Question about Kitchen Ranges
Range Rover Air Suspension Problems - Kitchen Ranges
    Novelist:
    Sniper:
  • 58 Answers
I would recommend going to strutmasters.com and taking a look at our conversion kits. these convert you from the airbag to a powder coated American made steel coil spring that is guaranteed to last the life of the car. Airbags and compressors are constantly having to be replaced. Also something alot of people don't know is that theses air suspensions are not meant to be in temperatures above 90 Degrees or below 40 Degrees. That is most of the world. The temperature will cause you to replace alot of bags. and typically when your replacing a bag you are going to have to replace the compressor to because the bag had a hole or small crack in it causing the compressor to over work and it will die. I posted the link below so you can take a look http://www.strutmasters.com/land-rover-suspension-parts-s/21.htm I hope I was of some help Good Luck!!!
Posted on May 06, 2009
2004 land rover range rover hse transmission is overheating and drives like it's in sand or mud. Also have air suspension inactive warnings along wIth HDC inactive suspension light dosent even lightup
check that you are not in 4 x 4 settings on hard surface as that loads up the transmission making it work harder
that it turn can over heat the transmission oil
check for correct oil level in transmission as too much oil or not enough will also heat oil
take it to an accredited service center that has experience on your make of vehicle for a diagnosis of all problems
Nov 30, 2016 | BMW Cars & Trucks
What does air slip inactive mean
two videos for you
  • How to reset the air suspension inactive warning Range Rover www.youtube.com/watch?v=xR899nhkRxE
    • BY POWERFULUKLTD
    • 56 SEC
    • 290K VIEWS
    2010-11-11 · Video embedded · Air suspension inactive reset, ... How to reset the air suspension inactive warning Range Rover ... Wabco Air Suspension Compressor ...
  • Air suspension inactive problem range rover - YouTube www.youtube.com/watch?v=sv5nuKb10Ew
    • BY MMMZZZHHH
    • 52 SEC
    • 26K VIEWS
    2014-03-31 · Video embedded · Air suspension inactive problem range rover ... Wabco Air Suspension Compressor Repair Kit for Range Rover - BMW - Land Rover - ...
  • and some text for you.
  • Thread air suspension inactive
    May 16, 2016 | 2004 Land Rover Range Rover
    How to reset air suspension in a 2003 range rover
    This assumes the suspension has failed in some way. The cause could be a loose air line, a leaking air spring, the valve block, the compressor or the computer. Only a dealer or specialised LR shop can reset the computer, but you need to determine and fix the cause first
    Jun 13, 2014 | 2003 Land Rover Range Rover
    05 Range Rover HSE inactive air suspension
    Sorry computer controlled and it needs the dealer software to find the fault ,lot of money i would imagine to repair in the dealers
    Feb 14, 2012 | 2004 Land Rover Range Rover
    What is code 74 in the air suspension ecu
    Hi , I have a 2005 Range Rover HSE ,we replace the air suspension pump and since then I been getting code #74 " reservoir pressure static when filling "
    I like to know what does exactly it means .
    Nov 05, 2010 | 2003 Land Rover Range Rover
    Noise in front right
    pulling the relay will not solve your problems,will make vehicle dangerous to drive
    Apr 10, 2009 | 2003 Land Rover Range Rover
    Suspension
    Instead of replacing your failed air suspension parts I recommend converting to the passive coil spring system. This is a permanent fix to the problems caused by the air ride suspension. Check out Strutmasters website for the kit that will fit your Range Rover: http://www.strutmasters.com/Range-Rover-Air-Suspension-Spring-Conversion-Kit-p/-rr-03-4.htm. I hope this helps!
    Jun 19, 2008 | 2003 Land Rover Range Rover
    Kitchen Ranges Logo
    117 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
