Question about New Home HF-1012 Mechanical Sewing Machine
New Home sewing maching, using Gutermann thread to sew faced, turned "windows" (square)....PROBLEM: the machine checks, the thread pulls, seriously nests on the underside and I notice that the thread spool (on top) seems to have "thrown" a loop of thread that twists before feeding into the tension mechanisms. Thread also becomes wound around spindle underneath the bottom of the spool. I have to stop, work the thread free, clear multiple threads that have become jammed up in and around the bobbin and bobbin spindle. I've got my needle in correctly, tension adjusted, machine is clean and oiled, thread tails are not an issue as I hold them clear at all point -- beginning, turns, ends. I never had this problem with any other thread or when working any other procedure or sewing technique. I always make the turns with the needle completely down in the fabric.... Help!
  • burtja117 Jul 29, 2010
    Excuse me, the model number is 1502, I mis-typed....
  • New Home Master
  • 7,365 Answers
1.put new spool of thread on
2.watch the thread on the take up lever,make sure it doesn't come off
3.check the tension disk for loose threads, if there are threads pull out
4.check needle for being bent or blunt --if so replace
Posted on Jul 29, 2010
What thread to use?
You can search on the net directly. It maybe faster Motor Part Store Motor Parts Wholesale
Jun 27, 2016 | Sewing Machines
New Home sewing maching how to thread the bobbin
check with youtube for a video
do you have a manual?
Aug 21, 2012 | New Home Sewing Machines
I have a white sewing machine model #426, the thread breaks at the needle as soon as it starts to sew. I cleaned and oiled the machine.
Could be a couple of things so best to trouble shoot the following possible causes:
Cheap thread, brittle old thread. Always store thread in an airtight container out of sunlight and don't use the cheap 5 rolls in a bag in the bargain bin in your sewing machine, fine for hand tacking but not good to machines. Brands like Gutermann, Metrosyne or Sylko Supreme are good.
Needle bent or has a burr on it or is in backwards. Change needle, flat shank to the back.
Thread is catching somewhere on the threading path from spool to needle. Or hooking up on the thread spool itself, some brands have a little notch cut in top to hold the thread tail, but thread can catch in this as you start to stitch. Turn thread spool up other way or use a mushroom cap over the spool to help thread to run off smoothly.
Thread top tension is too tight, should be on 5. When you lower the pressure foot and pull the thread from below the tension device, can you feel firm tension on the thread. Should still be able to pull it though. If you can't pull it it at all when set to 5 then device is faulting.
Obviously if you have tried all of the above and it is still faulting, or you thing the top tension device is the cause, then you could try cleaning the top tension discs (turn to zero and floss with dental floss, check one of my other solutions, I've covered this lots), then I'd suggest it needs a professional service.
If you don't have a manual for your machine they are available from Singer website, http://www.singerco.com/accessories/instruction-manuals, type in W426 then click "search", often free as pdf files.
Jul 11, 2011 | Sewing Machines
I have a bernina 210 model sewing machine. I'm
#1 Use only Mettler or Gutermann thread. Coats thread is very rough and will pucker the fabric. #2 Make sure that the tensions are balanced. #3 Use the regular zig zag foot. #4 Use a new needle, universal, size 80/12. A blunted point will pucker the fabric.
Jun 02, 2011 | Bernina Activa 140
I cannot seem to get the tention right, the threats pulls the material very badly and it is very tight
Is this a new machine, old machine, serviced recently??
Here is my regular checklist for stitching issues:
Change the needle and pick the right size for the fabric you are sewing, or ball point for stretch fabrics.
What thread are you using? good quality cotton wrapped polyester is good, Sylko Supreme, Metrosene, or Gutermann are all good brands.
Wind a fresh bobbin and keep tension on the thread spool and nudge the thread going onto the bobbin to ensure a neat even fill at consistent tension.
Clean out the rotary hook area and give it an oil. Clean between the tension discs on the top tension dial by turning down to zero to open up and running the edge of a piece of clean fabric waste between the discs.
Now check your bobbin tension, is it a front loading bobbin and bobbin case like the Brothers? If so, do the dangle test where you hang the bobbin by the loose end and see if it dangles, ie enough tension to hold the bobbin's weight, but will also release thread if you give it a gentle pull. If not, gently turn the tension screw on the bobbin case down a bit and try again.
Set top tension to the middle number on your machine. Now thread again paying attention to ensure the thread path is clear, raise the thread aerial if there is one, the thread is under tension in the bobbin correctly, and the top thread is also under tension when the pressure foot is lowered.
Set stitch length to 2.5. Now test sew, holding the two thread tails back out of the way as you start. Look at the stitch formation and adjust the tensions if it still looks too tight.
You can get lots of general info on www.sewing.about.com too which is helpfull.
Feb 27, 2011 | Sewing Machines
Sewing problems
For a comprehensive 5 page illustrated tutorial...Check this solution link, just copy & paste:
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=1060&prdid=131120&smid=23884&mthid=1&mpsaugid=347d7805-9ce5-42d2-b812-b602b6cf7437
Mar 28, 2007 | Euro-Pro 8260 Mechanical Sewing Machine
New Home HF-1012 Mechanical Sewing Machine Logo
157 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
