Question about Sport & Outdoor - Others
I had my remington 541-t for over 25 years and at all most new ben shot lest then 1000 rd.now some how the bolt too tight after fired is the spring gond bad or it rust inside the fireing mec.
  • 6982 Answers
SOURCE: bolts to manifold & exhaust rusted
Bolts are screwed into the manifold (actually studs)
Best thing to do is to have someone heat them with a torch and get the nuts free. If the studs are in really bad shape, you will have to remove them from manifold and replace them (usually a torch job as well) Not a job for a burns o matic...need a real torch for this one! Or, just snap them off and remove manifolds to fix them.
Posted on Mar 18, 2009
SOURCE: Hi my subaru out back have ben miss firing start
check your
timing
exhaust pipe not proper tight or have hole
Posted on Jul 12, 2009
  • 3640 Answers
SOURCE: need the firing order including coil pack to
1995 Land Rover Range Rover SE
Posted on May 14, 2010
SOURCE: Crosman 766 was shooting fine, the next shot did
Upon cocking your gun is there the same tension with the cocking spring as there was befor? Also check the condition of your barrel seal for tears or cracks in it.
Posted on Nov 23, 2010
SOURCE: My Spit Pulsa 1000 wont fire
Did you get this problem solved and if so what was it?
Posted on Jan 22, 2011
Remmington 700 new total of 12 shots action works and sounds perfect but missfires leaves no mark on the primer
tear down the action clean the parts look for damage on each easpecially the spring and firing pin, and also the ejector to make sure a round is properly seated against the face of the bolt, do the rounds eject properly?, you may need to order a new firing pin and or spring from the manufacturer, Remmington online, some manufacturers will send you free parts such as smith and wesson who desnt even charge shiping
Jan 04, 2015 | Optics
I need a spring bolt stop
There is a spring on the bolt stop but it can't be lost unless somebody took it out. Remington has them. Bolt stop return spring.
Mar 24, 2014 | Remington Model 700 Special Purpose Bolt...
Remington field master 121 . will feed, fire and extract but will not eject
If this is a semi auto clean the gas passages. If it is a pump or semi auto check that the bolt travel moves full length. Make sure the extractor groove is clean and the spring that pushes on the extractor is clean.
Aug 29, 2013 | Garden
Remington 1100 wont eject or load another shell
check and see if the shell stop hasn't broken loose. this on the inside left side of the action . this could stopping the next shell in the mag. from being loaded. this not uncommon. but is an easy fix. a gun smith can stake it back in . in a few minutes for around $20.00
Nov 25, 2012 | Remington Shotgun Mount 12Ga Lh, B Square...
I have a Remington rifle which is a 22 caliber octagon barrel rolling block type serial number J282433. Any info on this rifle would be appreciated.
Could use more info, such as markings on the barrel and or breach. The Remington rolling block type single shot goes back to the 1860'S. The first 22 calibers around 1888. The rolling block went through 8 changes. The different types or changes are where various pins and screws are located, size and shape of hammers and triggers. The New Model Number 4, made from 1890 - 1933 came standard in 22 cal. with a 22 1/2 inch Oct. barrel. It will have a small lever on the right side of the breach. Approx 50,000 of these where made between the years noted. You could very well have a model 1, 2 or a model 7, which will be rare if in very good shape as only 1000, No. 7's where made. Tracking the serial number will be hard unless you contact Remington.
Oct 30, 2011 | Optics
My remington 870 is suddenly not loading shells from the tube. What could be the problem
It could be that the spring in the ammo tube is not strong enough to push them far enough back to clear the tube. Have you added any type of accessorys to the receiver like a side saddle, scope, etc? If you have changed the tightness of any of the screws or bolts (such as you would replace or adjust for a side saddle), it can bind up the action and prevent the free movement of the shells. Is it a new weapon? Is it propperly lubricated?
May 11, 2011 | Remington Sport & Outdoor - Others
Friend jus baught an older remington with the serial number 582793. Trying to figure out what ammunition it takes because it doesnt say on the rifle
It would help if you told us shotgun or rifle, center fire or rim fire, pump, falling block, lever, bolt action, or auto loading, etc.
Then it would help to simply see what fits into the end of the barrel.
Next would be to measure the length of the action.
After 1921 Remington use letter codes for year and month, so this would have to be earlier than that, since it has no letters.
Nov 01, 2010 | Remington Sport & Outdoor - Others
I just bought a new tippmann 98 custom act platinum edition and it doesnt seem to be firing right. i upgrades the rear bolt and trigger and after a few shots the bolt lock in the firing position. if i pull...
I would look in to the bolt and check that it moves freely, also check that is properly lubed, and finally that your upgrade bolt does not need a different spring. I would also check the batteries on the grip if it is an E-trigger.
Mar 18, 2010 | Tippmann 98 Custom Act Paintball Gun
Sport & Outdoor - Others Logo
101 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
