I've just purchased a samsung SH-S203 sata drive my motherboard recoginses it but winxp seems to freeze with it pluged in unplug it from mainboard and computer starts up plug it in whilst xp is running and the auto hardware installer starts but freezes is there anything that needs to be done Regards Scott
  • 106 Answers
Check the boot priority for the second disc as the conflict may be because of that
Posted on Apr 24, 2008
Will K8MM-V MS-7142 Motherboard supports 500GB/250GB Sata 3(6gbps) Hard disk, by setting to 1.5gbps speed ?
The designers of SATA aimed for backward and forwardforward compatibility with future revisions of the SATA standard.[citation needed] To prevent interoperability problems that could occur when next generation SATA drives are installed on motherboards with legacy standard SATA 1.5 Gbit/s motherboard host controllers, many manufacturers have made it easy to switch those newer drives to the previous standard's mode. For example, Seagate/Maxtor has added a user-accessible jumper-switch, known as the Force 150, to enable the drive to be switched between 1.5 Gbit/s and 3 Gbit/s operation. Western Digital uses a jumper setting called OPT1 Enabled to force 1.5 Gbit/s data transfer speed (OPT1 is enabled by putting the jumper on pins 5 & 6). Samsung drives can be switched to 1.5 Gbit/s mode using software that may be downloaded from the manufacturer's website. Upgrading a Samsung drive in this manner requires the temporary use of a SATA-2 (SATA 3.0 Gbit/s) controller while programming the drive.
May 09, 2012 | MSI Ms-7142 k8mm-v Mainboard Ide - Socket...
Drive the motherboard
This is your Mainboard driver
MSI K8T Neo V (MS-7032)
Direct Download :
VIA 10/100 LAN Drivers
XP :
Vista :
VIA PIDE/SATA RAID Drivers & Utility
XP :
Vista :
Realtek ALC Series AC97 Audio Driver
XP :
VIA Chipset 4in1 Drivers
XP :
Vista :
VIA VT8237(R) SATA RAID Driver (For floppy driver)
XP32bit :
AMD Cool and Quiet Driver
• AMD Athlon™ 64/Sempron™/Turion™ 64/Opteron™ systems with ACPI 2.0 processor performance control objects
• WinXP WHQL pass
XP :
May 08, 2009 | Intel Motherboard
Samsung dvd writer sh-s203 need firmware
sounds like you have not adjusted the jumper setting for the drive
Dec 02, 2008 | Computers & Internet
Samsung SH-s203 dvd writer is compatable with this motherboard
put the sata cable to sata terminal and also connet the sata power cable to drive.
Oct 28, 2008 | Intel D845GVSR Motherboard
New Samsung SH-S203 DVD writer with SATA has a plug-in in the back that doesn't seem to match the plug on my SATA cable which goes from my ABIT AW9D-MAX motherboard to my Pioneer burner which also has a...
The power connector is really similar to SATA connector. It's not like IDE/EIDE. It should be a flat connector.
Take acloser look, most of the times both connectors are very close.
Jun 28, 2008 | Computers & Internet
Firmware upgrade disables dvd
there may be some virus in your system blocking it check for virus in your pc
Jun 21, 2008 | Computers & Internet
Sp2004c sata hard drive is not recognised on system by bios or samsung hard disk manager all pluged in corectly to a new m/b, please help built a few pc`s now and not had this prob b4
  • Some SATA HDs have jumper for 1.5 G (SATA I) and 3 G (SATA II)mode. Try switching the jumper to 1.5 G or SATA mode (see motherboard manual).
  • Or you might need to upadte BIOS to support SATA drives.
Good Luck
Iqbal
May 11, 2008 | Computers & Internet
SATA configuration for MSI P965 Neo --- JMicron hell!
Once you have loaded your main board drivers,configuration should be pretty much automatic.Personnally,I have my dvd drive on the standard IDE ribbon cable header,and 2 SATA HDD.One on each SATA header.After loading The mainboard Drivers,Windows did the rest.I haven't found any need to mess around with any BIOS settings at all.
I currently am using a Biostar P4M900 board,but I have dealt with MSI before,and they are pretty much the same deal.
Feb 07, 2008 | MSI P965 Neo-F Motherboard
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
