Question about Microsoft Xbox 360 Console
Picture comes up fuzzy as though interferance, nothing wrong with cables or TV
    Genius:
  • 1,478 Answers
Could be a short in the A/V cords or could be something wrong with the back Inputs, i will advice you check this two areas very well to see if there is anything you need to correct, if you did not see anything cable shorted or problem with the back input which are the most likely cause of fuzzy pictures on xbox 360. You may be on your way to getting the E74 error. I will advice you return send the xbox 360 for repair if it still under warranty.
Take care.
Posted on Jul 29, 2010
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
I have a samsung hp5033 plasma for 18 months and is now having pixel problems. 3/4 of the picture is showing fuzzy tiny squares, this started 3 days ago and seems to get worse. I have tried to self...
Hello rqromero2,
I found this on HP's website. I hope it helps
Picture quality problems (such as lines, fuzzy image, or wrong colors)Check the cables and connections:
  1. Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors.
  2. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
    Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal.
    For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away.
    If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and .
    If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Open OSD to adjust the picture:
    Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed.
    If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
If this dosent solve your problem, letus know and we will find another solution,
Dahaka
Jul 22, 2008 | Televison & Video
Horizontal lines across screen picture going fuzzy in and out and then no picture at all
A horizontal line that rolls from the bottom to the top of the tv could be a Hum Bar. This is from a bad ground either for the house electric system or for the cable system. By code, these grounds are supposed to be connected (bonded) together. In other words, the electrical interference is going through your tv instead of into the ground. Fuzzy picture is usually from low cable signal. This can be due to bad cables, connections, or splitters or problems outside with the drop (cable line outside that runs to the house). Splitters, by design, lower the cable signal (i.e. a 2 way splitter cuts the signal in half). If you have unnecessary splitters you should remove them. If you have more than about 6 or 7 tvs, you may need to add an amplifier.
Jun 25, 2010 | Vizio VF551XVT 55 in. HDTV
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Tv picture looks grainy like it was shot on video
well most lcd and plasma tv's above 36" will look grainy on standard definition because they are made for high definition so if you do not receive a high definition signal to your tv then that would most likely be the problem
Sep 12, 2009 | Insignia 42" LCD Flat-Panel HDTV
My t.v screen is fuzzy and the picture is showing double on one side and it at times seem s streched
The stretching might be due to having the wrong aspect size on your tv. Look on your remote and see if you have a button that says "Aspect" or it could say "ratio" or something to that effect. You can cycle through the different screen sizes to make it not appear to be stretched. As far as your picture being fuzzy, if you are using a standard antenna that may be the cause. If you are using cable, I would contact the cable company and have someone come out and check your signal strength, and possible inquire if you need a cable booster added. If you are running cable through a cable box and are running it straight coaxle then I would recommend trying a different hookup method, e.g Red, white yellow cables, or S-video or even hdmi, whichever your cable/satellite box and tv allows.
Dec 15, 2008 | Panasonic TH-37PA20U/P 37 in. Plasma...
52D82U Fuzzy picture
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
Oct 07, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV CHANNEL CODE
WE JUST GOT A USED TV AND WE ARE TRYING TO HOOK IT UP. THE PICTURE COMES ON BUT IT IS VERY FUZZY AND THE NUMBERS CHANGE ON THE SCREEN BUT NOT ON THE TV. WHAT ARE WE DOING WRONG WE DO NOT HAVE A MANUAL AND IT IS A USED TV WE HAVE CABLE
Aug 27, 2007 | Philips Magnavox 27MS343S 27" TV
The picture on my tv is fuzzy
Check your connections Inm the Back of your Tv and Also see If your VCR got turned on By Mistake....
Jul 18, 2007 | Insignia IS 20" TV040919 TV
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stu Morris K
shaun taylor
mitch_3020
mitch_3020
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
