Question about Car Audio & Video
I have just bought a Fusion subwoofer and amplifier package, the EN-AT110, which is a 10" sub in an enclosure. i have wired it in correctly and after about 2 minutes of usage it just stopped working. no sound at all, if i pull out both rca leads then the sub pops. the blue power light stays on unless i take out both rca leads or unplug the power cables, so it is still getting power, and signal. could the speaker have possibly blown??
    Champion:
  • 227 Answers
Try a different speaker if there is no sound then it is your amp output fried. Goodluck.
Posted on Apr 24, 2008
Mtx mxa 6001 amp cant get it to produce good bass using mtx 5500 subs running a 2ohm load
You seem to have everything in spec. check your crossover points and your speaker wiring. subs may be playing out of phase.
A huge factor is subwoofer enclosure ...if the enclosure is not in spec with sub requirements the subs will not peform great.
Sep 23, 2013 | Car Audio & Video
How to assemble boss sub woofer,any?
If you have already bought the subwoofer, you will need to buy an enclosure for it. As well, you will need an amplifier and a compatible receiver for the amplifier.
Once you have all of these components, you will need to wire them all together. For this, you will need a pair of RCA cables to run from the receiver to your amplifier, a power wire to run from your amplifier to your battery, and wire running from your amplifier to your enclosure/subwoofer.
For a more in-depth tutorial on how to install your subwoofer, check here:
http://www.wikihow.com/Install-Subwoofers
Mar 01, 2011 | Boss R12 Riot Series Subwoofers (12 ;...
I have a rockford fosgate ounch 325.1 (2004). I recently helped my parents move and took the sub and its sealed enclosure out of my 1994 Ford Explorer. The sub and amp worked until the move. After I...
it sounds like you have a short someplace. also, if you have a multimeter, check the voltage coming out of the speaker terminals of the amplifier. if the voltage is higher than 4 or 5 volts, the amp is probably bad.
Jan 10, 2011 | Car Audio & Video
Subwoofer rumbling noise
check all your supply wiring's specially the one that is connected directly to the positive terminal of your battery, it has to be of enough gauge to supply your amplifier's wattage, and it is has to be properly grounded to the body of your car.
May 20, 2010 | Fusion FEW12PK Car Subwoofer
Wireing two dual 4 ohm kicker cvr 15s on a memphis pr1000 at a 1 ohm load. I trying to get these kickers to hit harder. Do I need a bigger amp or what?
CVR series do not have large power handling capabilities.
Your subs will melt before the amplifier is used to its full potential.
If the subs arent in a ported enclosure - do that.
They both handle 500w rms - so the pr1000 is perfect.
bass response is all in the enclosure!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
What do i need to install a subwoofer
Here's what you need:
1) An enclosure for the 8" subwoofer.
2) 8" subwoofer.
3) Amplifier to power the sub.
4) Amp wiring kit.
Your Sony has two sets of preamp outputs so make sure that your wiring kit includes a set of RCA's.
Mar 24, 2009 | Sony Car Audio & Video
How do you wire up 2 4 ohm dual voicecoil subwoofers for 1 ohm?
Both + on Both Subs to + Terminal on amplifier.
Both - on Both Subs to - Terminal on amplifier.
Jan 15, 2009 | Kicker DCVR124 -- 4 Ohm Dual 12in CompVR...
Cu Ft for Sub
EN-SW100 EN-SW120 EN-SW150
PORTED
Volume (litres) 28.5 48.28 91.28
Volume (cuft) 1.008 1.705 3.223
Port diameter 76.2mm / 3" 76.2mm / 3" 101.6mm / 4"
Port length 255mm / 10" 225.3mm / 8-9/10" 242.5mm / 9-1/2"
Tuned frequency (Hz) 41.6 33.0 34.2 SEALED
Volume (litres) 15.71 28.58 85.53
Volume (cuft) 0.56 1.009 3.02
Tuned frequency (Hz) 69.9 53.9 44.4
If this doesnt come out right, look at the following link...
http://www.fusioncaraudio.com/north-and-south-america/suggested+encounter+subwoofer+enclosures+sizes-12-technical-support-detail.aspx
Jan 08, 2009 | Fusion 10" Single-Voice-Coil 4-Ohm Marine...
Subs not hitting
remote wire turning on amplifier?
Ground for amplifier?
Gain improperly set?
Radio output crossed over above tuning freq. of enclosure?
Just suggestions. Not much info to go by.
Dec 15, 2008 | Jensen BP212 Car Subwoofer
Sub installation
You would be better served to go to a local shop and get the correct fittings to fit the connections, and use those to connect your subs. Just running the wire tips will result in loosed connections and plenty of headaches..
Jan 04, 2008 | Rockford Fosgate Punch Stage P110 S4 Car...
Car Audio & Video Logo
133 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
