then save and reboot to see if the problem is solved. Otherwise, you need to ensure that the hard drive itself is not faulty. If it is ok, then a new OS and reloading of the drivers and other programs is necessary.
Feb 04, 2016 | ASUS Computers & Internet
Asus eee pc 1001p - hard drive failure?
or check the bios settings . look in to which drive is the first drive
Jan 10, 2018 | ASUS Eee PC 1001P Netbook
HI, ive been having a problem with my Asus A9RP. Been trying to fix it but it is still futile. Everytime i open my laptop, it just stays on the logo. no response from any of the keyboard. i tried to remove...
Bios is not operating properly. Either it is corrupted or you have a bad peripheral causing issues. Disconnect all you can, (hard drive, optical disk, etc) and then see if it still freezes on boot up. If you have 2 memory sticks disconnect one and try again till you check out both chips. If all disconnects do not change anything then my original comment re bad bios stands.
Apr 08, 2017 | ASUS A9RP Notebook
Asus A8JR Won't Boot
Have you made any hard ware changes?memory upgrade hard drive?
You can try holding down the f12 key while booting up.This will bring you to the cmos or bios page.
once there try setting system back to factory default or optimal settings.
www.asus.com
good luck.
Jan 10, 2010 | ASUS A8N-E Motherboard
I have the identical problem as chrisdangelo
hello
I have read your problem and the solution to your problem may be following.
  • The BIOS setting may have changed.You can reset the BIOS settings.
  • The hard disk type may have changed..look for SATA and ATA.
  • Or your window got corrupt.Reset the BIOS setting and reinstall the windows using boot able CD.
  • if nothing work out then may be your hard disk connector is loose or your hard disk is gone.
thank you
Jul 29, 2009 | ASUS Eee PC 900 PC Notebook
ASUS P5S800-VM Motherboard set up
Hi m_k_bishop,
You must connect the CD-RW drive to the Secondary IDE connector on your board.
It can not be connected to the Primary IDE port.
(All SATA drives are seen as master drives in the bios).
With that in mind there shouldn't be any data cable connected to the Primary IDE slot.
When you first load the Bios menu screen you should see your CD-RW listed & you should see your SATA drive listed. Go to the title, " BOOT " in your bios.
(If your system has a floppy disk drive connected your Boot menu should read as follows);
First boot device [Floppy Disk]
Second boot device [Your CD-RW drive]
Third boot device [Your SATA drive as shown from the main menu]
No need for a fourth device.
Save the bios & exit. The system will auto restart.
(At boot up re-enter your bios).
Next change the [RAID Mode] to SATA or Enabled anything but RAID.
Once completed save & exit the bios. If everything is connected correctly & you made the changes above your system should see your SATA drive & windows should install.
(Load the windows CD into your CD-RW drive).
The Asus manual lacks the proper information needed for you to make the correct setting changes in the bios.
Good luck m_k_bishop!
Post back if still have trouble... You shouldn't!
Mike
Mar 21, 2009 | ASUS P5S800-VM Motherboard
Want the best bios for Asus M2N68-LA motherboard to run on win xp
You don't need to change the bios to do that, you already have the best one.
Mar 14, 2009 | ASUS Computers & Internet
Want to run both Raid 5 (4 drives) and a single SATA boot drive
Download the latest beta BIOS 1238. I had the same problem when adding a Samsung 1TB HDD to my RAID config. Updating to BIOS v1238 solved the Intel RAID Matrix "hanging" instantly.
You can't download it through the official Asus support page yet, but there's a topic in the Asus support forum with a link. You could also call Asus support and request the file, or just download it here: http://rapidshare.com/files/186891601/P5B-Deluxe_1238.rar :)
Feb 07, 2009 | ASUS P5B Deluxe/WiFi-AP Motherboard
Ilunable to read from hard drive or cdrom from p4i65g
Try changing the IDE cable which connects your CDROM to motherboard. Also make sure that Master/slave configuration are properly set if both the hard disk and the cdrom are connected with a single cable
Nov 25, 2008 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Windows xp
kgprakash, Did you check your BIOS's Main Page to see if the board is reqognizing the drive correctly? If so did you change from Master setting to Cable Select or vice versa? Some drives don't like to play nice. Have you access to a differnt drive, just to see if XP finds it. If you have SATA or Raid capabilities on the board read the manual this messed me up for awhile (the Asus I use has 6 internal Sata ports and one IDE legacy connector). If you only have IDE, are you in the connector marked or known as IDE0? Just some thoughts.... Pcdok
Oct 21, 2007 | ASUS P5S800-VM Motherboard
ASUS Essentio (CM5571BR003) PC Desktop Logo
198 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
