I need instruction manual for aiwa ad-wx929 as it never arrived with cassette deck
4 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: User/owners manual
www.vintagecassette.com
or
hifiengine.com
Posted on May 05, 2008
  • 18 Answers
SOURCE: Downloading an instruction manual for the K-700 Cassette Deck
Make sure you have the correct model # and go to the Yamaha web site. There is no K-700 but there is a K-720 (I have this tape deck).
http://www.yamaha.co.jp/manual/english/search.php?div=emi
Posted on Jul 17, 2009
SOURCE: Tape jammed in AIWA AD-F640 deck.
tapes jammed in this machine are usually due to drive problems. try turning the drive wheels inside by hand and see if the eject kicks in. usually requires new belts / drive wheel tyre
Posted on Apr 10, 2011
Aiwa AD F660 cassette deck. Having changed the drive belts, the eject button does not now work. Hook holding the cassette door shut does not drop enough to release. How can I fix this? Thanks, Brian
Have you trapped wire or something near the hook mechanism stopping it from getting full travel when the button's pressed?
The nice people at HiFiengine have a service manual for the deck, free you just need to join.
HTH
Aiwa AD F660 Manual 3 Head Stereo Cassette Deck HiFi Engine
Jan 19, 2018 | Aiwa Audio Players & Recorders
I HAVE JUST BOUGHT TWIN CASSETTE DECK AIWA AD-WX727 ON EBAY AND TRYING TO WORK IT. BOTH CASSETTE PLAYERS ARE WORKING O.K BUT WILL NOT RECORD CAN YOU HELP. I HAVE FOLLOWED THE MANUAL BUT NO JOY.
It is often a bad idea to buy dual cassette type decks. They never work very well except for one unit I have seen which was the Sony ES model. It was not cheap at $1200 a unit. You might get it to work but the performance of these is poor even when new. Avoid dual cassette deck at all costs.
Jul 01, 2016 | Audio Players & Recorders
Aiwa ad wx929
this is what i rendered to another person asking about replacing belts in a tape transport
Can you not retrieve you tape ?
this is caused by a safety feature, your tape is not damaged more than it might already be, if your take up spool the right side dos not rotate when it is suppose to it registers a fault. in all cases it simply dos not play the tape.
some other units require the loading of the tape path components IE pinch roller/ and tape pickup heads if this function is interrupted and unable to complete its cycle you will not get your tape back until you disassemble and manually advance the function to it`s conclusion ARE YOU PREPARED TO UNDERTAKE THIS PROCEDURE ?.
Nov 01, 2013 | Audio Players & Recorders
How do I get my HS-TX686 to go into continuous auto reverse?
Look in the operating instructions which you would find by searching "Aiwa HS-TX686 manual"
http://www.retrevo.com/support/Aiwa-HS-TX686-manual/id/1077bh447/t/2/
Under "Playback"
Aug 13, 2011 | Aiwa HS-TX686 Personal Cassette Player
Aiwa cassette deck won't eject
I had this problem on an AD-S40. Turned out to be the drive belts, which had stretched, resulting in the fact that the motors couldn't drive the mechanism through it's various load cycles of opening/closing the captain roller, etc. as required to operate the mechanism. Stuck in mid-cycle, the doors would not open.
After removing the case cover, you can turn the belt driven wheels by hand to complete the cycle, so that you can eject. Then get new belts (several outfits sell belts based on length, on line). You don't need to do much to replace the belts -- after unlocking and getting the tape out, it was only a couple of screws to remove the mechanism, as a unit, and there is no need to fuse with the circuit boards and such. Easier than I expected.
Apr 20, 2008 | Audio Players & Recorders
Fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Dec 25, 2007 | Aiwa Audio Players & Recorders
680 people viewed this question
 Grubhead
Grubhead
