Question about ASUS Eee PC 1000H Laptop
Disk error msg on bootup
I have to run the Recovery disk to get it to bootup every
third or fourth time that I turn on the 1000 HD due to
'disk error' message upon bootup.
  • 69 Answers
Remove all the external peripharials from the system and restart it......it will work!
Posted on Jul 29, 2010
I recenlty purchased an asus U52F - i5, 4gb, 640HD notebook - it's fast!! - I am having bootup issues - on occassion, upon bootup, I get an error message that the "desktop" file cannot be found...
This is a windows software issue you will need to reinstall windows, I would back your laptop up if you have any data you wish to keep onto disk and use your recovery disks that you should have got with your laptop. If you have no disks and you can log into your laptop there is usually a program that will let you create recovery disks. Create them and use them to reinstall your operating system.
This should solve the desktop error.
Hope this helps need anymore info feel free to ask.
Feb 22, 2011 | ASUS U52F-BBL9 Laptop
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
Just installed a new hdd 500gb on my acer 5100 and now it won't read the recovery disc. Plz help. Dwayne
is the hd formatted?
when the computer is booting, hit the f12 key. this gets you to the bootup sequence windows. highlight the cd/dvd drive as first startup. reboot w/the recovery disk in the drive. this should allow you to format the hd and then install th files on the recovery disk.
Dec 24, 2009 | Acer Aspire 5100-5022 Notebook
DST log contains previous errors.DST short test failed
Error Code: 0146
MSG Code: 2000-0146
MSG: 1:DST Log contains previous errors
Dec 22, 2009 | Dell Latitude D600 Notebook
Receiving "Load Error!" on bootup. Tried using the recovery disk which seemed to be working fine, but still receive the same error. I've run the recovery disk several times with the same result.
If you had run recovery disk for several times and still have the same problem then you must go to other solution. Reprogram your computer operating system, this is last thing you have to do. You need your operating system installer. Setup a fresh copy of it. Don't forget also the computer support cd which contain all the drivers needed in installing an operating system. Hope this could help..Please don't forget to rate me..Thanks..:-)
Nov 04, 2009 | Toshiba Satellite A45-S250 Notebook
When starting windows, I get to the loggon page, I log on and suddenly there is a message saying, "this copy of windows hasn't been activated, would you like to do that now?" yes or no. when I click yes,...
I believe you are running Windows Vista. I've heard of many times that it has a problem loading or there is corruption in the bootup.
Even my mother's system crashed for no apparent reason.
Now, if you didn't make recovery disks, you can actually order them from HP for a price of about 40 dollars. As long as you have the original product key.
If you have recovery disks or obtain recovery disks based on the laptop you have, insert the first disk and there are options to repair the actual bootup files in Vista.
If you have important files on your system, have your hard drive hooked up to a standard PC through a USB external drive adapter and as long as there is no encryption, you should be able to retrieve them.
XP is the same to.
Jul 27, 2009 | HP Mini 1000 Netbook
D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Feb 17, 2009 | Dell Latitude D610 Notebook
PC wont boot to windows xp
This seems to Be a common problem with dells, The only way to fix it is to buy a new HD, And all data is Unrecoverable. Sorry for your loss
Jan 11, 2009 | Dell Inspiron 9300 Notebook
No screen visible
run win xp boot cd and access recovery console... run chkdsk... hit y when it asks you to... another way of doing this is right click on ur hard drive and choose properties.. tools... disk check... choose both the options asking for complete scan etc.. itll then say that scan will be done when windows is restarted.. say ok.. restart...
Nov 20, 2008 | Dell Inspiron 8600 Notebook
Seagate Barracuda 7200.7 ST380011A "a disk read error occured"
Might be a damaged sector. Otherwise i would think you (by accident) created a seperate partition on your C:\ (? main) HD. The cause of damage can be many things, certain types of certain brands or more sensitive in how fast these sectors get damaged. But you can at least try to repair them with the disk repair utility in Win XP, called ChkDsk ("check disk"). However, what may end up happening is that ChkDsk will mark the sector as bad (instead of attempting to recover any information) and your hard drive will no longer 'hover' over top of that area of the drive, making it impossible to recover any data on the sector. Maybe try to google for (free) BETTER third party software for this first. So what caused it is hard to discover after it happened, but you can try to repair it.
Nov 05, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
ASUS Eee PC 1000H Laptop Logo
129 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
