Question about Apple iPhone Smartphone
Battery runs down rapidly(6-7 hours) - Apple iPhone Smartphone
  • 34 Answers
We had a power failure after a few power surges and now I cannot set the clock. The display keeps blinking rapidly. How can I set the clock?
Jensen Smart Talk JCR 290 User Manual Page 10
USING MANUAL SETTINGS
In radio off mode, press SET BUTTON (#5) to enter AL1/AL2/Time
setup mode.
1. The HOUR DIGITS and AL1 indicator in the LCD panel will flash.
2. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired hour for AL1.
3. Press SET BUTTON (#5). The MINUTE DIGITS and AL1 indicator
in the LCD panel will flash (#25).
4. Using the > (UP) (#6) or < (DOWN) (#4) BUTTONS, adjust to the
desired minute for AL1.
5. Press SET BUTTON (#5). The SOUND EFFECT INDICATORS of
AL1 will flash (#25).
6. Use the > (UP) (#6) or < (DOWN) (#4) BUTTONS to choose a
Wakeup Alarm Sound - Ocean, Rain, Brook, Radio or Beep Alarm.
Jensen Smart Talk JCR 290 User Manual Page 9
Mar 02, 2016 | Jensen Interactive AM/FM Talking Dual...
Battery keeps going flat on gilera runner 125vx 4stroke
Three possible issues: Bad battery won't hold a charge or rapidly loses a charge. Bad charging system/ alternator. Current draw on the battery when turned off. Use a multimeter to check voltage on battery terminals when it is running. You should see at least 13 volts. Fully charge the battery for about 6 hours, unplug it from the charging system, and then check the battery voltage. It should be at least 12.0 volts, actually a bit higher. If your ammeter can handle it, you could test for current when it is turned off. You want the reading to be 0 or very close to zero,
Oct 17, 2013 | Motorcycles
Batteries fine but drain fast why
A load test only checks for current - not capacity. Recheck the batteries after they run down in 2 miles for internal resistance. Chances are one of the batteries has a high resistance.
If the battery gauge comes up after running down and sitting then look for a bad or corroded battery connection at the batteries, fuse/ circuit breaker and controller power connection.
Sep 07, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
Can i use 3 12volt batteries in a golf cart instead of 6 6volt batteries
Yes you can but the down side is that the total amp hour rating from 3 x 12 volt batteries may be a lot less than the amp hour rating from 6 x 8 volt batteries. This means you will run out of battery power a lot sooner.
Mar 15, 2012 | Cars & Trucks
Why so long to charge cordless tools
depending on the saw you bought, (or other tool) some come with what is called a "rapid charger" and some come with a small "trickle" charger. most cordless tool batteries take about 1 to 1 1/2 hour to charge (from empty) using a rapid type, the trickle charger will take up to 8 hours to charge a battery. if you want fast, but the rapid charger, and usuallly when you buy one you can get a free battery with the deal.
Mar 22, 2011 | kawasaki Saws
I believe i have a weak battery on my car when i tried starting the car after it had sat a month it was dead. I boosted it and it started and run fine. I bought a trickle charger and put it on the battery....
1. You possibly have a dead cell in the battery or a loose ground.
2. check your battery also for corrosion are the post.
3. Take you battery to a checker, Auto zone,or other auto parts place that can check the battery for you and tell whether the battery needs replacement.
4. if the battery is 4 yrs old or more it more than likely has lost it's ability to take a charge.
5. Also check the alternator> if the alternator has gone bad the battery will not be charged.
6. If a car has set for more than a week without starting or running it for 30 minute to an hour it will deteriorate.
Feb 19, 2011 | Computers & Internet
FS240BX battery how Long should it take to charge.
Hi .Charge the battery initially for 9 hours.
After the initial charge, under normal usage, your power pack should be fully charged in 3 to 6 hours. If the power pack is run-down completely, it may take up to 6 hours to become fully charged.
The red light is just a power indicator. The light will not go out, change color, or blink when the charging has been completed.
To prolong power pack life, avoid leaving the power pack on charge for extended periods of time (over 30 days without use). Although overcharging is not a safety concern, it can significantly reduce overall power pack life.
The power pack will reach optimum performance after being cycled 5 times during normal usage.
There is no need to run the batteries down completely before recharging. Normal usage is the best method of discharging and recharging the batteries
Hope this was of some help to you.
Jan 22, 2011 | Black & Decker Firestorm Slide Battery
My calculator drains a set of four batteries with every use. Why?
I am not sure what every use means: duration, programs running etc. But that drainage is properly excessive. TI estimates that with 2 hours a day of usage, the batteries should last a school semester.
Possible causes of rapid drainage.
The most common causes of rapid battery drain are mismatched batteries
  1. Batteries of different brands
  2. Batteries of different types (alkaline (1.5V + rechargeable NiMH 1.2V)
  3. Batteries of different charge levels (new batteries with old ones)
  4. Negative charge build up
Another cause of rapid battery drain is the use of third-party programs: Certain of them keep large amounts of data in memory. Some of them are tweaked to bypass the TI power management scheme and disable the TI APD (automatic Power Down ) after 5 minutes of inactivity.
Possible remedies
  1. Remove all batteries (main batteries and backup battery)
  2. Leave them out of calculator for about 15 minutes. (Beware that this will clear the contents of the memory and that data will be lost along with all applications installed). However Applications cam always be reinstalled once calculator returns to its normal state.
  3. The possible benefit of the removal of all batteries is to make the negative charge build up disappear.
If that fails
If the foregoing steps fail to restore the calculator to its normal behavior, you may have to contact TI Customer Assistance by filling out and submitting a customer assistance form.
Dec 18, 2009 | Texas Instruments TI-84 Plus Calculator
Ummm, hi. i was wondering how many watt my Acer Aspire 5600 runs?
Power
subsystem
ACPI 2.0 CPU power management standard: supports
Standby and Hibernation power-saving modes
71 W 8-cell or 44.4 W 6-cell Li-ion battery pack
Acer QuicCharge™ technology
(for Aspire 5600 Series):
• 80% charge in 1 hour
• 2-hour rapid charge system-off
• 2.5-hour charge-in-use
90/65 W AC adapter
Oct 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
How do you set the clock on the panasonic cq-c1121u cd radio.
1 Turn the ignition switch until
the accessory indicator
lights.
2 Press [SRC] (PWR: Power).
3 Press [DISP] (CLOCK).
4 Hold down [DISP] (CLOCK) for more than
2 seconds.
5 Adjust the hour.
[[]: sets the hour ahead.
[]]: sets the hour back.
6 Press [DISP] (CLOCK).
7 Adjust the minute.
[[]: sets the minute ahead.
[]]: sets the minute back.
8 Press [DISP] (CLOCK).
Notes:
¡ "AdJ" is displayed before adjusting the clock.
¡ Hold down []] or [[] to change numbers rapidly.
power off displayPower Off
Press [DISP] (Display) to change the display.
Mar 10, 2008 | Audio Players & Recorders
Apple iPhone Smartphone Logo
125 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
