Question about Kenmore Dishwashers
Kenmore Dishwasher Model # 363.14391991 It does not allow water to come into the machine. What could be the problem and what part do I need to repair it?
  • Kenmore Master
  • 2,605 Answers
Hello Sonny,
Welcome to FixYa !
The problem you're experiencing based on your description sounds like (unfortunately) a common one.
First check the float isn`t being obstructed and thereby indicating the unit is already full.
The other possibility....
The water inlet valve can be an issue with dishwasher's if they fail in the closed position, It'll need to be replaced likely, but you can try to fix it.
You can remove the water line and remove the valve and try to clean it out...it's usually futile, but worth a try.
You may want to call in a pro however, the part to repair it is available at most brick & mortar appliance part centers or you can check out on-line vendors such as "repairclinic.com" "searspartsdirect.com" or "apwagner.com" etc.
Do a search by typing in your actual model number and you should find it. Hope that helps move you forward.
Let me know if I you need help on how to change it etc.
**It's relatively easy with Whirlpool built Kenmore or any other for that matter. First Turn off the power, the water, safety first...access is gained through the kick plate/toe panel below the door.**
The valve will be on the left and involves only removing 2 screws, the water line in & out and 2 wires which go on either way...they aren't polarity specific. Should resemble this image...
Thanks for coming to "FixYa" for your inquiries. Let me know how you make out or if you require further assistance.
Good luck.
macmarkus :)
Posted on Jul 29, 2010
665.13049k110 kenmore dishwasher won't drain.
Check that the drain pipe exit point is higher than the water inlet and drain connection on the machine, thats a comin problem, also check and clean the drain pump situated at the front of the machine at the botom underneath the cover
Oct 03, 2017 | Kenmore Dishwashers
Kenmore Ultra Wash. What is the proper operating water depth for my dishwasher?
Try checking the q&a section of the technical support manual. Also get in touch with the manufacturer, they should be best placed to help.
Jun 10, 2015 | Kenmore Washing Machines
On my Kenmore Dishwasher Model 66513749K601, the door is leaking water. I'm wondering if changing the gasket will repair it or if this machine has a history of other issues.
Hi, Just change the door seal... it is very easy to do...and don't cost much at all...
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Aug 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
I have a Kenmore Elite dishwasher model number 665.16483300. The motor is very loud and have been told by a technician that it needs to be replaced. I am looking for a service manual that may allow me to...
THE DISHWASHER is no doing good, foot soil left on dishes, I alreary check water temperature 50 F, I clean inside, the pressure at the water supply is good 50psi. and the machine it sound quiet, Is the pump no working right?? is derty inside??
Sep 30, 2010 | Dishwashers
Hi, I have a model 587 kenmore dishwasher which abruptly wont allow any water in right after I turn it on.
Assuming the water supply is on to the unit, check for a bad, stuck or clogged water fill valve. Some have a screen that can get plugged. You will need to turn off the water supply, remove the front lower cover, drain any remaining water out of the machine with a shallow pan, and then check the fill valve. You will probably have to remove it to do this. If you aren't comfortable with this kind of service, it's best to call a repair shop.
Another csue of this could be a problem with the dishwasher control board, but again, it's more advisable to have it checked by a repair shop.
Jun 07, 2009 | Dishwashers
Kenmore dishwasher model 63991 (10yrs old)
If the display works, but the machine doesn't fill, wash, or pump out, the control board is the only component that could cause all these symptoms.
Aug 26, 2007 | Kenmore 24 in. 16259 / 16254 / 16252...
Kenmore Dishwasher #587.... doing nothing but heat dry
The problem appears to stem from the float and float switch. The float is a mushroom shaped plastic part that resides on the bottom left, just inside the door. It appears that the float does not release the float switch, causing the dishwasher to think it is full of water, and won't allow the dishwasher to fill. It's a relatively straight forward repair, but even with a new part, the same scenario is likely to repeat itself until the float or float switch is modified by Kenmore.
Nov 20, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
316 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
